Home » Archived » Visual Editor (VE) » tree cannot be painted in the VE
tree cannot be painted in the VE [message #89099] Sun, 01 May 2005 19:36 Go to next message
Originally posted by: tischercd.hotmail.com
For create my tree and change the default code in
getJTree-Method: jTree = new JTree()
to the following: jTree = new JTree(rootNode);
the tree cannot be painted in the VISUAL EDITOR!
Can you explain this with code sample?
thanks
// Java Code
import javax.swing.JFrame;
import javax.swing.JTree;
import javax.swing.tree.*;
public class visual extends JFrame {
private javax.swing.JPanel jContentPane = null;
private JTree jTree = null;
private JTree getJTree() {
if (jTree == null) {
TreeNode rootNode = createNodes();
return jTree;
private TreeNode createNodes() {
DefaultMutableTreeNode root;
DefaultMutableTreeNode grandparent;
DefaultMutableTreeNode parent;
DefaultMutableTreeNode child;
root = new DefaultMutableTreeNode("San Francisco");
grandparent = new DefaultMutableTreeNode("Potrero Hill");
root.add(grandparent);
parent = new DefaultMutableTreeNode("Restaurants");
grandparent.add(parent);
child = new DefaultMutableTreeNode("Thai Barbeque");
parent.add(child);
child = new DefaultMutableTreeNode("Goat Hill Pizza");
parent.add(child);
return root;
visual application = new visual();
application.show();
public visual() {
super();
initialize();
private void initialize() {
this.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLO SE);
this.setSize(300,200);
this.setContentPane(getJContentPane());
this.setTitle("Application");
private javax.swing.JPanel getJContentPane() {
if(jContentPane == null) {
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
jContentPane.add(getJTree(), java.awt.BorderLayout.CENTER);
return jContentPane;
Re: tree cannot be painted in the VE [message #89129 is a reply to message #89099] Sun, 01 May 2005 22:29 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Tischer wrote:
> For create my tree and change the default code in getJTree-Method:
> jTree = new JTree()
Tischer,
The Visual Editor can not visually model classes that are instantiated
with a parameter. The Swing support is based on the Java Beans spec,
which stipulates that classes should have a no-argument constructor, and
any properties of the class are set using set methods.
You can get around the problem in your code this way:
private DefaultTreeModel getDefaultTreeModel() {
if (defaultTreeModel == null) {
defaultTreeModel = new DefaultTreeModel();
defaultTreeModel.setRoot(createNodes());
return defaultTreeModel;
jTree = new JTree();
jTree.setModel(getDefaultTreeModel());
return jTree;
The tree still won't show the nodes, but at least it'll show up in the
design view. This is because VE won't execute the createNodes() method
at design time.
Hope this helps,
- Jeff
Re: tree cannot be painted in the VE [message #89144 is a reply to message #89129] Mon, 02 May 2005 05:47 Go to previous messageGo to next message
Originally posted by: leafy.nospam.com.tw
"Jeff Myers" <myersj@nospam.gmail.com>
???????:d543eo$b86$1@news.eclipse.org...
> Tischer,
Is there any plan to overcome this subtlety? Likewise, VE cannot process
anonymous inner classes, so something like:
new JTable(){
public void isCellEditable(){
return false;
will fail for VE.
Jiawei Ye
Re: tree cannot be painted in the VE [message #89159 is a reply to message #89144] Mon, 02 May 2005 05:48 Go to previous messageGo to next message
My bad, the 'void' should read 'boolean'
"Jiawei Ye" <leafy@nospam.com.tw>
Re: tree cannot be painted in the VE [message #89175 is a reply to message #89099] Mon, 02 May 2005 10:06 Go to previous message
--------------080801050000020007030400
> return jTree;
> parent.add(child);
> parent.add(child);
> return root;
There are two problem with: jTree = new JTree(rootNode);
1. rootNode is a TreeNode, and by default VE does not model it (as it is considered as a none visual).
In the future this restriction is going to be lifted, and VE will model any none visual that is referred to by a
visual component.
To model the TreeNode, make tree view an instance variable with the following comment:
private TreeNode rootNode = null; // @jve:decl-index=0:visual-constraint=""
The comment will force VE to model jTreeNode
2. rootNode = createNodes();
The createNodes() is defined in the same class you are editing; VE will not be able to model/drive this on the
target VM. If you create a Static utility to create the rootNode:
rootNode = SomeFactory.StaticCreateRootNode();
VE should be able to create your jTree
Content-Type: image/jpeg;
name="scrape.jpg"
Content-Disposition: inline;
filename="scrape.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcH Bw8LCwkMEQ8S
EhEPERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcG Bw4ICA4eFBEU
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh7/wAAR
CAIJAo8DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD6mooorhNQooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA8W/4aF0P/oXtT/7 +J/jR/w0Lof/
AEL2p/8AfxP8a8ctPCWv3lvbXNpoWp3EF05S3kitHZZmAYlUIGGICMSB/dPo arxeH9Tl0uXV
YtNvJNPhfZLdLAxhRuPlZ8YB+ZeCe49a/YP9UclvbX/wI+D/ALdx/wDSPa/+ GhdD/wChe1P/
AL+J/jR/w0Lof/Qvan/38T/GvGLLw9eX8Vqun2OoXd1cTSxpFDalw+xVY7CC SzAMSy4+UbTk
7uI28P6mtwls2m3gnkuGtUjMDbmmUgNEBjJcFlBXqNw9aP8AVDJr21/8CD+3 sfa+n3Htf/DQ
uh/9C9qf/fxP8aP+GhdD/wChe1P/AL+J/jXikvh/U4tLi1WXTbyPT5n2RXTQ MIXbn5VfGCfl
bgHsfSk0jTbO41S1g1C6NnaSSqk1wIy/lITgvtHLYHOB1xSqcI5PCnKpaTUb 7O706evkOOe4
6UlG6V+67nvOk/Hjw9fTiGWwnsSWVVa5kwpycZyqtgDuTivQNF17+2rUXWkv pV5Cc4aK+Y9D
j/nn6g14PrPwcfQ7HVtY1jX7GHRIIg+l3cREh1J2G6NEUHK5HU846jcoLDiv DGr6x4av/tuj
3kltIcBwPuyAHOGHp+vJ9a+flwxgMxhOeWVHeNvi+HXpe17997HqLOMThJRj jILW+2/rb/hj
688zVf8Anysv/Atv/jdHmar/AM+Vl/4Ft/8AG6wPhv42sfF+lh1xBfxAC4ty eQfUeoNdZXwt
ehUw9R0qqtJbo+jpVYVYKcHdMpeZqv8Az5WX/gW3/wAbo8zVf+fKy/8AAtv/ AI3XMeP9RuH8
R+GNC0q/vIb2TVIpLuO1LBvsxVtzNxtKjGSDkcciug1BdR0W+ike4uNR02Ux xSPN5QkikeTY
pGxVyuWXIIPXIPGCq9KVGEZtOz/AdKaqSlFdCfzNV/58rL/wLb/43R5mq/8A PlZf+Bbf/G6d
rMmpxabLJo9pZ3l8MeVDd3TW8TcjO6RY5CuBkjCHJAHGcjnPBPjL+1fBmieI vEsekeHv7e+z
nTYP7U83zvPjV4o9zxx5mOWHlqG+7wT2zsWdD5mq/wDPlZf+Bbf/ABujzNV/ 58rL/wAC2/8A
jdVbfxR4Zuf7V+z+ItIm/sfd/anl3sbfYdu7d52D+7xsfO7GNrehrCvPiPoc fibwtptlJDqe
m+I47sw6tZ3KS20LwvDGquwO3DySiIEHPmFEwS/BZgdP5mq/8+Vl/wCBbf8A xujzNV/58rL/
AMC2/wDjdYll440NPDsmt+INQ07w/arqt7pqSX16kaO9vczQjDvtGWEJfb1A yOcZo8a+OND8
MXVjps+oac+sX15ZW9vpr3qR3EiXF0kBlVDlmC7nbgYPlkZHJBZgbfmar/z5 WX/gW3/xujzN
V/58rL/wLb/43Uek69oer3t9ZaVrWnX91p8nlXsNtdJK9s+WG2RVJKHKsMHB yp9DWR4u8caH
oWl+I3g1DTtQ1jQdKn1K40lL1BcbI4vMG5RlkByg3FcfODzkZLAbfmar/wA+ Vl/4Ft/8bo8z
Vf8Anysv/Atv/jdR2+vaHca/ceH4Na06XWLaMS3Fgl0jXESHaQzRg7lHzpyR j5h6ioYfFHhm
bTbDU4fEWkSWOo3AtbG5W9jMV1MSVEUbZw7kqw2qScqR2oAteZqv/PlZf+Bb f/G6PM1X/nys
v/Atv/jdXaKAKXmar/z5WX/gW3/xuo7W71O4jMiWNoAHdObtuqsVP/LP1FaN UtHIWxlZjgC4
uCT6ASvQlfQA8zVf+fKy/wDAtv8A43R5mq/8+Vl/4Ft/8brmPAUt34l8T+K7 6HW9VTSBcwLY
