Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY
[Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90001] Tue, 17 July 2007 07:19 Go to next message
Hello, I'm updated teneo version to 0.8.0.v200707121518,
I want to use new version in order to correct
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185717 bug.
Casused exception:
org.hibernate.MappingException: Foreign key
(FKF8C83C375882C2E:dtsadd_paymentdescription [dtsadditionalpaymentst_id]))
must have same number of columns as the referenced primary key
(dtsadditionalpaymentstype
[dtsadditionalpaymentst_id,dtsadditionalpayments_idx])
at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.jav a:90)
at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.jav a:73)
Should I use some persistence options?
I tried to use PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY with "unique"
options, but it was useless.
code:
final Properties persisence=new Properties();
persisence.put(PersistenceOptions.JOIN_TABLE_NAMING_STRATEGY , "ejb3");
persisence.put(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH, "25");
persisence.put(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
// persisence.put(PersistenceOptions.PERSISTENCE_XML , "persistence.xml");
// used earlier
persisence.put(PersistenceOptions.JOIN_COLUMN_NAMING_STRATEG Y, "unique");
hbds.setPersistenceProperties(persisence);
I used to use persistence mapping file, but now it doesn't help.What wrong?
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90017 is a reply to message #90001] Tue, 17 July 2007 07:45 Go to previous messageGo to next message
Can you post the part of the generated hbm which covers this assocation?
gr. Martin
> Casused exception:
> code:
> // used earlier
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90032 is a reply to message #90017] Tue, 17 July 2007 08:13 Go to previous messageGo to next message
I cann't, because exception caused in hbds.initialize() method and hbm
mapping isn't generated yet.
I can post ecore model or old hbm mapping:
old hbm.xml:
<class
name=" customs.ru.esaddts.common.aggregate.types._3._0._1.impl.DTSA dditionalPaymentsTypeImpl "
entity-name="DTSAdditionalPaymentsType" abstract="false" lazy="false"
table="`dtsadditionalpaymentstype`">
<meta attribute="eclassName">DTSAdditionalPaymentsType</meta>
<meta
attribute="epackage">urn:customs.ru:ESADDTSCommonAggregateTypes:3.0.1 </meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="column9A" lazy="false" insert="true" update="true"
not-null="true" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`column9a`" length="1"/>
</property>
<property name="column9B" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`column9b`" length="1"/>
</property>
<list name="paymentDescription" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`dtsadditionalpaymentst_id`" not-null="true"
unique="false"/>
</key>
<list-index column="`dtsadditionalpayments_idx`"/>
<element type="java.lang.String"/>
</list>
<list name="paymentConditionDescription" lazy="true"
<key update="true">
unique="false"/>
</key>
</list>
</class>
<joined-subclass
name=" customs.ru.information.customs.documents.dt.sout._3._0._1.im pl.DTSoutTypeImpl "
entity-name="DTSoutType" abstract="false" lazy="false" extends="BaseDocType"
table="`dtsouttype`">
<meta attribute="eclassName">DTSoutType</meta>
<meta
attribute="epackage">urn:customs.ru:Information:CustomsDocuments:DTSout:3.0.1 </meta>
<many-to-one name="dTSAdditionalPayments"
entity-name="DTSAdditionalPaymentsType" cascade="all" lazy="false"
insert="true" update="true" not-null="false">
name="`dtsadditionalpaymentst_id`"/>
</many-to-one>
</joined-subclass>
  • Attachment: model.rar
    (Size: 57.62KB, Downloaded 178 times)
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90047 is a reply to message #90032] Tue, 17 July 2007 08:14 Go to previous messageGo to next message
It should be possible to call getMappingXML() after the exception and still get the mapping out of
de datastore. It really helps if I can the difference between the old and the new hbm.
gr. Martin
> old hbm.xml:
> <class
> <meta
> </id>
> </version>
> </property>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> <joined-subclass
> <meta
> </many-to-one>
> </joined-subclass>
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90063 is a reply to message #90047] Tue, 17 July 2007 08:43 Go to previous messageGo to next message
Ok, I'm attachnew hbm, old hbm and old persistence...
