Home » Archived » M2M (model-to-model transformation) » How to use distinct and foreach in called rules?
How to use distinct and foreach in called rules? [message #89594] Tue, 02 September 2008 03:08 Go to next message
I wrote a transformation using a foreach in a called rule and I obtained a
compilation error.
The purpose of the transformation is to generate from one element named
Interface two elements Interface1 and Interface2. The element Interface
defines operations and attributes. Interface1 will contain services
derived from operations and Interface2 the attributes.
See below for the rule I already wrote:
rule System {
from
systemDesign : design!System
to
systemImpl : impl!System(
Name <- systemDesign.Name,
Description <- (systemDesign.defineClassifier->select(i |
i.oclIsTypeOf(design!Interface)).asSequence()).size().toStri ng(),
Components <- systemDesign.defineClassifier->select(c |
c.oclIsTypeOf(design!Package)),
-- One interface defined one interface1 and one interface2 in the
-- implementation model
Interfaces <- interfaces1.append(interfaces2)
interfaces1 : distinct impl!Interface1 foreach(interface in
(systemDesign.defineClassifier->select(e|e.oclIsTypeOf(design!Package)))- >collect(i|i.defineClassifier)->flatten()->asSet())(
Name <- '1'+interface.Name,
services<-thisModule.NewServices(interface)
interfaces2 : distinct impl!Interface2 foreach(interface in
Name <- '2'+interface.Name
rule NewServices (interface :design!Interface)
to
operations : distinct impl!Service foreach(operation in
interface.defineOperation)(
Name <- operation.Name,
Description <- operation.Description
do
operations;
The design metamodel defined Packages that contains Interfaces that
contains Operations. To transform the design model to implementation model
I will transform Interfaces to Interface1 that defines services (one
service for one operation defined in design model) and to Interface2 that
defines attributes.
I try to go threw the Packages, Interfaces and Operations using foreach.
It works fine in the matched rule System but I got a compilation error
with the called rule NewServices.
INFO: Warning, could not find mathing node for ForEachOutPatternElement in
mode calledRuleCreate
mode calledRuleInit
GRAVE: ERROR: no slot reserved for variable: operations used at 68:3-68:13.
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor37.invoke(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
org.eclipse.m2m.atl.engine.vm.InstanceNativeOperation.exec(I nstanceNativeOperation.java:79)
... 131 more
Caused by: java.lang.NullPointerException
org.eclipse.m2m.atl.engine.vm.ASMOperation.addVariableInstru ction(ASMOperation.java:112)
at org.eclipse.m2m.atl.engine.vm.ASMEmitter.emit(ASMEmitter.jav a:128)
... 135 more
What could I do in order not to use distinct foreach in the called rule?
Thanks for your help,
Mel
[ATL]Re: How to use distinct and foreach in called rules? [message #89607 is a reply to message #89594] Tue, 02 September 2008 03:11 Go to previous messageGo to next message
I am sorry I forgot to set the prefix ATL in the title.
Mel
Re: How to use distinct and foreach in called rules? [message #89695 is a reply to message #89594] Tue, 02 September 2008 09:49 Go to previous messageGo to next message
Actually their use is deprecated. You can use lazy rules instead.
I think if you rewrite it with a lazy rule, thinks will be come more clear:
rule System {
from systemDesign : design!System
to systemImpl : impl!System(
Interfaces <-
thisModule.createInterface1(systemDesign.defineClassifier->select(e|e.oclIsTypeOf(design!Package))- >collect(i|i.defineClassifier)->flatten()->asSet())
Interfaces <-
thisModule.createInterface2(systemDesign.defineClassifier->select(e|e.oclIsTypeOf(design!Package))- >collect(i|i.defineClassifier)->flatten()->asSet())
lazy rule createInterface1 {
from systemDesign : design!Package
to systemImpl : impl!Interface1 (
lazy rule createInterface2 {
to systemImpl : impl!Interface2 (
Good luck,
Alfons
"Melb" <melanie.bats@enix.org> schreef in bericht
news:c77ca8eca4a1c01531c72f51eeb5b148$1@www.eclipse.org...
> Hello,
> compilation error.
> rule System {
> -- One interface defined one interface1 and one interface2 in the --
> to
> do
> operations; }
> defines attributes.
> mode calledRuleInit
> 68:3-68:13.
> GRAVE: exception: GRAVE: null
> at
> ... 131 more
> at
> ... 135 more
> Mel
[ATL] Re: How to use distinct and foreach in called rules? [message #89710 is a reply to message #89695] Tue, 02 September 2008 11:43 Go to previous messageGo to next message
Hi Alfons,
It seems that I am a little bit lost with lazy rules...
