| roundtrip editor, possible? [message #89500] |
Thu, 04 January 2007 14:22  |
Originally posted by: tiggo.kan.gmail.com
Hi all, I'm really puzzle about the possibility of roundtrip on
generated editor. My semantic model(ecore) is transformed from a schema.
Also someone tell me that, there is a conflict between MDD and
roundtrip... thanks.
/tiggo
| Re: roundtrip editor, possible? [message #90966 is a reply to message #89580] |
Tue, 09 January 2007 11:41  |
Thanks Alex, I will have a look on the 2.0M4 right now.
To a "roundtrip" needs, besides function properly and reverse
seamlessly, fault-tolerance is also important. Hope GMF team can pay
more attention on it.
Alex Shatalin wrote:
> Hello tiggo,
> If you roundtrip is <change .xml file> -> <diagram updated> / <change
> diagram> -> <XML file updated> then in past GMF had some problems with
> diagram content synchronization (you had to reopen the diagram).
> Currently (2.0 stream) all tehse problems are solved.
> Alex Shatalin
FUDForum. Page generated in 0.03997 seconds