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90077 is a reply to message #90063] Tue, 17 July 2007 08:47 Go to previous messageGo to next message
entirely foghot, archive description:
persistence.xml - old persistence
hbm.xml - it old hbm
hbm1.xml - it new hbm
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90137 is a reply to message #90077] Tue, 17 July 2007 10:51 Go to previous messageGo to next message
Thanks, I noticed the following differences:
- the persistence.xml did not seem to be picked up (at least not for the join tables)
- Teneo now adds a column tag to a key (this is probably were your exception comes from, although my
testcases don't get this exception)
- Teneo does not recognize your date fields as such (they are mapped as strings)
- Teneo adds a scale="0" to numeric columns
Can you send me the ecore file or if that is easier the model project? I can analyze why the
differences occur and repair this (if relevant).
Which options do you use to generate the hbm's?
gr. Martin
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90288 is a reply to message #90137] Wed, 18 July 2007 03:42 Go to previous messageGo to next message
Hello.
1. Scale=0 - I a bit changed code for generation numeric filed: if exist
precision attribute always adding scale attribute (doesn't matter scale
contain default value or not). It fix same bug but I don't know whose its
bug (hibernate or teneo or mine or etc :))))) )
--- Most likely, it's hibernate bug and I don't post its in this
forum(news).
2. Ecore files: I attached their previous in 3th post (model.rar)
3. I used persistence.xml before, with this bug it useless
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90301 is a reply to message #90288] Wed, 18 July 2007 03:46 Go to previous messageGo to next message
Create datastore...
public SessionFactory getSessionFactory() {
if(sessionFactory==null){
PropertyConfigurator.configure("log4j.properties");
// create the HbDataStore
hbds = (HbDataStore)HbHelper.INSTANCE.createRegisterDataStore("mySF ");
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.URL, "jdbc:mysql://localhost/test");
props.setProperty(Environment.PASS, "rootpassword");
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLDialect.class.getName());
props.setProperty(Environment.SHOW_SQL, "true");
// props.setProperty(Environment.HBM2DDL_AUTO, "update");
hbds.setHibernateProperties(props);
// persisence.put(PersistenceOptions.UPDATE_SCHEMA, "true");
// persisence.put(PersistenceOptions.JOIN_COLUMN_NAMING_STRATEG Y,
"unique");
// sets its epackages stored in this datastore
EPackage[] packages = new EPackage[]{_1Package.eINSTANCE,
_0Package.eINSTANCE,
customs.ru.common.aggregate.types._3._0._1._1Package.eINSTAN CE,
customs.ru.common.leaf.types._3._0._1._1Package.eINSTANCE,
customs.ru.esad.common.aggregate.types._3._0._1._1Package.eI NSTANCE,
customs.ru.esad.common.leaf.types._3._0._1._1Package.eINSTAN CE,
customs.ru.information.customs.documents.dt.sout._3._0._1._1 Package.eINSTANCE,
customs.ru.esaddts.common.aggregate.types._3._0._1._1Package .eINSTANCE,
customs.ru.ekts.common.aggregate.types._3._0._1._1Package.eI NSTANCE,
customs.ru.information.customs.documents.kt.sout._3._0._1._1 Package.eINSTANCE};
hbds.setEPackages(packages);
// initialize, also creates the database tables
hbds.initialize();
//take xml mapping into file (for debug)
writeMappingXML();
sessionFactory = hbds.getSessionFactory();
return sessionFactory;
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90331 is a reply to message #90301] Wed, 18 July 2007 05:45 Go to previous messageGo to next message
Thanks, yes I found the ecores.
>> Scale
The scale is read from the annotation meta data (fractionDigits), this should be okay.
>> Different Date mapping
It was the other way around the latest Teneo release now correctly identifies the date types,
therefore it does not use typedef's in the top of the hbm anymore. This also means however that the
mapping to the database has changed (it uses a date column instead of a string column).
