Home » Eclipse Projects » Equinox » Specify bundles to install in 3.3RC3
Specify bundles to install in 3.3RC3 [message #89943] Thu, 07 June 2007 05:15 Go to next message
I'd like to develop web applications with Jetty as an OSGi HTTP service. I
provide my Servlet in a bundle and contribute it via plugin.xml. When I
create an OSGi launch configuration I select my bundle and click on "Add
required bundles". That results in 20 selected bundles out of 200. But
when I start the launch config and list the bundles in the console (via ss
command) I see 167 bundles installed, bundles like swt, rcp and ide among
them.
I don't see a way to correctly specify the bundles to install. Formerly
that was possible, I did that many times. Do I miss something?
Cheers
/Eike
Re: Specify bundles to install in 3.3RC3 [message #90003 is a reply to message #89943] Thu, 07 June 2007 15:32 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
If you add 'org.eclipse.update.configurator' it will scan-and-install all bundles in the plugins/ directory. You can get away without this by changing your 'target platform' to be just those set of running bundles if you want.
It shouldn't be an issue in your servlet, because you won't have those plugins in place.
Alex.
Re: Specify bundles to install in 3.3RC3 [message #90033 is a reply to message #90003] Thu, 07 June 2007 16:05 Go to previous message
Originally posted by: stepper.sympedia.de
Alex,
Thank you, the target platform solution works fine.
Cheers
/Eike
> Alex.
Previous Topic:OSGi & DS questions
Next Topic:Initial Provisioning service
Current Time: Fri Nov 14 22:48:07 EST 2025
Powered by FUDForum. Page generated in 0.03972 seconds
