Invalid thread access from SWT [message #90087] |
Mon, 26 May 2008 13:57  |
I get an invalid thread access exepction from SWT as I call refresh on my
table viewer. I use the following code that is inside a listener that
listens for changes of my model:
DUMMY.addSaveListener(new ISaveListener(){
public void saved() {
Job refreshJob = new UIJob(""){
public IStatus runInUIThread(IProgressMonitor monitor) {
monitor.beginTask("Refreshing...", 1);
refresh();
monitor.done();
return Status.OK_STATUS;
refreshJob.setUser(true);
refreshJob.schedule();
public void savedApplKindPauschData() {
public void refresh() {
if(!viewer.getTable().isDisposed())
viewer.refresh();
Markus
Re: Invalid thread access from SWT [message #90975 is a reply to message #90789] |
Fri, 30 May 2008 03:46  |
Originally posted by: rherrmann.innoopract.com
Hi Markus,
I can reproduce the invalid thread access. It occurs regardless
which browser is used.
To work around the issue you could wrap the UI code like this:
UICallBack.runNonUIThreadWithFakeContext( display, new Runnable()
public void run() {
refresh();
Currently I think this shouldn't be necessary. The fake-context
should be provided under the hood. But we need to investigate this
more thoroughly.
I filed bug 234779 to track and discuss this issue.
Rüdiger
Markus Krüger wrote:
> Hi Rüdiger,
> to reproduce apply the attached path to your demo. This patch adds and
> activator with my simple save listener and a dummy save method that fires
> the listeners when called. The FooEditor calls this save method on save. The
> DemoTableViewPart registers a save listener and wants to refresh on save.
> Now start the demo and call it with IE7 (may be IE6 will raise the bug, too,
> but I hove not tested). Open the FooEditor and add some changes and save it.
> You will see an error and the console states an invalid thread access
> exception from SWT.
> The patch also shows bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=234103. When you start the
> workbench nothing seems to be selected in DemoTableViewPart, but if you
> scroll up bit, then you see the selection. Pushing the extra button alwas
> reveals the selection.
> Markus
> "Rüdiger Herrmann" <rherrmann@innoopract.com> schrieb im Newsbeitrag
> news:g1knc6$dnn$1@build.eclipse.org...
>> Markus,
>> I couldn't reproduce what you describe. I changed the WorkbenchDemo
>> by adding a UIJob that refreshes a viewer.
>> Could you provide a standalone snippet that reproduces the behavior?
>> Cheers
>> Rüdiger
>>> I might need to add, that this only happens in IE (i use IE7), not in
>>> FireFox!?
>>> "Markus Krüger" <krueger@ion.ag> schrieb im Newsbeitrag
>>> news:g1eti7$tnt$1@build.eclipse.org...
>>>> Hi,
>>>> my
>>>> refresh();
>>>> monitor.done();
>>>> viewer.refresh();
>>>> Regards,
>>>> Markus
FUDForum. Page generated in 0.04692 seconds
