Home » Archived » Visual Editor (VE) » Eclipse VE jre 1.5.x problem
Eclipse VE jre 1.5.x problem [message #89532] Wed, 04 May 2005 02:05 Go to next message
Originally posted by: akan.aiqa.com
Does Eclipse VE 1.1M1 has a problem with JRE 1.5.0 or 1.5.0_02 ?
thanks,
aiQa
Re: Eclipse VE jre 1.5.x problem [message #89548 is a reply to message #89532] Wed, 04 May 2005 03:17 Go to previous messageGo to next message
> thanks,
> aiQa
Finally I start to use Eclipse VE 1.1M1 with JRE 1.5.0_02 there seems to
be no problem now. The reason was a component which I have installed
before. After removing that component everything started to work fine.
aiQa
Re: Eclipse VE jre 1.5.x problem [message #89685 is a reply to message #89548] Wed, 04 May 2005 11:27 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Is this component one of yours, or is it available from somewhere else?
We would like to know what can cause conflicts with the VE so we can
either fix it or warn people about it?
> aiQa
Rich Kulp
Re: Eclipse VE jre 1.5.x problem [message #607326 is a reply to message #89532] Wed, 04 May 2005 03:17 Go to previous message
> thanks,
> aiQa
aiQa
Re: Eclipse VE jre 1.5.x problem [message #607335 is a reply to message #89548] Wed, 04 May 2005 11:27 Go to previous message
> aiQa
Rich Kulp
Previous Topic:PropertyEditor
Next Topic:BeanInfo
Current Time: Tue Nov 04 17:29:27 EST 2025
Powered by FUDForum. Page generated in 0.04545 seconds