PHgxEeV84QSowGDjO0Dk810Oi3N/5sum6rEFvLeNJDIpXEqOWCtgdGyjZHTo RjOBeIpuhU9n
JfPpte3/AA/YijNVYc6/rWxN5mq/8+Vl/wCBbf8AxujzNV/58rL/AMC2/wDj dVbTWvP8Z6l4
d+zbfsOnWl75/mZ3+fJcpt2442/Zs5yc7+gxzyLePfE13pPgnU9H8LaRPD4s t4WiW71uSBre
Z7SW6KNttnDIEiIDggliBtA5qbFnceZqv/PlZf8AgW3/AMbo8zVf+fKy/wDA tv8A43XPW3j/
AET+1fG9jfyfY/8AhDvKlv3w8n+jParcCbAX/rqu1dx/dZ/iAo+H/jX/AISz 7N/xLfsfn+Ht
M1r/AF/mbftnn/uvujOzyPvfxbugxyWYHQ+Zqv8Az5WX/gW3/wAbo8zVf+fK y/8AAtv/AI3X
JaR451OaR7/VNBs7PQG1mfR4L2DUWmnEyXj2kbSwmFQiSSqFyjyFTImRt3un U2+vaHca/ceH
4Na06XWLaMS3Fgl0jXESHaQzRg7lHzpyRj5h6ilYCTzNV/58rL/wLb/43R5m q/8APlZf+Bbf
/G6q6N4o8M61BFcaP4i0jUYZrg2sUlpexyq8wjMhiUqSC4QFyo52gnpUN14y 8IWt79iufFeh
QXXlzS+TJqESvshMglbaWzhDFKGPRTG+cbTgsBoeZqv/AD5WX/gW3/xujzNV /wCfKy/8C2/+
N1VuPFHhm2/sr7R4i0iH+2Nv9l+Zexr9u3bdvk5P7zO9Mbc53L6iqmu+NvDO k6bq122rWd5N
pWnXOo3FlaXEclyYbcuspWPcDw6NGScAOCpIINFgNXzNV/58rL/wLb/43R5m q/8APlZf+Bbf
/G65JfiXplx49sfDWlafeatZ3Fu8suq2RWWCF8WrIAqku6FL2BjIoKqJUOSo laLIsfinqa+D
D4i1jwxZ232nwtceJdNgtdUafzYYI4neOZmgTynPnxAbRIPv5I2jc+Viueie Zqv/AD5WX/gW
3/xujzNV/wCfKy/8C2/+N1Hb69odxr9x4fg1rTpdYtoxLcWCXSNcRIdpDNGD uUfOnJGPmHqK
yF8caHe3GhDw/qGna7a6rqr6a9zY3qSpbutpPcnJTcCcQgbcg4cH2KsM2/M1 X/nysv8AwLb/
AON0eZqv/PlZf+Bbf/G65i78Wa5feJpNK8IaRoWsWselWmpG9udae3SRLl51 j8vy7eUOMW5b
dkAhhjPWrjeONDsrjXR4g1DTtCtdK1VNNS5vr1IkuHa0guRgvtAOJiNuScIT 7B2YG35mq/8A
PlZf+Bbf/G6PM1X/AJ8rL/wLb/43V2ikBS8zVf8Anysv/Atv/jdHmar/AM+V l/4Ft/8AG6u0
UAZ13d6nbWk1zJY2hSJGdgt22SAM8fu6k8zVf+fKy/8AAtv/AI3Rr3/IDv8A /r2k/wDQTS63
qNppOlT399cC3hRdvmEE4Y8L0561UIOclFdSZSUVdieZqv8Az5WX/gW3/wAb o8zVf+fKy/8A
Atv/AI3XN/Dyx8R3Pwy0rUJtW1NtWeHzDDebGD/vDjeXXeQUwfvjjoRxXT6V eG+shO8JgkDv
FJGWDbXRyjAEdRuU4PcelKrF0qrpNbdej1sFN89NTXUZ5mq/8+Vl/wCBbf8A xujzNV/58rL/
AMC2/wDjdclpHjnU5pHv9U0Gzs9AbWZ9HgvYNRaacTJePaRtLCYVCJJKoXKP IVMiZG3e6bHi
Hxt4Z0WDXfO1azub7Q9Ol1G+022uI3vEhjjDk+VuBGQVwWwPmXnmizKNXzNV /wCfKy/8C2/+
N0eZqv8Az5WX/gW3/wAbrP0zxVodzLpOnz65oS6xqdml3b2VvqSTGdGQsXhz taWP5XIcKAQp
OByBF4j8XaZpelabfWlxZ6h/aVxZpaJFdL++huLq3tzOhGd6L9pjbI4OVGRu BpWA1fM1X/ny
sv8AwLb/AON0eZqv/PlZf+Bbf/G65LwN8T/D/jDxDa6VpTZ+2+HrfXrRi4Zn jeaSKWNguUR4
nRFYbydzkY+QmtL4c+N9I8beHbPWdPmhSO/kvDZRmT57i3t7loPOCsFbB/ds QR8pkVTzjLaa
Ebfmar/z5WX/AIFt/wDG6PM1X/nysv8AwLb/AON1iWPxB8IXS63Kdf063tdF kt1urqe8iSHZ
cQxSwyh92PLcShVY4DMrAZxkwr8Q/DI8Zp4duNZ0i3+16dZXulzyajGP7R+0 yToqwqT8+PJQ
gqWz5q8DjJZjOh8zVf8Anysv/Atv/jdHmar/AM+Vl/4Ft/8AG6xNH8caHcW9 udV1DTtHurzV
b7TbK2ub1Fe6e2u3tv3YbaXLFFO0AkFwOeCYdM8ReJrn4iX/AIZufD+kQ2Nl bxXb3seryPK0
Mz3CQkQm3Ubybc7l8zChhhn6UrCOh8zVf+fKy/8AAtv/AI3R5mq/8+Vl/wCB bf8Axus9PGXh
B4tMlTxXoTR6tI0WmuNQiIvXVwhWE7v3hDEKQuTkgdaqeLvHGh6FpfiN4NQ0 7UNY0HSp9SuN
JS9QXGyOLzBuUZZAcoNxXHzg85GSzGbfmar/AM+Vl/4Ft/8AG6PM1X/nysv/ AALb/wCN1iaH
4zttY1TQbW0spkj1fSru/YzsFltHt5baN7eSMZxIrXDK43ZRomUgnpbt/GXh C40C48QQeK9C
l0e2kEVxfpqETW8TnaArSBtqn504Jz8w9RRYDQ8zVf8Anysv/Atv/jdHmar/ AM+Vl/4Ft/8A
G6z/AAJ4ktvFvh3+27IQm1e8vLeGSGcTJMkFzLCsquBghxGHGMgBsZPU7tAF LzNV/wCfKy/8
C2/+N0eZqv8Az5WX/gW3/wAbq7RQBnTXepxSQRtY2hMzlFxdtwdrNz+79FNS eZqv/PlZf+Bb
f/G6NR/4/NN/6+W/9EyVHq0az6ho9pLJOkM94ySCKZ4iwEEzAblIOMqD17VM m1sNK5J5mq/8
+Vl/4Ft/8bo8zVf+fKy/8C2/+N1zUmoSR6x4i/smKaFPDeDcrc6jNOt4jRCT AV87CMEAg9cd
sg7fjbWv+Eb8Ga34i+zfav7K064vfI8zZ5vlRs+3dg7c7cZwcZ6GqcZwm4TV np+JKlGUVKLu
v8i15mq/8+Vl/wCBbf8AxujzNV/58rL/AMC2/wDjdZVrrmp6Zpt7qfjuHw54 dsbfy9tzHrTT
RfMdp8xpYIQnJQDlslsccZt3Hijwzbf2V9o8RaRD/bG3+y/MvY1+3btu3ycn 95nemNuc7l9R
RYZa8zVf+fKy/wDAtv8A43R5mq/8+Vl/4Ft/8brEtviD4QfSLrVb3X9O0q1t NVudJme/vIoQ
lzBI6NGSWwCwQuqk7ijK2BmtdNe0N9Xl0dNa05tSikSKSzF0hmR3jaVFKZ3A tGjuBjJVWI4B
NFgJPM1X/nysv/Atv/jdHmar/wA+Vl/4Ft/8bqNtWtpF0ieyu9OuLXU5AIZT dgCZDC8qtBgE
TEhAcAgbN75O3Bh0bxR4Z1qCK40fxFpGowzXBtYpLS9jlV5hGZDEpUkFwgLl RztBPSgC15mq
/wDPlZf+Bbf/ABujzNV/58rL/wAC2/8AjdVbrxR4ZtJ7K3uvEWkQTX9xJa2c cl7GrXEySeW8
UYJy7q52FRkhuDzWvQB88eKvEen6tPqskFvdqLyymt496KMM+pm7BOGPGw4/ 3uOnNW9e8X2e
oLfS26z28j/bYoYzp1s7yR3Esz5Nw2ZIuJyCigg7ThgXJV//AArrxV/0Cf8A yYi/+Ko/4V14
q/6BP/kxF/8AFV+xLEZUkl7aOjv8Ueu5+duGYXb9nLX+6zM0q40Wx0Czhlbz 1S/vjDI9pFPJ
AGS02ytbu2xtyo6YZsAksCSgqXUvE9vJqF9PbRPIFt7c6dI9skTQXKW6W7SK iNtiBUM42dHi
gPRMVe/4V14q/wCgT/5MRf8AxVH/AArrxV/0Cf8AyYi/+KqvreWOXNKvF7/a j1d/66eWrF7L
HWsqUlt0fRWMn+1dHTwfe6ZbwPBPdWUVv5K6dDgOssTvI11u81wxjZthGFLh RwoNcvp8FvBq
FtPd2n2u3jlVpYPMKeagILJuHK5GRkdM133/AArrxV/0Cf8AyYi/+Ko/4V14 q/6BP/kxF/8A
FVoswy5U5wVePvXv7yvqrb9/PfzIeHxrlGTpP3f7r9f6WwzW/iNd63p2qaRq uhWE2kTxBdNs
4wI/7NdRiN0ZVy2B1BxnoNqkqfPfsftXov8AwrrxV/0Cf/JiL/4qj/hXXir/ AKBP/kxF/wDF
VjgcRlOA5lQrRSdtOdW0677vr3NMVDMMVZ1acm1f7L6/L7jh9Eub7RtSi1DT pmhniOQR0I9D
6ivoXwJ4207xHaxRSSLb6jj54CepHUr6ivM0+HHit3CrpGSTgf6RF/8AFU+H 4deL0vY4YdNx
cMjSLsvIc7QQCch+PvD868/O6GV5rFS9vCM1s+Zfc9dvyOvLa2OwLt7KTi+l n960O8+Kt9c2
htUtdQ+xyS2sg/4/FtmkQXNoZY45GZQsjRCUKdykE5yvUctJqOsz2UtrJ4mg 1C7n0vRYDHba
xGWnuknP2sQjeNkjpgBxs5KncuMjoNG074tacwD6f9sizkpPcwnPGMZ35A+l bHn/ABN/6FKy
/wDAuP8A+OV8V/Z+Iw94QlTku/PH9Wn07H0yxtKraUozj5csv0TNrw1FqcHh zTINanWfVI7S
JL2VTkSTBAHYcDgtk9BXK6F4O1Ow8NfDXTJp7NpvC3k/bmV2KybNNntT5fy5 PzyqfmC/KCev
B0PP+Jv/AEKVl/4Fx/8Axyjz/ib/ANClZf8AgXH/APHK5HlmIbbvH/wOH/yR ssbS7S/8Bl/k
ed6d8HNSi8OxaTM8Ik0uztrWyuj4h1GZ7wQXNtPwGIXThJ9kQEQiUoXUq2Ig JN3w78MnTWY7
7WbSzS3nt74XcCaveXs6zStp/kyC6nIkZ1FjuEi+UYz5QQEoZD0/n/E3/oUr L/wLj/8AjlHn
/E3/AKFKy/8AAuP/AOOU/wCzcT3j/wCBw/8Akg+u0u0v/AJf5HMeFvBfjPwx Y6JfLd6R4i1y
w/tiG6a5mexiulvr5brz9yRSbHHlKDEE25kbD4Qbqml/DjxNoOjWnhfTJdI1 DSzqOi3tzf3F
zJbzx/YFsY2VIFjkV962IYEyrgy4x8u5uy8/4m/9ClZf+Bcf/wAco8/4m/8A QpWX/gXH/wDH
KP7MxHeP/gcP/kg+u0u0v/AZf5HMfDH4f6t4PnsWa3s7ltL05NKt7mbX765a 4hMkHmSrFKDF
afJAG8mNXDNsQSRqmWNd8DeJr7wp4g8IwweHHsbv+2Lix1G5kke4E18LkhfK 8vEGw3TIZVeQ
sisNg8z5On8/4m/9ClZf+Bcf/wAco8/4m/8AQpWX/gXH/wDHKX9mYjvH/wAD h/8AJB9dpdpf
+AS/yOS1v4f+KNW8ZwX17Lp17Zw3l7Obi/1O6nikhmtLmCKBtL2i3AQTxozL IGkWNmJDSMKm
l8DeJp9GtleDw59ve4mW4aeSS5dbaRY4yk07Rg36eVEI3iljjMiiHMqyQLO/ T+f8Tf8AoUrL
/wAC4/8A45R5/wATf+hSsv8AwLj/APjlH9mYjvH/AMDh/wDJB9dpdpf+Ay/y OqorlfP+Jv8A
0KVl/wCBcf8A8co8/wCJv/QpWX/gXH/8cpf2ViO8f/A4f/JD+vUu0v8AwCX+ R1VU9F/49H/6
+Z//AEc9YPn/ABN/6FKy/wDAuP8A+OVFa/8ACyreMxp4TtCC7vzeR9WYsf4/ U0f2ViO8f/A4
f/JB9epdpf8AgEv8jl/7Xv08cw7vElva6XDJex3ML6qkO0mW9DBoy4YszPaM rYO0RvgrnDv8
Bt4mvte8Myf2wL2Gx0W1i1lk1FJx5vl3IdZCrHzHaQwMrfNgRycruxJ1Xn/E 3/oUrL/wLj/+
OUef8Tf+hSsv/AuP/wCOV0RweKVNU/cslb44drfzGbxNFy5ve/8AAZf/ACJV 1b4faHr3j+/8
QeJdA0LWrWTSrOztEvrNLh4XilunlIDqQoYTRdDklTkDAzDoXg7U7Dw18NdM mns2m8LeT9uZ
XYrJs02e1Pl/Lk/PKp+YL8oJ68HQ8/4m/wDQpWX/AIFx/wDxyjz/AIm/9ClZ f+Bcf/xysP7M
xHeP/gcP/kjT69S7S/8AAJf5GVL8Oo77xneeINQmh2trqahEibyZLdbSyURN yAhF1Y282Ruy
IQvSRxWb4S8LeOfB/wDZn9maf4c1XyvC2k6Pc/aNWmtdk1n9o3Mm22k3I3nj BO0/L05rp/P+
Jv8A0KVl/wCBcf8A8co8/wCJv/QpWX/gXH/8co/szEd4/wDgcP8A5IPrtLtL /wAAl/kYmkeE
vEzwv4f1aPSINDj8Qz60l3a3kkt1P/xMXvoYjE0SpF85jDNvkyEZQAXDpm6/ 8Ntc1zS7rwtP
d6daaOLzV7631FJHluHe/ivUMbW5RVUR/bnO4SsW8kfKu87Ot8/4m/8AQpWX /gXH/wDHKPP+
Jv8A0KVl/wCBcf8A8co/szEd4/8AgcP/AJIX12l2l/4DL/IytR0PxfqeoWHi SfSfC1rrGl3k
c1vaQ3sri6Rbe6hKy3ZgDKB9sdlQQsFKN8x80mPC0T4aeJrZdQfUNQ0ie4u9 R0+7aSASRo3k
a7d6jIQhDFMxXChV3NhgQWwA57Lz/ib/ANClZf8AgXH/APHKPP8Aib/0KVl/ 4Fx//HKP7MxH
