| child of eclipse has socket/dns problems w/ java 1.4.2 [message #89990] |
Mon, 07 July 2003 11:44 |
Originally posted by: pmac.nospam.tensilica.nospam.com
eclipse 2.0.2, win32, jdk 1.4.2
In my plugin I fire off a child app using Runtime.exec(). The child app
checks out a license using flexlm ...
This all works fine with java 1.4.0 and 1.4.1, but fails in 1.4.2 with
errors from the flexlm code along the lines of "winsock could not obtain the
ip addr of the lic server - dns error".
When called from a trivial test app, the same child exec does work ok.
So, eclipse is ok with older javas and java 1.4.2 is ok with trivial apps
.... something in the combination is causing the child application's process
environment to get messed up ...
Any suggestions on where (or how) to look?
TIA
PMac
FUDForum. Page generated in 0.03433 seconds