>> The Exception
I tested this and the exception was caused by the following bug (or feature):
The latest release of Teneo now also computes the table name for list of primitive types. This table
name computation also does truncation if the name is too long (according to the options).
The problem with truncation logic is that it can result in non-unique naming (as the unique part is
truncated away).
This resulted in a eclass and a list of primitive string to be placed in the same table. You can
search the new hbm for the text table="`dtsadditionalpaymentstype`" and then you will see it appear
twice.
The primitive list causes this table to have two columns in the pk (the id and the idx).
I solved this by changing the truncation logic (there was a bug in it actually which caused it to
truncate away the wrong part). This will be in the next build.
Note that the new join table naming logic for primitive lists means that the generated hbm is not
backward compatible with the old db schema (only if the names are too long). So you need to use
jointable annotations to force Teneo to use the old tablenames (or transfer to a new db-schema).
Btw, the latest Teneo release offers an easier method to extend or override the sql naming strategy
(see extensions on the elver.org website).
gr. Martin
wolf_roma wrote:
> Create datastore...
> "unique");
> hbds.initialize();
> writeMappingXML();
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90362 is a reply to message #90331] Wed, 18 July 2007 06:26 Go to previous messageGo to next message
Thanks.
Where bug fix in next release or next build?
When will the new build be?
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #90425 is a reply to message #90362] Wed, 18 July 2007 07:27 Go to previous message
Build and release is the same for Teneo, I hope to do a new build today, otherwise it will be tomorrow.
gr. Martin
wolf_roma wrote:
> Thanks.
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608762 is a reply to message #90001] Tue, 17 July 2007 07:45 Go to previous message
gr. Martin
> Casused exception:
> code:
> // used earlier
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608763 is a reply to message #90017] Tue, 17 July 2007 08:13 Go to previous message
old hbm.xml:
<class
<meta
</id>
</version>
</property>
</property>
<key update="true">
unique="false"/>
</key>
</list>
<key update="true">
unique="false"/>
</key>
</list>
</class>
<joined-subclass
<meta
</many-to-one>
</joined-subclass>
    (Size: 57.62KB, Downloaded 137 times)
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608764 is a reply to message #90032] Tue, 17 July 2007 08:14 Go to previous message
gr. Martin
> old hbm.xml:
> <class
> <meta
> </id>
> </version>
> </property>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> <joined-subclass
> <meta
> </many-to-one>
> </joined-subclass>
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608765 is a reply to message #90047] Tue, 17 July 2007 08:43 Go to previous message
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608766 is a reply to message #90063] Tue, 17 July 2007 08:47 Go to previous message
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608770 is a reply to message #90077] Tue, 17 July 2007 10:51 Go to previous message
gr. Martin
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608780 is a reply to message #90137] Wed, 18 July 2007 03:42 Go to previous message
Hello.
forum(news).
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608781 is a reply to message #90288] Wed, 18 July 2007 03:46 Go to previous message
Create datastore...
"unique");
hbds.initialize();
writeMappingXML();
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608783 is a reply to message #90301] Wed, 18 July 2007 05:45 Go to previous message
>> Scale
>> The Exception
truncated away).
twice.
gr. Martin
wolf_roma wrote:
> Create datastore...
> "unique");
> hbds.initialize();
> writeMappingXML();
The Netherlands
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608785 is a reply to message #90331] Wed, 18 July 2007 06:26 Go to previous message
Thanks.
Re: [Teneo] PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY [message #608789 is a reply to message #90362] Wed, 18 July 2007 07:27 Go to previous message
gr. Martin
wolf_roma wrote:
> Thanks.
The Netherlands
Previous Topic:problem with initialzing jpoxDataStore(emf+teneo+derby)
Next Topic:Generating JDO outside of ecilpse
Current Time: Wed Nov 05 22:12:33 EST 2025
Powered by FUDForum. Page generated in 0.07394 seconds