eP8A4HD/AOSD67S7S/8AAJf5HA6h8JNWnvNSeQ2d7DrH2u3uYzrd9ZRQQy6h e3Ks0VvtF3lL
3DRO0YBjIV8SFl0db+FVzqfhJ9CjuNOsJLzXdb1C+uooyxZL6DUIY3xhfMkV bqAEMQMRkBsB
c9b5/wATf+hSsv8AwLj/APjlHn/E3/oUrL/wLj/+OU/7MxPeP/gcP/kg+u0u 0v8AwCX+RzGu
eFvGepfF7w34mS20jTorXTnju9QtLlzLGpltXezdSo+1I2y5VHYIqidn2JJE hlwvDnwm1yx8
AX/h9NN8LaFdS+EbjQ5H0ud2TVrmSJES6uj5EZUoUfHErYuJMEc7/RPP+Jv/ AEKVl/4Fx/8A
xyjz/ib/ANClZf8AgXH/APHKP7MxHeP/AIHD/wCSD67S7S/8Bl/kclr/AMNt c1zS7rwtPd6d
aaOLzV7631FJHluHe/ivUMbW5RVUR/bnO4SsW8kfKu87LnibwRrnja40+bxL ZaFpKw3ga4Gm
3L3E0kC2l5Eu6aSFFlHmXS/uHjMe0S7jIJTGOh8/4m/9ClZf+Bcf/wAco8/4 m/8AQpWX/gXH
/wDHKX9mYjvH/wADh/8AJB9dpdpf+Ay/yOY1Pwj4muPHUfiu+8JeBfEV9Hp1 pbQzXt3JA1rN
b3Fy/nQA20xj3iWJtobKMu3c+0OYfEvw51q68Z6h4ntGhumnvJmhtE1680o+ VLaafEXae2Uv
lXsW/dYKsJAxYFAD1vn/ABN/6FKy/wDAuP8A+OUef8Tf+hSsv/AuP/45T/sz Ed4/+Bw/+SD6
7S7S/wDAJf5F3wvp1/oWiaXoUVnpws9Pjhs0eGeVR9njtwA6o4cg+YNgjaRv k+YyFvlOxZNc
vZQPewww3TRqZo4ZTIiPj5lVyqlgDkAlVJHOB0rmvP8Aib/0KVl/4Fx//HKP P+Jv/QpWX/gX
H/8AHKn+y8R3j/4HD/5If16l2l/4BL/I6qiuV8/4m/8AQpWX/gXH/wDHKPP+ Jv8A0KVl/wCB
cf8A8co/srEd4/8AgcP/AJIPr1LtL/wCX+Ru69/yA7//AK9pP/QTVfxlI0Xg /WpEYqy6fOQQ
cH/VtWLd/wDCyrm0mtpPCdoElRkYreR5AIxx89S+f8Tf+hSsv/AuP/45SllO IateP/gcP/kh
rH0k72l/4DL/ACOHk1fWXudadvF1rtk1qzmtNuuxKDAt7I0pUCQbY/srQoUO NzRv8pJ3N13w
2GtS6lr+oXl6LnSbq8kbT2W4WSNsXFxl4wCdq+WYEI4y8btg7t72vP8Aib/0 KVl/4Fx//HKP
P+Jv/QpWX/gXH/8AHK6qmFxVSLi+T/wOHl/e8jGOJoxd/e/8Bl/8iYmkeEvE zwv4f1aPSIND
j8Qz60l3a3kkt1P/AMTF76GIxNEqRfOYwzb5MhGUAFw6c5rvwk1a+g8QWMJs 3W7/ALYuLG8u
dbvnUTX0dyoX7F/qINn2plMq+YWVWOwNJlO+8/4m/wDQpWX/AIFx/wDxyjz/ AIm/9ClZf+Bc
f/xysP7MxHeP/gcP/kjT67S7S/8AAJf5HPeOfBfijXPFtveRXENzp6arp17E 8ut3VsLOG3nh
kkh+xxoYbksYpHEkhDAygcCJDWRF8NvF7DwnZT3ehLp/hiztdPtykkpluUgv 9NnM7ZTCF47J
x5QyEbH7xw5Mfcef8Tf+hSsv/AuP/wCOUef8Tf8AoUrL/wAC4/8A45R/ZmI7 x/8AA4f/ACQf
XaXaX/gEv8jjbH4RTXOm22l63dWbW9no2l6TFLC0jNNHam9hnLL8uzz7S7aP hmMbSuVJMaO2
vY+DvE2k3llqelT6RJfQ3Gtxlbl5PKjh1DUFulm+VcyPGI0Bhygcsw81doLb fn/E3/oUrL/w
Lj/+OUef8Tf+hSsv/AuP/wCOUv7MxHeP/gcP/kg+u0u0v/AZf5HG+HPh14r0 DwQmh21/ZzMf
7OmuooNSuLH7S0OnxWckAuIkMsKB7eGdZUG5+YmRVyzZuk/DTxrZ6Lr2ieVo X2XxJpU+nXc7
6xczy2AlvdRm3qXg3XRWO+Xl2jLNGckZ3V6J5/xN/wChSsv/AALj/wDjlHn/ ABN/6FKy/wDA
uP8A+OU/7NxHeP8A4HD/AOSD67S7S/8AAZf5HA6h8JNWnvNSeQ2d7DrH2u3u Yzrd9ZRQQy6h
e3Ks0VvtF3lL3DRO0YBjIV8SFl9LstHuYPH+r+IHkhNre6VY2caAneHglu3c kYxgi4THJOQ2
QOM0vP8Aib/0KVl/4Fx//HKPP+Jv/QpWX/gXH/8AHKTyzEPrH/wOH/yQ/rtL tL/wCX+RwM3w
k1ZtG0fT5jZ33/FLWHh/UV/tu+s4Ivs6yhpPLt9v2xG89v3chi4TAYeYxU13 4SatfQeILGE2
brd/2xcWN5c63fOomvo7lQv2L/UQbPtTKZV8wsqsdgaTKd95/wATf+hSsv8A wLj/APjlHn/E
3/oUrL/wLj/+OU/7NxPeP/gcP/khfXaXaX/gEv8AI57xX8MrnV/E2rz2WrQ2 Oi6t4a1PS3tP
JLG2vLx4TJcoM4IcRgsgKDepflpZGovPCni+/wDFMPjee10KDWLOS2Fvpaaj LJbzJFFfxFmu
TArIT/aDnAhYfuQM/vCU6Hz/AIm/9ClZf+Bcf/xyjz/ib/0KVl/4Fx//AByl /ZmI7x/8Dh/8
kH12l2l/4BL/ACI/AOm+JtD0CSz1Cx0g3Euo3N6wg1CR0X7VfzzSKCYVJ8uK RdpwN7ZUiMAO
eptGuWiY3cMMUnmOFWKUyAoHIRslV5K7SRjCkkAsBuPNef8AE3/oUrL/AMC4 /wD45R5/xN/6
FKy/8C4//jlL+y8R3j/4HD/5If16l2l/4BL/ACOqorlfP+Jv/QpWX/gXH/8A HKPP+Jv/AEKV
l/4Fx/8Axyj+ysR3j/4HD/5IPr1LtL/wCX+Ru6j/AMfmm/8AXy3/AKJkql4n me1udGuxFcyR
w3zNIYLd5mQG3mUHagJxuZR071lTf8LKlkgkbwnaAwuXXF5HydrLz8/oxqXz /ib/ANClZf8A
gXH/APHKP7KxF07x/wDA4f8AyQfXqXaX/gMv8jBtVay0HxTJPNrGqaxrcDh2 XQrmFCwhMcag
eXx2yScfSur+Iej3PiLwB4i8P2UkMd1qelXNnC8xIRXkiZFLEAkDLDOATjsa pef8Tf8AoUrL
/wAC4/8A45R5/wATf+hSsv8AwLj/APjlaVcBiqs+ebhfynD/AOSIp4qhTjyx Uv8AwGX/AMiV
fEHgyO08MppXgfTtO0a3+2C5urCxlfSkvRsKlTcWy+ZCQ3lPvRSWEQjPyuSO X8I+APFfh6xv
IVtPDl//AG1bzWl/DqF/cXUVrG19fXCnLxb73KXxV1kMJYxcud5K9l5/xN/6 FKy/8C4//jlH
n/E3/oUrL/wLj/8AjlR/ZmI7x/8AA4f/ACRX12l2l/4BL/IxLXwl4m0LVoNW 0ePSNSmtbjV1
igu7yS1WSHULuK8Ls6xSFXjdDEECsHUh9yH93XOWngnWfB2maTpGlXH2/Wod ZsZ9IuP7Pmkt
RHDpltptxLdbSqx4i+0yrGZlLFUCsxyh77z/AIm/9ClZf+Bcf/xyjz/ib/0K Vl/4Fx//AByn
/ZmI7x/8Dh/8kH12l2l/4BL/ACOe8QeF9XsdK8EeGvD8s1nHo941nYamE+1v bxLo13DHczps
VARKwG3lWOzkF9oztK+HfiSOfX9VaOzsNUe3sH0UyeI73VTHd2sly4Mk9xGs iQyCcROkfWN5
gCN5z2Xn/E3/AKFKy/8AAuP/AOOUef8AE3/oUrL/AMC4/wD45S/szEd4/wDg cP8A5IPrtLtL
/wAAl/kcb8Q/hnr1/wCFH8NeHrz7ZYvo0lgn2zXbnT2juXEnm3k32aNhevMX VnWUAbkYjPnP
j1yuV8/4m/8AQpWX/gXH/wDHKPP+Jv8A0KVl/wCBcf8A8coeV4h9Y/8AgcP/ AJIf16l2l/4B
L/I+dtW+KOr6l4+8IeJte0WGPUvCN54utbi3ibyRcm109JBwGlERIIUgPKAQ SGIIFS/EL4q/
Em/+DetT6lHZ6JNdeHtO1mwvdNu47O8j8y8gRgsKXU0zQssmBMRF0ZWQFgB9 F6R8P9J0mW1l
0nQ/CenyWkkkts9roixmF5EVJGQq3yllCqSOWCqORtyaT8P9J0myvrLStD8J 2FrqMflXsNro
ixpcpgjbIqthxh2GDkYY/wB4Z4r+R1HiOvfEPxf4H8U/GnW59Qh1mPQLPQ0t 7GYSpbpc3ESI
ZYlMjeVHuZ3aMZZ/lHmKQSfVPhF4o8W63rniHRvFmmaZbXelTWxh8iaBZnSW Mttmto7m4MJB
UkFpMOrAgDBroB4Jsj/zC/DH/IO/sv8A5BA/48uP9G+9/qef9X9325GZvD3h NPD1k1l4ftPD
2kWsknmvDY6X5KM5CgsVRwCcBRnqQB7ZT9AJ/tUP/Q1W3/f2z/8AiKPtUP8A 0NVt/wB/bP8A
+Iq0LHWT/wAv1h/4Cv7f9NPf/ORkFjrJ/wCX6w/8BX9v+mnv/nIytRkNhLDJ dTeXqv29wibt
rRlEGWxjywFyec9+B7VcqEWOsn/l+sP/AAFf2/6ae/8AnIyCx1k/8v1h/wCA r+3/AE09/wDO
RmbMLlu0/wCPqL/fX+dR6X/yM1v/ANeU/wD6HDS6ZaaimoQG5u7R4t2SscDK xwMjkue+Ox/U
Gk0v/kZrf/ryn/8AQ4auCs0J7HSUUUV1EBRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUVwHx+vtU0/4cXVxp5eKHzVF9com9raDBPmYyPlDiMOQQVjLsGQgO vhXhfxBe634d
8TaDfXVhYpbWYle6u7g+Rb5ZR5TXTfP5M67grk+an73B3KqR8tXE+zqKFr6X NFTbg59EfWlF
eKfs0aXq2m28hvrq0exkhkFjBAY28tUdVLboiYwDhRsjAUbS+FeV0X2utaNT 2keZqxEkk9Ao
oorUQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeD SfEzxnDovh3U
1s9BvZPFdlZ6jptqYp7cWaTXthA0E0u6TzSU1EYlVEwYy3luH216F4F1fVNR k13TNaaznvtF
1IWMlzaQPDFchraC4VxEzyFMC5CEb3yVLZ+fabFr4b8KWs97cW2gaFBNqFzH d3skdkqtczxy
eYksh2Zd1fLhmyQ3Oc5zpW8VjbzXM0EVpDLdyia5eNCrTOEVN7nb8zbEVcnJ wqjoDnDmRdi3
198/59/X3698/OdffP8An39ffr3z88XnJ3ki9/vf/E/X/OcnnJ3ki9/vf/E/ X/Ocq6Al6++f
8+/r79e+fnOvvn/Pv6+/Xvn54vOTvJF7/e/+J+v+c5POTvJF7/e/+J+v+c5L oCXr75/z7+vv
175+c6++f8+/r79e+fni85O8kXv97/4n6/5zk85O8kXv97/4n6/5zkugJ4D/ AKTFz1Y9/wDZ
P+Pv198tl6X/AMjNb/8AXlP/AOhw1o20qG5izKn3u27kkEenqf8APJOdpf8A yM1v/wBeU/8A
6HDQt0HQ6SiiiuggKKKKACvO/wBpHXvEHhj4Ma5rfhfUBp2r272qwXJijk8s PdRI52yAqfkZ
uo+nOK9Eryz9rAbvgF4jH+3Z/wDpZDXZl9COIxdKjLaUop/NpGVeThSlJbpM +eNF+NnxSS2V
b3xtc3kpwTINOs07dgIen59etbcfxn+IKwrLJ4jvijEqGNpaBSQBkA+R1GR+ YryjRLKW6lht
rdQ00pCxqWC7j6DNd94k8Mz6ZozyjT2hBjRd1zbmPy0+ZywdsZb5BljziQLt jwFr9Rx1LK8v
rUMM8PFubt8K0S6t/O+u6T1urP4zC0cwx1OtXjWklBX3er7Jfhps2r6O62W+ N/jgdfEd3/4D
2n/ximH45eN8/wDIy3n/AID2n/xivKg0cu7y2DlTz/T8Peu68KeCdK1Xwp4f 1W7lvluNU8ZQ
aDKscihEgeHzC6gqTvzkAk49q9CvgcpoU1VlRg03bSKep51GrmFWbgqsrpX1 bRtf8Ly8b/8A
Qy3n/gPaf/GKP+F5eN/+hlvP/Ae0/wDjFYviXwDfnxifCnh/wX4gtrqS/uYL K61PUECX0UG/
Lxq1vEvIVXz5hABHXIrm9F8KatrUkkWkHTb6dHmRLeDU7Z5pzEpZ/JjEm+YA AnMYYHBwTUUc
Nk1WmqnsoJWvqorR7P0e3roa1HmMJ8ntJvpo29ex33/C8vG//Qy3n/gPaf8A xij/AIXl43/6
GW8/8B7T/wCMVzNn8LPGt1ZwXcOm2giuIbaePzNTtUYpcNtgJVpAR5jZVQQC WBA5GKpWXgDx
ZdwxvHpDJJM9xHBbTzRw3Nw0AzMsULsJJSnIIRWwQR1BFUsLkbv7tLTf4dCO fMtPenr6nZ/8
Ly8b/wDQy3n/AID2n/xij/heXjf/AKGW8/8AAe0/+MV5R5Leho8lvQ12/wBh 5f8A9A8P/AV/
kc31/Ff8/pfez1f/AIXl43/6GW8/8B7T/wCMUf8AC8vG/wD0Mt5/4D2n/wAY ryjyW9DR5Leh
o/sPL/8AoHh/4Cv8g+v4r/n9L72er/8AC8vG/wD0Mt5/4D2n/wAYpf8AheXj b/oZLz/wHtP/
AIxXk/kt6Gk8s+lH9h5f/wBA8P8AwFf5D+v4r/n9L72es/8AC8/G3/QyXn/g Paf/ABij/hef
