Home » Eclipse Projects » Subversive » subversive will not install
subversive will not install [message #8063] Sat, 14 July 2007 08:48 Go to next message
Originally posted by: hansm.science.uva.nlDELETE
Installed Eclipse 3.3
Downloaded Subversive_1.1.3-LocalUpdateSite.zip
Got following error message on installing in eclipse through the installer:
Subversive Integration for the CSC Project Set Project (Optional) (1.0.4)
requires feature "com.csc.dip.projectset.feature".
What is this? I cannot imagine the full eclipse 3.3 download (rcp version) is
incomplete. So is this subversive localupdatesite.zip incomplete? Why then?
I have worked with subversive before on older eclipse versions, but if it now
will not install I have no choice but to drop its usage.
Hans van der Meer
Re: subversive will not install [message #8157 is a reply to message #8063] Mon, 16 July 2007 05:27 Go to previous messageGo to next message
Dear Hans,
Project Set integration is an optional feature, which you can install only
if you use CSC Project Set plugin. You can find detailed information for all
features in Subversive installation if you select feature in the Updates
dialog. Then under the tree you will see description text. For CSC Project
Set Project it looks like "Integration with ProjectSet
(http://vpms.de.csc.com/projectset/). Installation is possible only if
ProjectSet is already installed or installed in one step with Subversive."
Igor Vinnykov
Subversive Team
"dr. Hans van der Meer" <hansm@science.uva.nlDELETE>
Re: subversive will not install [message #8221 is a reply to message #8157] Mon, 16 July 2007 10:53 Go to previous messageGo to next message
In article <f7fdm8$lvd$1@build.eclipse.org>,
"Igor Vinnykov" <igor.vinnykov@polarion.org> wrote:
> Dear Hans,
> Best regards,
> Igor Vinnykov
> Subversive Team
I do not completely understand the answer. Does it mean that I do need to have
the CSC Project Set plugin also, in order to be able to install and work with
subversive under eclipse 3.3?
As for the installation of javaHL for MacOSX, I did reply to your 1.1.3 release
announcement: I cannot find on the subversion site how to acquire the necessary
javaHL.
Hans van der Meer
Re: subversive will not install [message #8284 is a reply to message #8221] Wed, 18 July 2007 05:12 Go to previous messageGo to next message
Dear Hans,
Like I mentioned in the post - Subversive Project Set integration is an
optional feature, which should be installed only if you use CSC Project Set
plugin and want to have it integrated with Subversive. I all other cases you
don't need to install this instagretion. It doesn't have influence to the
Subversive functionality.
Igor Vinnykov
Re: subversive will not install [message #8316 is a reply to message #8284] Wed, 18 July 2007 08:19 Go to previous message
Thanks Igor.
Just now I found out that the install has several subitems and then found the
one that must be disabled in order to remove the error message. Glad to here
noninstalling that option does not restrict svn usage. However, could you
consider some explaining comment about this in the install dialog? Perhaps
others like me do not suspect that deselecting a subfeature will make the evil
looking error message go away and, like me, might be intimidated by it.
As for the javaHL problem I encountered: downloading and installing svnkit as
eclipse plugin from its homesite and selecting it in the eclipse team-svn
preferences solved that.
Hans van der Meer
In article <f7kli7$8j4$1@build.eclipse.org>,
> Dear Hans,
> Best regards,
> Igor Vinnykov
Previous Topic:Announcement: Subversive 1.1.3 release
Next Topic:Any news on a release to support Mylin?
Current Time: Sun Nov 09 10:38:55 EST 2025
Powered by FUDForum. Page generated in 0.05670 seconds
