Command Save / Save Action not working ??? [message #89631] |
Fri, 23 May 2008 08:55  |
I added my whole menu through the extension point "org.eclipse.ui.menus".
This way the Save action does not work correctly as it does not have a
handler set. CloseAction and CloseAllAction works properly. I get the Save
to work, if I call
register( ActionFactory.SAVE.create( window ) );
in my ActionBarAdvisor, but that's not a good solution, I think.
Any suggestions, or am I missing something?
Markus
Re: Command Save / Save Action not working ??? [message #89776 is a reply to message #89631] |
Sun, 25 May 2008 13:52  |
Originally posted by: rherrmann.innoopract.com
Markus,
I gave this a quick try, but ended up with the same results as you
did. Maybe you should ask this on the PlatformUI newgroup.
Rüdiger
Markus Krüger wrote:
> to work, if I call
> Markus
FUDForum. Page generated in 0.03661 seconds