jb/oZLz/AMB7T/4xXk3lmjyzT/sPL/8AoHh/4Cv8g+v4r/n9L72es/8AC8/G 3/QyXn/gPaf/
ABij/hefjb/oZLz/AMB7T/4xXk3lmjyzR/YeX/8AQPD/AMBX+QfX8V/z+l97 PWf+F5+Nv+hk
vP8AwHtP/jFH/C8/G3/QyXn/AID2n/xivJvLNHlmj+w8v/6B4f8AgK/yD6/i v+f0vvZ6z/wv
Pxt/0Ml5/wCA9p/8Yo/4Xn42/wChkvP/AAHtP/jFeTeWaPLNH9h5f/0Dw/8A AV/kH1/Ff8/p
fez1n/hefjb/AKGS8/8AAe0/+MU3/hefjj/oZLv/AL8Wn/xivKPLNJ5ftS/s PAf9A8P/AAFf
5B9fxX/P6X3s9Y/4Xn44/wChku/+/Fp/8Yo/4Xn44/6GS7/78Wn/AMYryfy/ ajy/aj+w8B/0
Dw/8BQfX8V/z+l97PWP+F5+OP+hku/8Avxaf/GKP+F5+OP8AoZLv/vxaf/GK 8n8v2o8v2o/s
PAf9A8P/AAFB9fxX/P6X3s9Y/wCF5+OP+hku/wDvxaf/ABij/hefjj/oZLv/ AL8Wn/xivJ/L
9qPL9qP7DwH/AEDw/wDAUH1/Ff8AP6X3s9Y/4Xn44/6GS7/78Wn/AMYo/wCF 5+OP+hku/wDv
xaf/ABiuQ+FNvbP42t3u4I5o7e0vLkJIu5d8VrLIhIPBwyKcHjivSPFHjTVY 0DWWva9GpXA2
ajMAP/Hq83E4LBUq6owwkHpe9ku/k+x3YeeJq0nUliJLW278vMxv+F5+OP8A oZLv/wAB7T/4
xQ3x08bgZ/4SS8/8B7T/AOMU7w/INav9D1vXD/aV3DPrKme6/eO621hFPDvJ 5fa7sRuzxgdA
BXqU+r6BJquk6NceI/H0V9qC2qhrTUcQq06oy9WyAN47H8a4MRLAUWorBxbs 27JaWbX8vkdV
Kjiql39ZkrNde6T7+Z5HJ8efHSnjxHeH/thaf/GKif4+eOx08S3g/wC3ez/+ MVd8PFdd1rw7
rOu/8TO7iuNZVp7r948i21hFPCHJ5fY7sRuzxgdABXtn2UXvhpfFI8T+KoNJ gtXa7it7ibzj
InH7rnbszn5ug28kfMV8bO86y7K6kaX1GEm02/hVkpOP8rvs+x7eU5Jicwpu o8VKKTUVu7tp
O2j89PM+cdb+PnxMltmXT/GtzZSjJDnT7KTPXggwj2/KvqD9mnxFr3iv4K6F r3ifUP7Q1a5a
6E9z5McXmBLqVEO2MBR8iqOB29a+T/jG8uq+GtJ1i+le61B7+9tJLmRt0skU cdq8asx5bBlk
wTk4IHQCvp79kMbf2evDQ/273/0snrz84+p43KMPmeHoqm6jtZeV+2m63sdl LDV8Bja2Cq1O
fk6/d8+p6xRVLV725sbcS22k3upud+YrV4VYbY3cf610HzMoQc/edc4Xcy43 w/8AFr+L7O8u
18Na1o0Ntcy2obUWtj5ssU0kMyqIZpD8kkTKS2AeCu4c18gegafihJJNFlWK N5G3xHailiQJ
FJ4HPQV4T8XvDl3ZaTY3ehaLe2Wm2kksl2NOszA9tI+zbeLhRhk2spYZwkr7 lKF8fRNc/wCM
vF+jeEptBTWnmjXXNXi0e0eOPeq3EqO0YfHIVjHtyAcFlzhcsOevh1W3ZcJu DTR4j+yrdapf
eNNYnVDNYJZtHd3kIZbe4uQ8YjcKcgSlFdXGcjy0BLAIx+jqzNG1u11XUdbs beOZZdGvlsrg
yABWdreG4BTBOV2ToOcHIbjGCTxZrdr4a8K6t4jvo5pLTSrGa9nSEAyMkSF2 CgkAthTjJAz3
FXQoqjBQXQKk/aScn1NOiiitSAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooA8Jv8A47+AbO10+6kvcw3VubmZvtVqv2aNZZImbDTA3GHhmGLbzifL yu4PGX9RrkZf
AsLTpcw+JvEdtcSW622ozx3Mfm6jGskkgWR2QtFhpp8G3MJUSYXaEjCddXE7 dDQKKKKQwooo
oAKKKKAJbT/j6i/31/nUel/8jNb/APXlP/6HDUlp/wAfUX++v86j0v8A5Ga3 /wCvKf8A9Dhq
4boT2OkooorrMwooooAK8t/au/5IH4i/37P/ANLIa9Sryz9rD/kgXiP/AH7P /wBLIa9PJf8A
kY4f/HH/ANKRhif4M/R/kfHMD2z2wBkhDxlXXeqsAQc5Ktww9VwSc4wcmtfx BrOi63ax2cWm
w2pVQvmfYrJfMIYEf6u0iKHj7xc4PfFdh8FfB/hHX9K1678QfDfxJ4lmh1lr eC60/W4rOGKM
W1u3lbHvYMkF2YkIR84+Y9BreMvA/g60u4IdG+DPii2HllpftVzquo7snAw+ n3E0S4weGffy
DtUbS31+a55ha2NkqlJ3i3G+ltLrujxMuwNalh17OdlLX7/66HmfmWiliXjZ mYkkkZxnheDj
gcccdT3zXa6j8Top9R0QWPh3S9M07T9eh164gt5wqzXEcCQhIkWNRBGQHY5M rbm6gDFek/DX
4R/B7xB8No/Fmu+F59K8t7xb0z6zqNsluLaeWJ2dZbjdGB5RJ34I5yF5A0fD fwi+AWv3z2Nl
4Z8QW92sRmWDUp9ZsJJUBAZ41uHQyKpZAxTIUum7G5clbizAVVGNWhJ8v977 723vv6mFPIsT
TnOUKqXN5benay0PD/B/jS30D4oXHxAOj2k17PfX14bZbnb/AMfBlIQzbMkL 5g5287ela3w4
+KL+C9F8N2UWlPcvov2gulrrLWVvemVFXdcxiF/PZNp2MSu0beDjNe9f8M5f B7/oWL3/AMHt
/wD/AB+j/hnL4Pf9Cxe/+D2//wDj9YV+Jcrrw5J4Z2sl8XRXt/6U/v8AQ2pZ TjaUnKNZbt7d
Xa/5I8F0z4qS2emafYnQ7VxaWHh6yLjUSNw0y5adnx5XHmFtoGflxnJ6U64+ LV9NpyxfYruG
WK+1S8gisvEtzZW5N5O0yC4EKLJP5bscFXiyMjHJNepeDfhZ+z94v8ttC8L+ JpYZrYXUNzcn
XLW3liO3aySzFEfIYEBWJIyRkAmum/4Zy+D3/QsXv/g9v/8A4/XP/bWTav6t L/wL5fkb/Usw
/wCfy+4+SLVrSC1igDRYjQJxwOBjuSf1NS/aLT+8n5ivrL/hnL4Pf9Cxe/8A g9v/AP4/UN/+
z38GrKxuLybwtqbRQRNK6w6vqU0hCjJCokxZ244VQSTwATXvLj/DpWVF/ejx nwpUbu6n4Hyn
9otP7yfmKPtFp/eT8xX1l/wzl8Hv+hYvf/B7f/8Ax+j/AIZy+D3/AELF7/4P b/8A+P0f8RAo
f8+X96F/qnP/AJ+fgfJv2i0/vJ+YpPtFr/eT9K+s/wDhnL4Pf9Cxe/8Ag9v/ AP4/R/wzj8Hv
+hYvf/B7f/8Ax+j/AIiBQ/58v70H+qc/+fn4HyZ9otf7yfpR9otf7yfpX1n/ AMM4/B7/AKFi
9/8AB7f/APx+j/hnH4Pf9Cxe/wDg9v8A/wCP0/8AiIND/ny/vQf6pz/5+fgf Jn2i1/vJ+lH2
i1/vJ+lfWf8Awzj8Hv8AoWL3/wAHt/8A/H6P+Gcfg9/0LF7/AOD2/wD/AI/R /wARBof8+X96
D/VOf/Pz8D5M+0Wv95P0o+0Wv95P0r6z/wCGcfg9/wBCxe/+D2//APj9H/DO Pwe/6Fi9/wDB
7f8A/wAfo/4iDQ/58v70H+qc/wDn5+B8mfaLX+8n6UfaLX+8n6V9Z/8ADOPw e/6Fi9/8Ht//
APH6P+Gcfg9/0LF7/wCD2/8A/j9H/EQaH/Pl/eg/1Tn/AM/PwPkz7Ra/3k/S m/aLT/non/fQ
r61/4Zx+D3/QsXv/AIPb/wD+P0f8M4/B7/oWL3/we3//AMfo/wCIg0P+fL+9 D/1Tn/z8/A+S
vtFp/wA9E/76FH2i0/56J/30K+tf+Gcfg9/0LF7/AOD2/wD/AI/R/wAM4/B7 /oWL3/we3/8A
8fo/4iDQ/wCfL+9B/qnP/n4fJX2i0/56J/30KPtFp/z0T/voV9a/8M4/B7/o WL3/AMHt/wD/
AB+j/hnH4Pf9Cxe/+D2//wDj9H/EQaH/AD5f3oP9U5/8/D5K+0Wn/PRP++hR 9otP+eif99Cv
rX/hnH4Pf9Cxe/8Ag9v/AP4/R/wzj8Hv+hYvf/B7f/8Ax+j/AIiDQ/58v70H +qc/+fh8weEt
X0zTda866m2QTW1zaSSJhmjWaCSEuBnnb5m7HfGK7PUfGOt3/hIeFrr4peFJ dLWGOBYja3Sn
ZGV2DcLPdxtXv25zXtn/AAzj8Hv+hYvf/B7f/wDx+j/hnH4Pf9Cxe/8Ag9v/ AP4/XnYvi7B4
qpGrOjK6tb4XtqnrF2evQ7cPkVfD03TjNWfr19Gj540fW9D0O3sNIfV4tQUP qTXV7axv5cf2
y1S2+RZAjtsCBzkLkkgdMnYt/Fuo2qW3k/EHwGZrRI0t7iTR5nlQRgLGd7WJ bKhVwSSeBzXt
/wDwzj8Hv+hYvf8Awe3/AP8AH6P+Gcfg9/0LF7/4Pb//AOP1lU4pwNS3NSk/ /AHe7b6xfVva
xrDJ8RC9prX1XRLo/I+dNG8Q6HoB0vTG1aLUUjk1J7q9tY3EafbLZLf92sgR 22CMOchckkDp
k9Vb/EDU7SWxmt/ip4eSTT7b7LakQXu1YsAYKfZNrcBckgnKrzwMew/8M4/B 7/oWL3/we3//
AMfo/wCGcfg9/wBCxe/+D2//APj9eLnGLyjNpwqV4VFKKteM0r6uWvu927Ws e1lNXMMrhKnR
cHGTvaUb205dNeqVmfK3jbU9LbQLDQ7HU4dTkt7q6vJrmFHWItMkKBEEiq5w IASSo5bGOMn6
s/ZI/wCTffDn+/e/+lk9eP8A7U3wo8CeA/Buiar4V0i5sbu51oWszvqd1OHi NrcuV2yyMv3o
0OcZ4r179kI5/Z48MknOWvP/AEsnrtx1bCy4eoUcJBxhTm4q7u9r3v8AM54z r1cyq18RJOc1
d2Vlvb9DpfiH/wAjd8OP+xkm/wDTTqNc/f8AgvU7/wCFlx4avtHhumufGTX8 9pM0bxy2TeIP
tbFgTtZTbksUPJB243fLXqdFfIHongFz8MfF8vifxLe2MutWWv3v9rm3137V Y29o0dwlwtpH
50UR1CTyhLbDy5CsaNBuQkRQqx4b+FEsk9jZTeHNatPDlxqTDUbDUZdMtcQt pmo28siwaaqR
LvN1BGZA7StgAhFiVm9/ooA8TXwX4w8jWW8U6PD4ptG8ZG/uLCNrdjrenLpc drAXjlMcBlEq
wyuj+WgeB2jHEQPP+Lfhx4guvBmtWF/4B/4SV9Q0S7tfDlp5llJ/wjkslzfS RL+/lVIdsNxZ
RZti4H2TaPljiLfRlFAHjPg3wDrWnfF+fxFf2+tNcnUr+5m1PzdOS0uLSUzf Z7fekZvp/LSS
BfJmZYlaHKsRFCrezUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FAHB+MNeh8N6G2qzWN5ff6Rb20dtaeX5ssk86QxqvmMiD55FyWYADNHhfXod dgu/9BvNOvLG
4+zXtld+WZbeTy0kCsY2eNsxyRuCrMMOAcMGA4XVfCeqp8EbPw7Bp2r3lxBq Nnc/YxqEEd4t
umpRzmNZYzDFE6QqQqxMqR7QiOQqscjWfA+u6j4Qlt/7L1eHT5vEIv5dJkns 7zUZ7QWQgEcz
3TS29w/2gLKPOkfbEkYVlaONF40kaHtFFeAeNPAXi2bwTYabY6Lq91cWGnXL aE8DaTJeafdy
SSOomlmRFt0RfsoQWOPK2SKGYJC567wz4HvdJ1nSNZi0vydRfxTq9xqdz54a Q6dM1+8Me7cT
5Jd7WTyV4DneVDbmpWXcLnqNFFFIYUUUUAS2n/H1F/vr/Oo9L/5Ga3/68p// AEOGpLT/AI+o
v99f51Hpf/IzW/8A15T/APocNXDdCex0lFFFdZmFFFFABXln7WP/ACQLxH/v 2f8A6WQ16nXl
n7WP/JAfEf8AvWf/AKWQ16eS/wDIxw/+OP8A6UjHE/wZ+j/I8c+AHi/wloPh bXrHXPFGiaXd
t4jmmWC8v4oZChtLMB9rMDtJVhnplT6V6J/wsn4df9D94V/8HFv/APF1H+xb /wAiR4r/AOxn
k/8ASO0r1jwh4v8ADPiuO5bw94j0XWWtXxONOvY7jygWYIW2Mdu4KSM9cHFd eYYyVLF1opbT
l/6UzDAxvhqf+Ffkjgvhqltrv7PWtx2enReJLbUbjxCIbKK8EKaikl/ebY1n BwgkBCiQHjdm
o9Kn1m+vtTl0z/hLfF8Ufh++TzNd0v8AsO7juGMPk21rcC2tmRZ9sm9137Gh hbKHG/1m/u7W
wsbi+vrmG1tLaJpp55pAkcSKMs7MeFUAEkngAVyY+K/wwY7YfiJ4UuJDwkVv q8Essh7KiIxZ
2PQKoJJ4AJrwm+ZnaeP6T4c1e7s/Eek2/h+ay0G5vvC8lquj+HLnw/DIV1Zj dzxwea0scqoi
b5T5bhYo2wEEcjev/DLSf7Dv/F+l2umf2Zo8Gtp/ZNrFB5NvHA1hZs/kIAFC Gczk7RjeZCfm
3VU8N/FbQdc8RWOhxaZrVnc3zukD3cCRozLG8hXO8knajHAB6ema76qnCUHa SsF7niej+FvE
Vj+yXqGlXV94g1TUbrwJ9nh0m6tIVks5vsDL9niSKFJC24hNshdsqBnOc5nx 88N3ljpc9j4S
