Re: Remove whitespaces from generation [message #8081] |
Wed, 28 March 2007 17:05  |
John,
Please use the M2T newsgroup for JET2 questions. I've added it to the
"to" list so Paul should see your question. He might need more detail
though. Often the goodness of the answer is proportional to the amount
of information provided in the question...
John Slave wrote:
> i am using emft jet generation to create java code however i cannot
> find how to remove whitespaces (these whitespaces are that from used
> tags).
> Thanks in advance
> Tobia Loschiavo
Re: Remove whitespaces from generation [message #9931 is a reply to message #9859] |
Wed, 04 April 2007 08:18   |
Stu:
<c:log>Log here</c:log>
would add a line, while
<c:log>
Log here
</c:log>
will not.
The whitespace/line stripping would have to get smarter about the intent of
individual tags to successfully do the right thing on:
and, and the same time:
<f:lc>Lower Case here</f:lc>
I'll give it some thought. Here's a bugzilla to track it...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180927
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:euqsgl$rhf$1@build.eclipse.org...
>I have all comments on a separate line so it must be something else. I'll
>look more into it and post something with more detail if I can narrow it
>down.
> The <c:log>Log here</c:log>
> Seems to add a blank line is what I have found so far.
> Cheers for all your time.
> Stu
> "Paul Elder" <pelder@ca.ibm.com> wrote in message
> news:euqrei$jfl$1@build.eclipse.org...
>> Stu:
>> No, just put them on a separate line.
>> I'll have another look at the new line trimming algorthim to see if I can
>> make it more friendly with respect to comments. No promises for this
>> release, so it still comes down to, put your comments on a separate line.
>> <%-- Good: do something --%>
>> <c:iterate ... >
>> <c:iterate ...> <%-- Bad: will result in a an unexpected new line --%>
>> Paul
>> news:eugl88$70b$1@build.eclipse.org...
>>>I get the same thing and yes I have comments all over the place trying to
>>>make the text understandable.
>>> Are you saying to remove these ghost blank lines you have to remove all
>>> comments ? Seems a shame.
>>> news:eugbj7$qk8$1@build.eclipse.org...
>>>> John:
>>>> JET2 removes write space when a tag (or other language element) is
>>>> alone on a line.
>>>> Rule of thumb: If you don't want write space associated with a tag, put
>>>> it on its own line.
>>>> So:
>>>> <c:iterate select... >
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> But, if you put a comment on the line
>>>> <c:iterate select... > <%-- a comment --%>
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>> "Ed Merks" <merks@ca.ibm.com> wrote in message
>>>> news:euelal$d3e$1@build.eclipse.org...
>>>>> John,
>>>>> amount of information provided in the question...
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #11416 is a reply to message #9931] |
Thu, 12 April 2007 00:47   |
Originally posted by: evaandoli.dodo.com.au
Ok I got around to finding my problem with a blank line appearing when I
think it shouldnt.
Here is the line that caused trouble:-
PreText1
<c:addTextElement select="$conductorType/valueHolder" name="notFoundName"
var="notFound">NotFound</c:addTextElement>
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
but got the same result.
Stuart
news:ev053l$dvg$1@build.eclipse.org...
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> of individual tags to successfully do the right thing on:
> Paul
>>down.
>> Stu
>>> Stu:
>>> can make it more friendly with respect to comments. No promises for this
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>to make the text understandable.
>>>>> John:
>>>>> alone on a line.
>>>>> put it on its own line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> the "to" list so Paul should see your question. He might need more
>>>>>> detail though. Often the goodness of the answer is proportional to
>>>>>> the amount of information provided in the question...
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #11601 is a reply to message #11416] |
Fri, 13 April 2007 08:17  |
Stu:
Thanks for you persistence. I have filed bug 182311
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=182311). I'll be fixed
shortly.
Paul
news:evkdkp$952$1@build.eclipse.org...
> think it shouldnt.
> PreText1
> PostText1
> Output looks like:
> PreText1
> PostText1
> I tried:-
> var="notFound">
> NotFound
> </c:addTextElement>
> Stuart
FUDForum. Page generated in 0.05068 seconds
