Home » Archived » Visual Editor (VE) » BeanInfo
BeanInfo [message #89633] Wed, 04 May 2005 10:37 Go to next message
I have a beaninfo class Xbeaninfo in the same package as the class X. If I
debug (remote) the class Xbeaninfo the breakpoints in the class will not
be reached. (But If I debug the class comboboxbeaninfo the breakpoints
will be reached. It means the debug process is ok)
In what class in VE I could set the breakpoints to see if my beaninfo
class would be picked up?
Thank you in advance
Elena
Re: BeanInfo [message #89715 is a reply to message #89633] Wed, 04 May 2005 11:32 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
How did you do the debugging? BeanInfo is done in a special remote vm,
the IDE that is doing the debugging needs to have the BeanInfo class in
the project that the remote debugging session is using to do the debugging.
Elena wrote:
> Hello,
> I debug (remote) the class Xbeaninfo the breakpoints in the class will
> not be reached. (But If I debug the class comboboxbeaninfo the
> breakpoints will be reached. It means the debug process is ok)
> Elena
Rich Kulp
Re: BeanInfo [message #89745 is a reply to message #89633] Wed, 04 May 2005 13:11 Go to previous message
Hi Elena,
Assuming that you have used the remote debugger to attach to the correct
VM (which is documented in the Help so I presume you have) the key class
to look at is java.beans.Introspector.
Joe
Re: BeanInfo [message #607337 is a reply to message #89633] Wed, 04 May 2005 11:32 Go to previous message
Elena wrote:
> Hello,
> Elena
Rich Kulp
Re: BeanInfo [message #607339 is a reply to message #89633] Wed, 04 May 2005 13:11 Go to previous message
Hi Elena,
Joe
Previous Topic:Eclipse VE jre 1.5.x problem
Next Topic:PropertyEditor
Current Time: Thu Jul 17 01:21:33 EDT 2025
Powered by FUDForum. Page generated in 0.04338 seconds