8IfaLqz0SWTRrv8Asi41W6N2Wmkle3m85RY3Stsma5ctLcPIm0SyQhW9/oqA PGdZ8KTf8JP4
r8Tw6LevrA8b6IdPuxHIzx2ezSo7p4OyI0YuEldMb0RlkJVMLS1jRJn8CfE+ zHhjWpfFl3pv
iBZ71LaTbexSyzGwi35xdv5DRLGEEhgVWiJiLbH9zooA8g8S6SyfGWLUYtCm 1O+lvrR4pLnR
JzNDCBGkjWuqxP5drboqySNaygNKwuFwVuUzBDo2qnQPiBa6VoetW/ju6ttb VNVTdbLP5s8r
aav2gsqTusJhEbKX+zqjIWhJ2N7NRQB5z8KbHTLfxVr914V8PTaB4VlsbGOC 1OkSaXG16r3R
uJBbSJG24xvaAy7MMFVdx8shfRqKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooA8A/bl/5Jv4c/wCxjT/0ivK6b9kD/k3bwx9bz/0snrmf 25f+Sb+HP+xj
T/0ivK6b9kD/AJN28MfW8/8ASyevoJf8iGP/AF9f/pCOFf76/wDCvzZ6zRRR Xz53BRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QBz+23/56y/9
+x/jRtt/+esv/fsf4153rvii58GxX+nWdnNrNn4d0oatqtzf6iVuEs2efYkO I2+0SKttKP3r
ITtj3SOzO4wvGXxP1u28Ga/qNvof9lov9tadpd/9rSaRr2yjvHWXySm0QlbR zlm3B/l8spiQ
8dvI0PYdtv8A89Zf+/Y/xo22/wDz1l/79j/GvOz471z+07vRx4b046kmqwaR ar/az+TLcnTx
fTb38jckax5VWCOzsBlYwcjCtviDqZ17xBqsWn70tdOsbe4trm/ZLGxmjvtT t7md5AjMsO63
A80RZ2iNpFjRXaMt5Aew7bf/AJ6y/wDfsf40bbf/AJ6y/wDfsf41VsppLiyg nltZrSSSNXe3
mKF4iRkoxRmXI6HaxGRwSOalpXAl22//AD1l/wC/Y/xo22//AD1l/wC/Y/xq KilcY6WaG2aC
RS8hNxFHgqF+9Iq5zk9M5pNL/wCRmt/+vKf/ANDhqtf/AHbb/r9tv/R6VZ0v /kZrf/ryn/8A
Q4a0huiXsdJRRRXUQFFFFABXln7WP/JAfEf+9Z/+lkNep15Z+1j/AMkB8R/7 1n/6WQ16eS/8
jHD/AOOP/pSMcT/Bn6P8jyf4PaFrfib9nX4iaJ4e+a/uPEwIi87y/tESQ2Dz QZOB+8iV48MQ
p34YhSSJvDPg3xvruqQXHgjVtX8KapbX9zcS6vqPhT7ClrYSR7YtPSOVVN4d 43F2GPkVmIZY
g3X/ALFv/IkeK/8AsZ5P/SO0r3anmlVxxtePRzl+bMsCv9mp/wCFfkeX+J9P 8R6X8J9GsPFm
vp4h1iLxLovn6ilqlsJwdZtSv7pPlXapC8dduepq5eTS3tpNZ3rtd2s8bRTQ T/vI5UYYZHRs
hlIJBBBBBwa7HxRoOmeJdGk0jV4ppLSSWKYiG5kt5FeKRZY3WSJldWV0VgVI ORXLf8Kk8Hf8
9PFX/hW6r/8AJNcuHrwpX5o3udLVzh4fDXhjRviX8P7rRfC3h/SbhtbuI2ms NLgtpGQ6XfEq
WjQErkA4zjIHpV7xt4c/4SD436x/xQHgzxb9n8N6X/yMM/l/Zt1zqP8Aqv8A RZ87tvzfd+6v
3u3aaN8MvCWk65Y61bR61Ne2EjS2rXuv312kTtG8RYRzTMmdkjrkjjccV1iW lql9LfJbQrdz
RJDLOIwJHRCxRC3UqpkcgHgF2x1NZVpxnK8VZDSseP8AifUfFnhfQ9YsIPFt 7LN4E8EWmqmY
wRP/AG1chbsP9qMqyPsY2SnEbo/72TLk7StKIeJrH4i69p+j+L721/tz4gJZ 3DzWdtL5MA8P
C4IiHljDjbEqs28DyYyyvmUS+wax4e0DWb7T77V9D0zUbvTZfOsJ7q0SWS1f KnfEzAlGyinK
4OVHoKE8PaAmsy60mh6YuqTSpNLei0QTu6RtEjmTG4sscjoCTkK7KOCRWQzz Pwj4s8Z6l49t
pZ4dTTR7vxBqmkuLl9Oj04Q2rXaRm1Af7Y9wTax7g+5cG4YKFCFYPAmqeNfE Wh+ALHU/G17b
3niLw3Lr93f6fYWsciNGtgiQIssUiBCLp3clSxkGVMaYiHqdv4e0C28RXPiO 30PTIdauohDc
ajHaItzMg2gI8oG5l+ROCcfKvoKh1Xwn4V1bQ7TQtU8NaLf6TZ7Pstjc2MUl vBsUomyNlKrt
UlRgDAJA4oA8/wDFOu6r4i/Z+8J+Jvstk+ranc+Gb77P5jQ25nlv7J9m7Dsi bmxnDkDsx68/
8WNS8XRX2q3niDRPD+ny23w78Sy2q2t+2pRykGwJEqTW0a7RhflIcMCQQAOf c720tb2FYby2
huYlljmVJYw6h43Do4B/iV1VgeoKgjkVBqWk6VqW/wDtHTLK8320to32iBZN 0Eu3zYjuByj7
E3L0bauQcCgDyb/mrn/dSf8A3U69mql/ZOlfbPtn9mWX2n7T9r87yF3+f5Pk +buxnf5X7vd1
2fLnHFXaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooA8A/b
l/5Jv4c/7GNP/SK8rpv2QP8Ak3bwx9bz/wBLJ65n9uX/AJJv4c/7GNP/AEiv K6b9kD/k3bwx
9bz/ANLJ6+gf/Ihj/wBfX/6QjhX++v8Awr82es0UUV8+dwUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeS3HhX4fTxW8TtAsc MZikSPVZUF4h
dnZboLIPtQZnkZhPvDGWUnJkfdbm0bwLPZQ2VwumT2sN5dXywzXO9DNcicTl lZiGDi5nBVsr
h+AMDHR6Nq1xqWmxXhi1CyZ8h7e7UpLE6kqysMkHBBwyllYYZWZSGJretw6L o19rGp3ssFjY
W8lzcy/M2yNFLM2FyTgAnABNcRocvJ4f8DvYTWjXQHnXEd01wusTC6EyQJbr KtwJPNVzDGqF
lYFgW3Z3tmFvCvw+MRRGghkMcUYuIdVliuFMbzOHEyyCQSFrm4LyBt8nnOHZ gxruvtFx/wA9
5f8Avs1DZX13cWUE8qXVpJJGrvbzSKXiJGSjFGZcjodrEZHBI5ov5gZ1leaB Y2UFlZXemW1r
bxrFDDDIiJGijCqqjgAAAADgCpf7X0r/AKCdl/3/AF/xrS+0XH/PeX/vs0fa Lj/nvL/32aNA
M3+19K/6Cdl/3/X/ABo/tfSv+gnZf9/1/wAa0vtFx/z3l/77NH2i4/57y/8A fZo0GZFxqOnz
vaxQX1rLI17bYRJVJP75OwNael/8jNb/APXlP/6HDUOozTOlurSuwN7bcFif +W6VNpf/ACM1
v/15T/8AocNXDdEvY6SiiiuogKKKKACvLP2sf+SA+I/9+z/9LIa9Tryz9rH/ AJID4j/37P8A
9LIa9PJf+Rjh/wDHH/0pGOI/gz9H+Rzn7Fv/ACJHiv8A7GeT/wBI7Svdq8J/ Yt/5EjxX/wBj
PJ/6R2le7VGbf7/X/wAcvzZngf8Adaf+FfkFFFFeedQUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeAft y/8AJN/Dn/Yx
p/6RXldN+yB/ybt4Y+t5/wClk9cz+3L/AMk38Of9jGn/AKRXldN+yB/ybt4Y +t5/6WT19BL/
AJEMf+vr/wDSEcK/31/4V+bPWaKKK+fO4KKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKAPn7x74d8R+JJ7y+uPCHnX2oaMtrocp ubeRvDl6JLgi
6Z3ZTE5EtqzNbeawa3IBfZGz5uu/C/V7zwzeQ6bp8Nrrerar4gjvbya5yRY3 aaj9nRmBYiAy
S2khhQEBzvKbwxr2byb7/oI2/wD4AN/8eo8m+/6CNv8A+ADf/Hq5Ls0PH/E3 hTX7zxnoOq6b
4VvNO+w3Glpp7WEOlxR2GnpJEbi3uJGJuVcKbpdlsxiZCi/NukBp+Afhrrek +F7a7u9F8nxJ
bajoH2eU3SM9vbQ22mw3vlEOVj3LDdRybcGVUCneuwV7Z5N9/wBBG3/8AG/+ PUeTff8AQRt/
/ABv/j1F2B4FoXwq1tNMFlqOk6jeXDyabHrjX0mmi11Vo9QtJZ5wsMYluRsi uG33bCXbIQFd
pZNvpfg/Qr3T/iJ4g1OXQvskF1uY3zXYdrlmcFQCp3zIEUYE6q1uxeOFpIXH l9l5N9/0Ebf/
AMAG/wDj1Hk33/QRt/8AwAb/AOPUm2wLFFV/Jvv+gjb/APgA3/x6jyb7/oI2 /wD4AN/8epWG
F/8Adtv+v22/9HpVnS/+Rmt/+vKf/wBDhqhdRXStamS9hkT7bbZVbQoT++Tv 5hx+VX9L/wCR
mt/+vKf/ANDhq4bol7HSUUUV1EBRRRQAV5Z+1j/yQHxH/v2f/pZDXqdeWftY /wDJAfEf+/Z/
+lkNenkv/Ixw/wDjj/6UjHEfwZ+j/I5z9i3/AJEjxX/2M8n/AKR2le7V4T+x b/yJHiv/ALGe
T/0jtK92qM2/3+v/AI5fmzPA/wC60/8ACvyCiiivPOoKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPAP2 5f8Akm/hz/sY
0/8ASK8rpv2QP+TdvDH1vP8A0snrmf25f+Sb+HP+xjT/ANIryum/ZA/5N28M fW8/9LJ6+gl/
yIY/9fX/AOkI4V/vr/wr82es0UUV8+dwUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAeE+C3t9L+FmmfFHVdV8R3F3/wAI8usa tGNSlniut1r5
0qrbyuYYvm+ZREI9pUKCELKbl/498TWeuWvheXwtpB8RXVxAqRLrcn2MQywX kquZvs2/fmwm
BTysfMh3HJC6Fp4V+H1tKx3QXNv5bxR2V3qstzZwI6FGWK2lkaGIeWzRgIig IzIMKxBm0vw/
4H066tryK6FxeW1wLmK6vdYmupw4iliAMk0jOUCTzYQkqDI7ABiTXHdGhztn 8U9T1N9HtNK8
MWcl9rf2W509LnVGii+xXNteTwySusDlJsWUgaJVdQWTEjc4mm+KNz/Z+pXt t4ehkj0CzlvP
EAkvyhhSK4uoJBa4iP2g7rK4K+Z5AI8rJUswSTV/Avge8fQFs9TGmQ6P9niA tNUmilktre2u
oYIVlSVXTabt2LA5YAq2QeNK48K/D6eK3idoFjhjMUiR6rKgvELs7LdBZB9q DM8jMJ94Yyyk
5Mj7j3Q1Mm6+KsmnWV3rGseGZrbRILzVLGOeG8SWeeWxF1I7LFgARtHZyYLO GEny7CmJTu/D
nxdqPif7fFqfhy80ia08tldoLtIJlfdwjXNvA5dSh3AIVAZPmJJCyTaN4Fns obK4XTJ7WG8u
r5YZrnehmuROJyysxDBxczgq2Vw/AGBg0TSfCOjSiey1ORrjzBI09zrc9zLI FR1VHkllZnjX
zJCsbEorMXChuaWgHVV5z8fPGmpeDvCUs2n6cbgXNvKslxHcFZLTlFDhRzt+ cjzNyhG2Z+8K
67T5tCsdvkauH228VsPP1N5vkj3bSd7nLncdzn5n43E7RiwuoaItw9wt9pwm dFR5BKm5lUkq
Cc5IBZsDtuPrWlCpGnUjOUeZLp3JnFyi1exzvw5g8Z2vgvTLfx3NZz6tHeWo 8yCQuzR+ZEQJ
TgAyAllJXKnaDnk12el/8jNb/wDXlP8A+hw1mXGo6fO9rFBfWssjXtthElUk /vk7A1p6X/yM
1v8A9eU//ocNU6ntKnPZK76bAo8sbI6SiiityQooooAK8s/ax/5ID4j/AN+z /wDSyGvU68s/
ax/5ID4j/wB+z/8ASyGvTyX/AJGOH/xx/wDSkY4j+DP0f5HOfsW/8iR4r/7G eT/0jtK92rwn
9i3/AJEjxX/2M8n/AKR2le7VGbf7/X/xy/NmeB/3Wn/hX5BRRRXnnUFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFAHgH7c
v/JN/Dn/AGMaf+kV5XTfsgf8m7eGPref+lk9cz+3L/yTfw5/2Maf+kV5XTfs gf8AJu3hj63n
/pZPX0D/AORCv+vr/wDSEcK/31/4V+bPWaKKK+fO4KKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPmn4+fGTSvhvpLzwW1nd+J 7/y5bC1ZyXiX
YhMkuACIuq9QXOQOAzL0nwu+LOi/EvwP/aukSx2uoqJI7/TzJmazby3ZfTcp 2jbIBg88Bgyr
6R9mt/tH2j7PF53/AD02Dd0x169KcIIRKZRDH5hIJfaMkgYBz9CR+Ncd1bY0 M9JrpbmaLzY2
Z7hY1LISEPkhicZ6HHTPGc5NNOoXW24cLDttoi75By5VpFIHPGdmc84960Gt rdozG1vEUKhS
pQYwOgx6CnCCEIUEMe0oEI2jBUdF+nJ496kY+iiigAooooAltP8Aj6i/31/n Uel/8jNb/wDX
lP8A+hw1Jaf8fUX++v8AOo9L/wCRmt/+vKf/ANDhq4boT2OkooorrMwooooA K8s/ax/5ID4j
