Home » Eclipse Projects » Remote Application Platform (RAP) » Label.computeSize
Label.computeSize [message #89378] Thu, 22 May 2008 06:43 Go to next message
I have a ScrolledComposite that contains a label. When pack() is called
on the label (whenever the text changes) the label is given a width,
greater than the ScrolledComposites width, thereby cutting of the last of
the text in the line.
On looking into this I see the Label.computeSize estimates the width but
does not ensure that the width is less than or equal to the width of the
parent.
Is this correct behaviour?
Cheers
Paul
Re: Label.computeSize [message #89407 is a reply to message #89378] Thu, 22 May 2008 07:03 Go to previous message
Originally posted by: rherrmann.innoopract.com
Paul,
I am pretty sure that this is correct behavior. If you have doubts,
you could create the same scenario in SWT and see how it behaves.
Rüdiger
> of the text in the line.
> parent.
> Cheers
> Paul
Previous Topic:Combo problem about setvisibleCount
Next Topic:Truncated table header texts
Current Time: Sun Nov 09 00:10:02 EST 2025
Powered by FUDForum. Page generated in 0.03702 seconds