My source model looks like this:
System
Package 1
Interface 1.1
Attribute 1.1.1
Operation 1.1.1
Operation 1.1.2
Interface 1.2
Operation 1.2.1
Package 2
Interface 2.1
Operation 2.1.1
My target model would be defined as following:
System
CSInterface 1.1
Service 1.1.1
Service 1.1.2
SRInterface 1.1
Attribute 1.1.1
CSInterface 1.2
Service 1.2.1
CSInterface 2.1
Service 2.1.1
The transformation algorithm will be :
1 - For each Package in source I have to get the Interface elements
defined.
2 - After that, for each Interface I need to create two elements,
CSInterface and SRInterface, in target.
3 - Then for each CSInterface I need to get the corresponding operations
in Interface in order to create the
Service elements.
Here the rule I tried to write:
rule System {
from
to
Interfaces <-
(systemDesign.defineClassifier->select(package|package.oclIsTypeOf(design!Package)))
-- Get the Packages
-> collect(package|thisModule.CreateCSInterfaces(package.define Classifier))
-- Create the CSInterfaces for each Package
lazy rule CreateCSInterfaces {
from
interfaces : Sequence(design!Interface) ???
to
CSInterfaces : Sequence(impl!Interface) ???
I don't know how to write the lazy rule to iterate over the interfaces?
How to iterate without using foreach statement?
Do you have an idea?
Mel
Re: How to use distinct and foreach in called rules? [message #89726 is a reply to message #89695] Tue, 02 September 2008 13:34 Go to previous messageGo to next message
My example may have confused you. It;s incorrect sorry.
You can define two lazy rules accepting one input element and producing one
target element. Then you can call the iteratively:
Interfaces <- collection_source_elements->collect(i |
thisModule.createInterface1(i) );
thisModule.createInterface2(i) );
Alfons
"Alfons Laarman" <a.w.laarman@student.utwente.nl> schreef in bericht
news:g9jg92$21n$1@build.eclipse.org...
> Hello,
> clear:
> rule System {
> Interfaces <-
> Interfaces <-
> Good luck,
> Alfons
>> Hello,
>> a compilation error.
>> rule System {
>> to
>> do
>> operations; }
>> model I will transform Interfaces to Interface1 that defines services
>> (one service for one operation defined in design model) and to Interface2
>> that defines attributes.
>> in mode calledRuleCreate
>> in mode calledRuleInit
>> 68:3-68:13.
>> at
>> ... 131 more
>> at
>> ... 135 more
>> Mel
[ATL] Re: How to use distinct and foreach in called rules? [message #89800 is a reply to message #89726] Wed, 03 September 2008 04:32 Go to previous message
Hello Alfons,
Ok now it's clear. I succeed to replace foreach statement by lazy rules.
Now, my rule is defined as following :
-- IsCSInterface : An interface is a client server interface when there is
an operation with role defined to none
helper context design!Interface def: isCSInterface() : Boolean =
if self.defineOperation->exists(i|i.oclIsTypeOf(design!Operation) and
i.Role =#none) then
true
else
false
endif;
-- IsSRInterface : An interface is a sender receiver interface when there
is an operation with role defined to read or write
helper context design!Interface def: isSRInterface() : Boolean =
(i.Role =#read or i.Role =#write)) then
true
else
false
endif;
rule System {
from
to
-- One interface defined one CS interface and one SR interface in the
Interfaces <-
(systemDesign.defineClassifier->select(package|package.oclIsTypeOf(design!Package)))- >collect(package|package.defineClassifier-> collect(interface|thisModule.CreateCSInterface(interface))). append((systemDesign.defineClassifier- >select(package|package.oclIsTypeOf(design!Package)))->collect(package|package.defineClassifier- > collect(interface|thisModule.CreateSRInterface(interface)))) )
lazy rule CreateCSInterface{
from
interface : design!Interface(interface.isCSInterface())
to
CSInterface: impl!CSInterface(
Name <- 'CS' + interface.Name,
services<-
interface.defineOperation->collect(operation|thisModule.CreateService(operation)))
lazy rule CreateSRInterface{
from
interface : design!Interface(interface.isSRInterface())
to
SRInterface: impl!SRInterface(
Name <- 'SR' + interface.Name)
I want to create a CSInterface in implementation model if there are
operations defined in Interface in design model. So I defined an helper
isCSInterface that checks if the interface defines operations. Then I use
this helper in the lazy rule :
from
I did the same for SRInterface if attributes exists in interface in design
model.
But nothing change, both CSInterface and CSInterface are always created.
I am sure that the helper works as I already test it in a matched rule.
So is it possible to use helpers in lazy rule? If not how could I obtained
the expected behaviour?
Mel
Previous Topic:[UML2 to UML2] Add Classes to a UML2 model via ATL
Next Topic:[ATL] rule for abstract metaclass
Current Time: Fri Nov 07 04:46:51 EST 2025
Powered by FUDForum. Page generated in 0.03484 seconds