/wB+z/8ASyGvU68s/ax/5ID4j/37P/0shr08l/5GOH/xx/8ASkY4j+DP0f5H OfsW/wDIkeK/
+xnk/wDSO0r3avCf2Lf+RI8V/wDYzyf+kdpXu1Rm3+/1/wDHL82Z4H/daf8A hX5BRRRXnnUF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFAHgH7cv8AyTfw5/2Maf8ApFeV037IH/Ju3hj63n/pZPXM/ty/ 8k38Of8AYxp/
6RXldN+yB/ybt4Y+t5/6WT19A/8AkQr/AK+v/wBIRwr/AH1/4V+bPWaKKK+f O4KKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP IPHHxG0rSPD3
iSXS7jzdU0zTr2a2M9nOLOe4t4XdoVn2iOV1Mb7o0cuPLkyBsbbF4N8dx3Ta gNS1/Qtc0+3k
sYoda0SB1tZLi6maFbXaJZv3iMISx38LcJlVA3Nj6p8GbC7l8QCCbQrVdWj1 IperoETakkt6
kwfzLovl41M77URY22rGpcgPv3Z/A2p6kmp3ut69Zza1df2f5M9npzQW0X2G 5a5t90LTOz/v
XbfiRdyYVdhBc8fumhF45+KGneG9Q1GwgsZtSuNP0rUr24CCRRHNaW9tcCFm EZCh47pD5hO0
HC8swWt1fG3hw6lb6ebm8jmn8pd0mn3CRQyShTHDNIyBIJmDx4ikKuTJGNuX UHlj8KpLy41q
61rxNNe3GuR31vfvFZpCBb3dpawSJCMnYVaziZGbfhNyuJGPm1ozeBtTuNSk kudes2sb/UbL
VtUhj05lllvbUW+wwyGYiKEm0hJjZJGx5gEnzAqe6BseEfHHhfxZ5Z0DVPti zW4uYHMEkaTx
/LuaJnUCTYWVZApJjZgr7WOK6KuR8KeCv7C/4RH/AImX2j/hHfD0mi/6jb9o 3fZP3v3jsx9l
+7z9/rxz11S7dBhRRRQBLaf8fUX++v8AOo9L/wCRmt/+vKf/ANDhqS0/4+ov 99f51Hpf/IzW
/wD15T/+hw1cN0J7HSUUUV1mYUUUUAFeWftY/wDJAfEf+/Z/+lkNep15Z+1j /wAkB8R/79n/
AOlkNenkv/Ixw/8Ajj/6UjHEfwZ+j/I5z9i3/kSPFf8A2M8n/pHaV7tXhP7F v/IkeK/+xnk/
9I7SvdqjNv8Af6/+OX5szwP+60/8K/IKKKK886gooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA8A/bl/5J v4c/7GNP/SK8
rpv2QP8Ak3bwx9bz/wBLJ65n9uX/AJJv4c/7GNP/AEivK6b9kD/k3bwx9bz/ ANLJ6+gl/wAi
GP8A19f/AKQjhX++v/CvzZ6zRRRXz53BRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQBzVFFFcJqFFFFABRRRQAUUUUAS2n/H1F /vr/ADqPS/8A
kZrf/ryn/wDQ4aktP+PqL/fX+dR6X/yM1v8A9eU//ocNXDdCex0lFFFdZmFF FFABXln7WP8A
yQHxH/v2f/pZDXqdeWftY/8AJAfEf+/Z/wDpZDXp5L/yMcP/AI4/+lIxxP8A Bn6P8jnP2Lf+
RI8V/wDYzyf+kdpXu1eE/sW/8iR4r/7GeT/0jtK92qM2/wB/r/45fmzPA/7r T/wr8gooorzz
qCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigDwD9uX/km/hz/sY0/9Iryum/ZA/wCTdvDH1vP/AEsnrmf2 5f8Akm/hz/sY
0/8ASK8rpv2QP+TdvDH1vP8A0snr6B/8iFf9fX/6QjhX++v/AAr82es0UUV8 +dwUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA c1RXkcvxYfT7
yfTtL8I6vqjWtxeS3qRG8vJfLXULu3HkmOCUF2NrKyxyvCigoiuVDFMfXPGX ib/hWnjrT9Fj
+0X2mW+uXd1qF1qklvLawtf6jFbm3KxuXdBavhSYwoWMBuTs4+Vmlz3Siiip GFFFFABRRRQB
Laf8fUX++v8AOo9L/wCRmt/+vKf/ANDhqS0/4+ov99f51Hpf/IzW/wD15T/+ hw1cN0J7HSUU
UV1mYUUUUAFeWftY/wDJAfEf+/Z/+lkNep15Z+1j/wAkB8R/71n/AOlkNenk v/Ixw/8Ajj/6
UjHE/wAGfo/yOc/Yt/5EjxX/ANjPJ/6R2le7V4T+xb/yJHiv/sZ5P/SO0r3a ozb/AH+v/jl+
bM8D/utP/CvyCiiivPOoKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKAPAf25f+SceG/wDsY0/9Iryul/ZA /wCTdvDH1vP/
AEsnrmf25f8Akm/hz/sY0/8ASK8rpv2QP+TdvDH1vP8A0snr6CX/ACIY/wDX 1/8ApCOFf76/
8K/NnrNFFFfPncFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFAHmV18P/Cdw2ZNNmVXkmknjivZ40uhLNJNIlwiuFnjMksp8uUM gEjgKAzAw6v8
NvB+qWs9rc6feRw3P2gXS2up3Nt9pWeWSWRJjFIplQvNMQj5VfMcKAGIOvc+ KPDNtpr6nc+I
tIhsUt4bp7mS9jWJYZiVhlLE4COQQrZwxBAzR/wlHhn/AKGLSP8AkHf2p/x+ x/8AHl/z89f9
T/00+771xXZoa9FeaWfxPufEHimbRPA+maFrscclyFvn1wx28qQRWDsytFBL k7r7ZjoPKJzk
4HUyeLNM0qwmufFur+HNE8m4jtZC2rqY0maBJTEzyLHh/mYhcZZAr8btqlmB 0VFcu3jjQ7K4
10eINQ07QrXStVTTUub69SJLh2tILkYL7QDiYjbknCE+w0fBOtf8JJ4M0TxF 9m+y/wBq6db3
vkeZv8rzY1fbuwN2N2M4GcdBSsM16KKKAJbT/j6i/wB9f51Hpf8AyM1v/wBe U/8A6HDUlp/x
9Rf76/zqPS/+Rmt/+vKf/wBDhq4boT2OkooorrMwooooAK8s/ax/5ID4j/37 P/0shr1OvLP2
sf8AkgPiP/fs/wD0shr08l/5GOH/AMcf/SkY4j+DP0f5HOfsW/8AIkeK/wDs Z5P/AEjtK92r
wn9i3/kSPFf/AGM8n/pHaV7tUZt/v9f/ABy/NmeB/wB1p/4V+QUUUV551BRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQB4
B+3L/wAk38Of9jGn/pFeV037IH/Ju3hj63n/AKWT1zP7cv8AyTfw5/2Maf8A pFeV037IH/Ju
3hj63n/pZPX0D/5EK/6+v/0hHCv99f8AhX5s9Zooor587gooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA8Jj+HGp6Trg13RpbO 5m03UY30mxub
looTZLBeKsDOsbGHy31G5CBUdRFDbpgHc9Q2Xw21yCPV7l7vTjdXsljqEcQk fYLmDV7vU3gL
7M+WTcJEJdpbAZzGOEPq9FcXMzSx5Rp3w0uda8d3PiPx7oPha9tbiS8lGnlz fpE8kGmQxsDL
AgJxZTZO0ECRQM5ODxL8OdauvGeoeJ7Robpp7yZobRNevNKPlS2mnxF2ntlL 5V7Fv3WCrCQM
WBQA+r0UczCx5R4c+H3iLwhrQ1fQYtCv2gjazt7KW6ntIhbtZaZCX3lJ3Uq+ nECM78rICZMq
Q3dfDzR7nw74A8O+H72SGS60zSrazmeEkozxxKjFSQCRlTjIBx2FbtFDdwsF FFFIZLaf8fUX
++v86j0v/kZrf/ryn/8AQ4aktP8Aj6i/31/nUel/8jNb/wDXlP8A+hw1cN0J 7HSUUUV1mYUU
UUAFeWftY/8AJAfEf+/Z/wDpZDXqdZPjDw3ovi7w7deHvENn9t0y72efD5rx 7tjq6/MhDDDK
p4PauvAYiOGxVKtJXUZJ/c0zOrBzg4rqj5U+BHxl0L4a6LrukaxoWvX8l9rD X8MtgLZo/La3
gjAPmTIwbMTcY6Y5r0M/tV+Cgcf8Il4x/wC/Vl/8k10v/DOHwZ/6E5v/AAa3 n/x2j/hnD4M/
9Cc3/g1vP/jte1iMRkmIrSqzjVvJtuzh1d+xw0qOMpU404yjZJLZ9Pmcz/w1 Z4J/6FPxj/36
sv8A5Jo/4as8E/8AQp+Mf+/Vl/8AJNdN/wAM4fBn/oTm/wDBref/AB2j/hnD 4M/9Cc3/AINb
z/47WV8h7Vfvh/kaWxveP3P/ADOZ/wCGrPBP/Qp+Mf8Av1Zf/JNH/DVngn/o U/GP/fqy/wDk
mum/4Zw+DP8A0Jzf+DW8/wDjtH/DOHwY/wChOb/waXn/AMdovkPar98P8gtj e8fuf+ZzP/DV
ngn/AKFPxj/36sv/AJJo/wCGrPBP/Qp+Mf8Av1Zf/JNdN/wzh8GP+hOb/wAG t5/8do/4Zw+D
P/QnN/4Nbz/47RfIe1X74f5BbG94/c/8zmf+GrPBP/Qp+Mf+/Vl/8k0f8NWe Cf8AoU/GP/fq
y/8Akmum/wCGcPgx/wBCc3/g1vP/AI7R/wAM4fBj/oTm/wDBref/AB2i+Q9q v3w/yC2N7x+5
/wCZzP8Aw1Z4J/6FPxj/AN+rL/5Jpf8AhqzwT/0KfjH/AL9WX/yTXS/8M4fB j/oTm/8ABref
/HaP+GcPgz/0Jzf+DW8/+O0XyHtV++H+QWxveP3P/M5n/hqzwT/0KfjH/v1Z f/JNL/w1Z4J/
6FPxj/36sv8A5Jrpf+GcPgx/0Jzf+DW8/wDjtH/DOHwY/wChOb/wa3n/AMdo vkPar98P8gtj
e8fuf+ZzP/DVngn/AKFPxj/36sv/AJJpf+GrPBP/AEKfjH/v1Zf/ACTXS/8A DOHwZ/6E5v8A
wa3n/wAdo/4Zw+DP/QnN/wCDW8/+O0XyHtV++H+QWxveP3P/ADOZ/wCGrPBP /Qp+Mf8Av1Zf
/JNH/DVngn/oU/GP/fqy/wDkmum/4Zw+DH/QnN/4Nbz/AOO0f8M4fBj/AKE5 v/Bpef8Ax2i+
Q9qv3w/yC2N7x+5/5nM/8NWeCf8AoU/GP/fqy/8Akmj/AIas8E/9Cn4x/wC/ Vl/8k103/DOH
wZ/6E5v/AAa3n/x2j/hnD4Mf9Cc3/g1vP/jtF8h7Vfvh/kFsb3j9z/zOZ/4a s8E/9Cn4x/79
WX/yTR/w1Z4J/wChT8Y/9+rL/wCSa6b/AIZw+DP/AEJzf+DW8/8AjtH/AAzh 8Gf+hOb/AMGt
5/8AHaL5D2q/fD/ILY3vH7n/AJnM/wDDVngn/oU/GP8A36sv/kmj/hqzwT/0 KfjH/v1Zf/JN
dN/wzh8Gf+hOb/wa3n/x2j/hnD4M/wDQnN/4Nbz/AOO0XyHtV++H+QWxveP3 P/M5n/hqzwT/
ANCn4x/79WX/AMk0f8NWeCf+hT8Y/wDfqy/+Sa6b/hnD4M/9Cc3/AINbz/47 R/wzh8Gf+hOb
/wAGt5/8dovkPar98P8AILY3vH7n/mcz/wANWeCf+hT8Y/8Afqy/+SaP+GrP BP8A0KfjH/v1
Zf8AyTXTf8M4fBn/AKE5v/Bref8Ax2j/AIZw+DP/AEJzf+DW8/8AjtF8h7Vf vh/kFsb3j9z/
AMzmf+GrPBP/AEKfjH/v1Zf/ACTR/wANWeCf+hT8Y/8Afqy/+Sa6b/hnD4M/ 9Cc3/g1vP/jt
H/DOHwZ/6E5v/Bref/HaL5D2q/fD/ILY3vH7n/mcz/w1Z4J/6FPxj/36sv8A 5Jo/4as8E/8A
Qp+Mf+/Vl/8AJNdN/wAM4fBn/oTm/wDBref/AB2j/hnD4Mf9Cc3/AINLz/47 RfIe1X74f5Bb
G94/c/8AM5n/AIas8E/9Cn4x/wC/Vl/8k0f8NWeCf+hT8Y/9+rL/AOSa6b/h nD4M/wDQnN/4
Nbz/AOO0f8M4fBn/AKE5v/Bref8Ax2i+Q9qv3w/yC2N7x+5/5nM/8NWeCf8A oU/GP/fqy/8A
kmj/AIas8E/9Cn4x/wC/Vl/8k103/DOHwZ/6E5v/AAa3n/x2j/hnD4M/9Cc3 /g1vP/jtF8h7
Vfvh/kFsb3j9z/zPDP2i/jR4f+JPhXSdI0fQ9esJLPVReyy362yx7BbTx4Hl zOxbdKvbGM81
7n+yB/ybt4Y+t5/6WT0f8M4fBn/oTm/8Gt5/8dr0Pwf4b0Xwj4ctfD3h6y+x aZab/Ig815Nu
92dvmcljlmY8nvSx2OwLwKwmEU/j5vet2t0t2XQdGjWVZ1arW1tL979TWooo rwDtCiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gD5s17x1r93Y
6vrXh/xLDFot1rtna297ePFZW+nWL6TFdibzpLeTyzLNKiEzJIPnVFCMwYZ3 jT4keKNG8E2G
pHxFpFtqFlp1zfiafUI7ez1tVkkEMcPm2e+8fZCpfyPsyt9ojaNgssZT3+iu PmXY0sFFFFSM
KKKKACiiigCW0/4+ov8AfX+dR6X/AMjNb/8AXlP/AOhw1Jaf8fUX++v86j0v /kZrf/ryn/8A
Q4auG6E9jpKKKK6zMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD mqKKK4TUKKKK
ACiiigAooooAltP+PqL/AH1/nUel/wDIzW//AF5T/wDocNSWn/H1F/vr/Oo9 L/5Ga3/68p//
AEOGrhuhPY6SiiiuszCiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo A8s8DePLTxT9
gxomr6R/aenf2npv2/yD9rth5e518mWTbt86HIk2n94MA4bb11eL/Cnwp4u0 PRtO+yaFeaTq
mm+Fn09v+Eg1MXsE1+Vt/KMHlzzNDbBoZPMRPK3BovlbYvl53gn4eata+M9M c+GNRtfDdpqt
pfi31SLSohHPHaakjTpDY4iyHkshvK+YSqnO2MbeNpGlz3miiipGFFFFABRR RQBLaf8AH1F/
vr/Oo9L/AORmt/8Aryn/APQ4aktP+PqL/fX+dc94i/sb+0bL+3PsH2byZtv2 zZs35jxjdxnG
f1qou1mJnoNFeZf8W9/6lf8A8gUf8W9/6lf/AMgVv7XyJ5T02ivMv+Le/wDU r/8AkCj/AIt7
/wBSv/5Ao9r5BynptFeZf8W9/wCpX/8AIFH/ABb3/qV//IFHtfIOU9NorzL/ AIt7/wBSv/5A
o/4t7/1K/wD5Ao9r5BynptFeZf8AFvf+pX/8gUf8W9/6lf8A8gUe18g5T02i vMv+Le/9Sv8A
+QKP+Le/9Sv/AOQKPa+Qcp6bRXmX/Fvf+pX/APIFH/Fvf+pX/wDIFHtfIOU9 NorzL/i3v/Ur
/wDkCj/i3v8A1K//AJAo9r5BynptFeZf8W9/6lf/AMgUf8W9/wCpX/8AIFHt fIOU9NorzL/i
3v8A1K//AJAo/wCLe/8AUr/+QKPa+Qcp6bRXmX/Fvf8AqV//ACBR/wAW9/6l f/yBR7XyDlPT
aK8y/wCLe/8AUr/+QKP+Le/9Sv8A+QKPa+Qcp6bRXmX/ABb3/qV//IFH/Fvf +pX/APIFHtfI
OU9NorzL/i3v/Ur/APkCj/i3v/Ur/wDkCj2vkHKem0V5l/xb3/qV/wDyBR/x b3/qV/8AyBR7
XyDlPTaK8y/4t7/1K/8A5Ao/4t7/ANSv/wCQKPa+Qcp6bRXmX/Fvf+pX/wDI FH/Fvf8AqV//
ACBR7XyDlPTaK8y/4t7/ANSv/wCQKP8Ai3v/AFK//kCj2vkHKem0V5l/xb3/ AKlf/wAgUf8A
Fvf+pX/8gUe18g5T02ivnT+1Zv8AhL/tP/CMeF/7B/1f2X7TYebtz/rd2/7/ APs52446/NXa
6rB4GudPngsr7w1YXDriK4SO2cxt2O1gQR6j0zgg8jWa5Gr217O9vWwkrnq1 FfPvgOyRdQuJ
/Fus+E2t4WaOG3iissT/APTQsqghfQcMT1wBhu1/4t7/ANSv/wCQKVV+zly7 +gJXPTaK8y/4
t7/1K/8A5Ao/4t7/ANSv/wCQKz9r5D5T02ivMv8Ai3v/AFK//kCj/i3v/Ur/ APkCj2vkHKem
0V5l/wAW9/6lf/yBR/xb3/qV/wDyBR7XyDlPTaK8y/4t7/1K/wD5Ao/4t7/1 K/8A5Ao9r5By
nptFeZf8W9/6lf8A8gUf8W9/6lf/AMgUe18g5T02ivMv+Le/9Sv/AOQKP+Le /wDUr/8AkCj2
vkHKem0V5l/xb3/qV/8AyBR/xb3/AKlf/wAgUe18g5T02ivMv+Le/wDUr/8A kCj/AIt7/wBS
v/5Ao9r5BynptFeZf8W9/wCpX/8AIFH/ABb3/qV//IFHtfIOU9NorzL/AIt7 /wBSv/5Ao/4t
7/1K/wD5Ao9r5BynptFeZf8AFvf+pX/8gUf8W9/6lf8A8gUe18g5T02ivMv+ Le/9Sv8A+QKP
+Le/9Sv/AOQKPa+Qcp6bRXmX/Fvf+pX/APIFH/Fvf+pX/wDIFHtfIOU9Norz L/i3v/Ur/wDk
Cj/i3v8A1K//AJAo9r5BynptFeZf8W9/6lf/AMgUf8W9/wCpX/8AIFHtfIOU 6iiiiuYsKKKK
ACiiigAooooAltP+PqL/AH1/nXDfFBN404eXv/1q/c3fe2Lj7jdd23H8W7bt l3eTJ3Np/wAf
UX++v864b4oJvGnDy9/+tX7m772xcfcbru24/i3bdsu7yZOrB/xoepjiP4bO J/1n/TTf/wAD
37v++92fN/6abvN/5a+b/p/vPh9/M8KaTJ5nmbrW2bfv37shed298/Xe2f7z dT4N/rP+mm//
AIHv3f8Afe7Pm/8ATTd5v/LXzf8AT/efD7+Z4U0mTzPM3Wts2/fv3ZC87t75 +u9s/wB5up9j
MfgRxYP4ma1FFFeWdwUUUUAFV7qxsrqWOW5s7eeSL/VvJGGKfMr8Ejj5o0b6 op6gVmr4t8Kt
dyWa+JtFa5iu0spIRfxF0uGLBYSu7IkJRwE6na3HBov/ABb4V0+7vLO/8TaL aXNjGsl3DPfx
I9ujFQrOpbKgmRACcZ3r6iqSknoX7Kb05X9xNZ6dOPEN9q140blkS3slUk+V CAGc4I+V3kJ3
YOCscOeVrUrAufF2iReMLTwpHeWtxqk+/wAyCO+txJbbY/MG+JpBKdy8jYjc cnA5ouvG3gy1
+1fafF2gQfY5xbXPmajCvkTHdiN8t8r/ALt/lPPyN6GnLmluNUJrZPXU36Ky 9R8SeHdN1e20
jUde0qz1K62/Z7Se8jjmm3MVXYhIZssCBgckYrFuviN4VtPiQPAV1qMUGqta JcBpJoliLu4R
LfJfd5zblYJt5UgjrSUW9kONGpLaL2v8jrqKy9R8SeHdN1e20jUde0qz1K62 /Z7Se8jjmm3M
VXYhIZssCBgckYrUpWM3FrVoKK5/XfGXhrRPEWmeH9R1rTLfVNSlVIbSXUII psNvCOI5HV3V
nTyxsDEsw4wGKz6r4s8K6TrlpoWqeJdFsNWvNn2Wxub6KO4n3sUTZGzBm3MC owDkggc0hGzR
XPv438Fxw6rM/i/w+sWjSrDqjnUoQti7OUVJju/dsXBUBsEkEdaJvG/guG+0 2xm8X+H47vVY
optOgfUoRJeJKcRPEpbMiueFK5DHpmgDoKKxtQ8WeFdO/tT+0PEui2n9keV/ aXn30SfYvNx5
XnZb93vyNu7G7PGa2aACiuf8SeN/Bfhq+Sx8R+L/AA/o13JEJkgv9Sht5GQk gOFdgSuVYZ6Z
B9KNT8b+C9Lvr+x1Pxf4fsrvTolmvoLjUoY5LVGKBXkVmBRSZIwC2AS6/wB4 UAdBRXPt4y8N
NrOjaPa61pl3fazELizhh1CAySW5jkkW4VC4aSI+WQGjD8nONoZlnuvFnhW1 1R9LufEuiwX8
dzBaPayX0SyrPOpaGIoWyHkVSVXGWAJAOKANmisbV/FnhXR9UGl6v4l0XT79 rZ7sWt1fRRSm
BFdnl2MwOxVjkJbGAEYk8GtOwu7W/sbe+sbmG6tLmJZoJ4ZA8cqMMq6sOGUg ggjgg0ATUVzP
xA8Wv4Qs7O7bw1rWsw3NzFaltOa2HlSyzRwwqwmmjPzySqoK5A5LbRzWZ4k+ JFvoPiLV9Lu/
C3iCS00Wxh1HUdUiNoba3tJPN/flTOJmVfInyqxl/wB2cK2V3AHc0Vjar4s8 K6TrlpoWqeJd
FsNWvNn2Wxub6KO4n3sUTZGzBm3MCowDkggc0XXizwra6o+l3PiXRYL+O5gt HtZL6JZVnnUt
DEULZDyKpKrjLAEgHFAGzRWNqvizwrpOuWmhap4l0Ww1a82fZbG5voo7ifex RNkbMGbcwKjA
OSCBzRrniGHSNf8AD+kT2F7L/blzLaw3MXlmKGVIJJwsmXD/ADJFJgqrDK4O 3IyAbNFFY2r+
LPCuj6oNL1fxLoun37Wz3Ytbq+iilMCK7PLsZgdirHIS2MAIxJ4NAGzRXPze N/BcN9ptjN4v
8Px3eqxRTadA+pQiS8SU4ieJS2ZFc8KVyGPTNQ3XxB8D2vi9/CF34t0W219P IH2Ce8SOVmmJ
ESKGI3O2AdgywDISAHUkA6aiuZ+IHi1/CFnZ3beGta1mG5uYrUtpzWw8qWWa OGFWE00Z+eSV
VBXIHJbaOah8VeN10ea9h0zwx4g8US6dF5moJo0cDtanZvWMiWWPfKyfMIo9 7gFCVAkj3gHW
UVjar4s8K6TrlpoWqeJdFsNWvNn2Wxub6KO4n3sUTZGzBm3MCowDkggc0XXi zwra6o+l3PiX
RYL+O5gtHtZL6JZVnnUtDEULZDyKpKrjLAEgHFAGzRXM3XxB8D2vi9/CF34t 0W219PIH2Ce8
SOVmmJESKGI3O2AdgywDISAHUm7qvizwrpOuWmhap4l0Ww1a82fZbG5voo7i fexRNkbMGbcw
KjAOSCBzQBs0VjXXizwra6o+l3PiXRYL+O5gtHtZL6JZVnnUtDEULZDyKpKr jLAEgHFUrr4g
+B7Xxe/hC78W6Lba+nkD7BPeJHKzTEiJFDEbnbAOwZYBkJADqSAdNRXDeJPi Rb6D4i1fS7vw
t4gktNFsYdR1HVIjaG2t7STzf35UziZlXyJ8qsZf92cK2V3dBqvizwrpOuWm hap4l0Ww1a82
fZbG5voo7ifexRNkbMGbcwKjAOSCBzQBs0VjXXizwra6o+l3PiXRYL+O5gtH tZL6JZVnnUtD
EULZDyKpKrjLAEgHFGq+LPCuk65aaFqniXRbDVrzZ9lsbm+ijuJ97FE2RswZ tzAqMA5IIHNA
GzRWZ4h1u10SGza4jmnlvb6Cyt4IAGlkeRwCVUkZVE3yvjJWOKRsYU0Jrdqf FUvhx45ortbF
L2J5AFjuELsjiM5y7RkJvwMKJ4cn5xQBp0UVmX2t2tp4i0zQTHNLfahFPOix gbY4Ydgklckj
5Q8sKYGWJlU7dodlANOiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigD
mqK4Xxx8RtK0jw94kl0u483VNM069mtjPZziznuLeF3aFZ9ojldTG+6NHLjy 5MgbG2xeD/Hc
dxFrM2p6/oWuabp8du6azokDi3llmeRPsiossxedSkR2q5ZvtMShASC/Fys0 O/orl/8AhYHh
MWU91LqU0C21ndX1xFPZTxTQQ2wiMxkidA6ELPCwVlDMsisoIOa6ilYYUUUU AFFFFAEtp/x9
Rf76/wA64b4oJvGnDy9/+tX7m772xcfcbru24/i3bdsu7yZO5tP+PqL/AH1/ nXDfFBN404eX
v/1q/c3fe2Lj7jdd23H8W7btl3eTJ1YP+ND1McR/DZxP+s/6ab/+B793/fe7 Pm/9NN3m/wDL
Xzf9P958Pv5nhTSZPM8zda2zb9+/dkLzu3vn672z/ebqfBv9Z/003/8AA9+7 /vvdnzf+mm7z
f+Wvm/6f7z4ffzPCmkyeZ5m61tm379+7IXndvfP13tn+83U+xmPwI4sH8TNa iiivLO4KKKKA
Pmnxb4O1fxn8UviPpFvp0thbeIZNNtIdUvtFugFjtwjzvFN5ezAaALsYospM ZWQbQH9J13wP
rOo/G9PGNxo/hvUtEGijR/JvLpzMEeQtLMEMDLnY8kezd8yk5YBiB6bRWzrN /wBf12PQnmFS
SSS0St+CXl0SPN/HfhvxnqnxQ8L+KNJsdAey8Ofa/LS51SaKS6+0QLGchbdx HtIPd9wx92qn
iL4Z3WpfGaz8URxaUdBkns9R1JJJ5hdyX1pFcx27oB8gQCWLIyM+X067vU6K lVWtvQyjjKkU
lHSycfk3f89Txj41fDTxx41n1+2stZtbjTdSgs0sIbnVLm1j05on3SgwRI0d z5hAO+TDKSAP
uiuk1Pwr4qPxPsvHemHRVuZvD39j3ltcTylLRzOJfOjKoDcAEsNh8nO0fMu7 5e5ub+C31C0s
ZI7ppbvf5bR2srxrsGTvkVSkfHTeV3HgZPFZWv8AjDQND1eDSL24updSmga5 S0srCe8mEKsF
MjJCjsqbiAGYAE5Azg01ObSSRpHE15RjCMb2T6dLJP8AJfP5nnni74S3es+O /FOqTQafqmle
JI7ISRXGq3loLV4E2ZeCDC3QGEcBnjwQQCud9exVS1nVLDR7OO71GfyIZLmC 1VtjNmWeZIYl
woJ+aSRFz0GcnABNT3FzHBLbxOsxa4kMaFIXcAhGbLFQQgwp+ZsDJC5ywBly lOy7HPWxE6qi
pPb/ACS/JI4X4l6imsS2nhHTtP1qfU49b0m6Zv7IuVtBFBe29zK32poxB8sU bnG/JYbBlyFr
mfi18MPE/il/FdvpFxZRR69bMIrp9bvrJbdvsyw+XLZ2wEV3uMf+vlYsFkCl JEhSN/Q/F3jb
w54V8z+2bm8Xybc3Vx9l064u/s0I3fvZvJR/KQ7Hwz7Qdj4ztbHR05UpxipS i0ns+/oc90ec
+IfBmv6x4is5g2mWei61FAfGFgtw7+Y9vho1g/dqsqy/8e87SqDJbxxoAuMV z/xa+GHifxS/
iu30i4soo9etmEV0+t31ktu32ZYfLls7YCK73GP/AF8rFgsgUpIkKRv7NUKX Vq97LZJcwtdR
RpLJCHBdEcsEYr1AYo4B6Eo2OhqLNjPMvFfhDxprniq28VC08P293pUVkbTT hqcxtdTcPvnW
+b7PllgJLWrBSUlzKQN2xe61f/hKv+En0P8Asn+xf7A/0j+2vtXm/a/uDyPs +35Pv537/wCH
GOa2aKQHk3j3wJ4n8Qa/rgtdN0W3stS2xxX8fiG+gIUwJGZbrTljNteurBht lYLLEsUT4UVN
8WPhxr/ivWdRuNI1uGxtNX0hNLv0d3U7BHfQ8qvEq41FptrFRvtIl/5amSH0 1Lq1e9lskuYW
uoo0lkhDguiOWCMV6gMUcA9CUbHQ1zmreP8AwxpWv3WiX8+ow3VnHHNdSf2T dtb28Umdssk4
jMSR/K+ZGYKux8kbWxrToVKjtCLb30XQTaW5n/EXTfGl/wCJfDN74c0rw/dW mi3zag7X+rzW
0krta3VsYwqW0oCgXCvv3ZJUrtH3q5/4i+BfFWv6548vNP0vwy39u+EU8Pab eXN/KlxDlpjK
XAt22IftJO1WbcbaPON+Y/WaKyGeAfF7T/E8mj+MvCEPh2y1K58bWy3pxY31 5FZ3n2OG2SBH
W2Fuf3lqjLcSzQeWZBI0eIxv9m1f/hKv+En0P+yf7F/sD/SP7a+1eb9r+4PI +z7fk+/nfv8A
4cY5rZooA8/8Q+F/FWpa5d2X2uyn0C91vT9Y+0T3kv2iw+yNav8AZYrfyyjI 72m4v5qbTcOd
jFf3kOpeArjXvizquu+ILSGXw9NpFpYwRQa5dxtcGGSZ3W5tUVIZon+0uu2R pBiP7pErBfRq
KAPGfi18MPE/il/FdvpFxZRR69bMIrp9bvrJbdvsyw+XLZ2wEV3uMf8Ar5WL BZApSRIUjefx
t4H8aeIr7xpfDRPCUV3r3g2Lw/aTvqszSWzkzGfLfZc+UTck8cubaLKrv/de v0UAeM+Jvhrr
+qavrt7caLZarD4j8qbULP8A4TjVNMt4W+yQ20lv5dvCUuEIhz5rqjMH2lAF Get+Ium+NL/x
L4ZvfDmleH7q00W+bUHa/wBXmtpJXa1urYxhUtpQFAuFffuySpXaPvV3NYFz 4w0C18YWnhK5
uLqHV73f9kjksJ1jn2R+Y+yYp5bbV5OGODweeKaTexUYSnflVzfrwb426brp tPHPg3S9Dh1l
fGsX2yGWXTL24W3uPskVtFENkBtwxe0RhNLcReUZA7IVjHmetXPjDQLXxhae Erm4uodXvd/2
SOSwnWOfZH5j7JinlttXk4Y4PB54rSh1Swm1y60SOfdf2ltDdTxbG+SKZpVj bOMHLQSjAORt
5xkZGmtwlCUbcytc8t8a/DPVNR8S+JbuHS4dc07xDKktzBN4z1LR41H2WK2a FoLaN45lKw7i
7YJEmwrhAT1mt6N4qtfHF54g8Mros/8Aamm2unXDajPLH9h+zy3LrMsaI32j P2psxl4f9UBv
+fKdnVK71SwtdUsdLmnxe33mG3hVGdmWNcu5AB2ouVBdsKGeNc7nUFEnGeIf C/irUtcu7L7X
ZT6Be63p+sfaJ7yX7RYfZGtX+yxW/llGR3tNxfzU2m4c7GK/vLt3o3irSNf1 e88KLotxDr9y
l1dvqc8qNYTrBFb+ZGkaEXCGOGI+UWhO5H/e4kHldnRQB5n4u8HeKr2Lxvoe lxaLLpPjTd9q
vrm+liuNP8yyhs32QLC6z7VhEgzLFuLFDtA3ml8RfAvirX9c8eXmn6X4Zb+3 fCKeHtNvLm/l
S4hy0xlLgW7bEP2knarNuNtHnG/MfrNFAHDXmk+NIPFUniPSLbw/9r1bSLPT 79Lq8mMenPA9
w/mRBYgbtc3TfIxtyREPmG87OZ8a/DPVNR8S+JbuHS4dc07xDKktzBN4z1LR 41H2WK2aFoLa
N45lKw7i7YJEmwrhAT6/RQB5N8RfAvirX9c8eXmn6X4Zb+3fCKeHtNvLm/lS 4hy0xlLgW7bE
P2knarNuNtHnG/MfQXmk+NIPFUniPSLbw/8Aa9W0iz0+/S6vJjHpzwPcP5kQ WIG7XN03yMbc
kRD5hvOzuaKAPOdS8BXGvfFnVdd8QWkMvh6bSLSxgig1y7ja4MMkzutzaoqQ zRP9pddsjSDE
f3SJWC8/8Wvhh4n8Uv4rt9IuLKKPXrZhFdPrd9ZLbt9mWHy5bO2Aiu9xj/18 rFgsgUpIkKRv
7NRQB5B428D+NPEV940vhonhKK717wbF4ftJ31WZpLZyZjPlvsufKJuSeOXN tFlV3/uoPE3w
11/VNX129uNFstVh8R+VNqFn/wAJxqmmW8LfZIbaS38u3hKXCEQ5811RmD7S gCjPs1FAHJ/E
O0un1Hwfq9vbTXUWk+II5riKCMvKUnt7izDqB/Cj3SSOSQFjSRuSACXNpdXn xhsL5LaaO00n
w/cwyzyRkRzPeXEBRI26MyCxcuDgqJYcZ3Hb1lFABXM6jpd+nxL0fxBbQefZ Npt1p94d6loG
Z4pYZFDn5EPlyo/l/M7PBuVljDRdNRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAeH+I/hdc6zpeoaHJ4hhh0eSTU7qxRbAm4gub6K5SRpJPN2y xr9snKoqRtxG
C52sX0Z/A2p6kmp3ut69Zza1df2f5M9npzQW0X2G5a5t90LTOz/vXbfiRdyY VdhBc91RXFzM
0seaav8AC651lZLnVfEML6k95Jq6SwWBjhg1VIYILO7jjMrNiGOA5id3WRpG LYAVR6XRRSbu
MKKKKACiiigCW0/4+ov99f51w3xQTeNOHl7/APWr9zd97YuPuN13bcfxbtu2 Xd5Mnc2n/H1F
/vr/ADrhvigm8acPL3/61fubvvbFx9xuu7bj+Ldt2y7vJk6sH/Gh6mOI/hs4 n/Wf9NN//A9+
7/vvdnzf+mm7zf8Alr5v+n+8+H38zwppMnmeZutbZt+/fuyF53b3z9d7Z/vN 1Pg3+s/6ab/+
B793/fe7Pm/9NN3m/wDLXzf9P958Pv5nhTSZPM8zda2zb9+/dkLzu3vn672z /ebqfYzH4EcW
D+JmtRRRXlncFFFFABRRRQAUUUUAeReO9A1X/heHhfxfongC6uYtK+1/2nfW z2Mcl95tsscW
C8yu+w5X95twM7cisrWPBQl+ON54mn+EH9paC+kvaPH5WmN9pvTcmQ3Wx5hn cn8bYfnBAr3K
itVWa+6x3QzCpFJJLRcvXa9+5xnxL/0fV/A2rTfLZWHiRPtMnXy/tFpdWcPA 5O6e5gTgHG/J
woYjB+LH/CDapr2mWkf/AAjl744tNZ0jyYl8mTVIYUvoJpNo5lVBCZJDjgIW Y8ZNeo0VeFr/
AFeoqmunZ2+/y7o4JK6scW0Wv+G/EWvT6Z4fm12PX7xLyKWK6hgSzlW2gtyl x5jBhH+4R/Mi
WVsM48vKL5nLePfCOoajqvigjwb/AGvq+qf8i94hzan+w82sUUf7yWRZ4fLu Eln/AHCPjzNy
5cso9XuLq1t5beKe5hikuZDFbo7hTK4RnKqD947UdsDnCk9AazvEfijwz4a8 j/hIvEWkaN9p
3eR9vvY7fzduN23eRuxuXOOmR611YfGVoVE6cLytbrqlbs+lunne5Liranlv xI8HahqPivxz
q2meBLy5vrnw9bQ6NfxXFrGranGZwtyoaZSs0Ymh2TsodFhlCEZUSbGreF0/ 4WK3jX/hWVnr
F9qWnWAt2nWzWXTL2B5iZLiRmJXiSBfMg85sQHAO2MN6jRT/ALVrcqjZaK28 trRVt/7qeltb
9NA9mjxH4h+ANQ1Tx3rGr3ul+KdTFzJE+mXejJoxewiWCNNiTXwFxBIJVlkH ksFUyK6kOXxL
8SPB2oaj4r8c6tpngS8ub658PW0OjX8Vxaxq2pxmcLcqGmUrNGJodk7KHRYZ QhGVEntNFXDO
a8OWyXuq3VaXi9bNfyq/zE6aPLtW8Lp/wsVvGv8AwrKz1i+1LTrAW7TrZrLp l7A8xMlxIzEr
xJAvmQec2IDgHbGGl1zwpqniT4o68moJrun+Gb3QrTT53gksvs+phJLlpYX3 b7hAUudoZBEe
JfmGIyfTKKx/tKqtbK9rdXZK1rXdk1ZW0899R8iPC/jN4C8S67rmu6lpGi3l xq724bQ7+BtO
EVuUgXaGmuke6gmEqyFRbbI8tG26N2llE3jrwpqms6/4z16y+HWorqV74atE 0i4NzZIU1RPO
AmwLjCzwieELORuQQSiNsFRJ6jd+M/B9nr6+H7vxXoVvrDSJEthLqES3Bd8F F8stuy25cDGT
kY61u11LNsTRhBOCVlpurr3X3V17q/EXs4u+p4X428C6prni7Ude1LQfF9w9 75E2nPpa6I0+
lxi3iUxCa7JlhmWZZXzbyFAXDo28sa90oorhxWNniYQhJJKKsrfL/IqMUjzP xt8F/DXizxPd
+INQutlzdbN6/wBhaPcY2oqD95cWUkrcKPvOcdBgAAHjb4L+GvFnie78Qahd bLm62b1/sLR7
jG1FQfvLiyklbhR95zjoMAAD0yiuMoK+c/G/ww8RajqXxR1rRPCEVpqd/d6Z N4buRJbRziSK
QG5midXzCWILkkqzbhn5sgfRlFaU6jg7o6sLi54aTlDrb8Gn+n3Hzd8Tvhr4 m1P/AIWD/ZHg
f7R/wlf9lX2nbJbNPsFxDn7QJt0o2yndJlo94bzD83JrtPFyeLdX+KHgfxRb fD7X0stA/tD7
Wkl3p4kfz4FjTYBdEHBHOSOOma9doqvbPt/VrGzzKo0k4p2TXXrFRfXsjyLx cni3V/ih4H8U
W3w+19LLQP7Q+1pJd6eJH8+BY02AXRBwRzkjjpmul82TUvjJos6W0sEmneF7 t9QglK77U3lx
am3VipKsW+xXQOwsB5XJwyFu4qG4u7W2mtobi5hhlupTDbpJIFaZwjOUQH7z bEdsDnCsegNR
KXMkrbHNVr+0jGNkuVW0v3b6t9WTVyeqWl1F8WdC1Zraa4sZdIvbATCMstnM 0lvKB8n3VlSJ
9zyZUG3iVSjSES9ZRUGAUUUUAFFFFABRRUNxd2ttNbQ3FzDDLdSmG3SSQK0z hGcogP3m2I7Y
HOFY9AaAJqKKKACiisbxP4s8K+F/s/8Awk3iXRdE+07vs/8AaN9Fb+btxu27 2G7G5c46ZHrQ
Bs0Vz97438F2XiJfDl54v8P22tNLHCunS6lClyXkwUQRFt25ty4GMncMda6C gAooooAKKpXe
raVZ6pY6Xd6nZW9/qHmfYrWWdVlufLXdJ5aE5fapBOAcDk1Pe3drZQrNeXMN tE0scKvLIEUv
I4REBP8AEzsqgdSWAHJoAmoqFLu1e+lsUuYWu4YkmlgEgMiI5YI5XqFYxuAT wSjY6GpqACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAOaooorhNQooooAK KKKACiiigCW0
/wCPqL/fX+dcN8UE3jTh5e//AFq/c3fe2Lj7jdd23H8W7btl3eTJ3Np/x9Rf 76/zrhvigm8a
cPL3/wCtX7m772xcfcbru24/i3bdsu7yZOrB/wAaHqY4j+Gzif8AWf8ATTf/ AMD37v8Avvdn
zf8Appu83/lr5v8Ap/vPh9/M8KaTJ5nmbrW2bfv37shed298/Xe2f7zdT4N/ rP8Appv/AOB7
93/fe7Pm/wDTTd5v/LXzf9P958Pv5nhTSZPM8zda2zb9+/dkLzu3vn672z/e bqfYzH4EcWD+
JmtRRRXlncFFFFABRRRQAUUUUAFFFFABRRRQBwvxY09YodM8QW9/q9tfQ6zp Fsot9VuYoGjk
1GBHV4EcRPuSR1JZSSDjsMQ3rx6L4i8Upr2gajrkfiGSNbFbbTnvEnthbRxG ykbGyECXz3xM
Uhxclt+TLs6n/hF/DP8Awkn/AAkv/CO6R/bn/QS+xR/avubP9bjf9z5evTjp WvXfHFqMFDV6
enZ2W+ia/F6Lcjl1ueRePf7W/tXxRj/hL/8AhIf+ZQ/s/wC3fYf+PWLyvO8n /Rf+Pvzt32n+
HG/91tqn8SH1aHxX45vNLuPHQmsvD1tdaTb2cF89nLqqmdVKBUKPgPa7olPl PudpEcxsye00
VrSzLk5fdvZW3/w+W3u7d22Dhc8o1Sysbf4oz+MJ9O8aXMeqaVpzaZFYSagg luIpLgtDNErL
HANslv8ALciOPLyE4PnGsj4hweK38d6xNL4l13R4kki/sVrHQNX1FEhEEZ8w iznW3Yifz/ku
I3YgDdujKLXt1FFPM5QmpWvZcu6eita100tFrprd7A4XPFviQ+rQ+K/HN5pd x46E1l4etrrS
bezgvns5dVUzqpQKhR8B7XdEp8p9ztIjmNmTS1Sysbf4oz+MJ9O8aXMeqaVp zaZFYSaggluI
pLgtDNErLHANslv8tyI48vITg+ca9XooWZNRUUmtLOztpaPl3j+LXmHIeUeJ tI1XxR8UfFXh
+C4m07R9S8NWen6jPPodw4uE8y781La6LJCkix3SckSjLfdPluKwvjN/wm6a 5rt9oE/iNNQt
LcS6LaWljf3EVwEgV96vBPFaLiTzQYrlJpGKHiRZIoa90op0c0lSnGXKmkkr aeV+nW1n5aJo
ThdHiPjq71KbX/Ger6LN8QEaHw1aX2jWsFlqK28mp/vghEZjwSoe0Dwf6s7n MsbGNjHD42Pi
e/8AF2o6kPEfiPRLaTyJdC+z+GtZu/LgNvE2947WZId4nM2YrmJn4w4MZRR7 pRVU81ULWhsr
dHpaPeLX2e3VoHC4V5n42+HXiXXvE93qun+M/wCzrafZstvO1hdm1FU8W+pw xckE/LGvXnJy
x9MoryDQK+c/G9v45XUvijrHhxvHPnadd6ZJ4cQS3xieQyD7X5UDnZNHuDZG 1kC42jaRX0ZR
WlOfIzqwuJ+rybte9vwaf42t6NngfjOLx7q/xG1qe11zxTo2nyQadN4aNpo9 5Mr/AClpEZFk
jgjcyAq4vR91hnYozWL4k0H4i22t694X0zU/HLWk/iGzgstWW6vZBb29ztkE ikud0dqqTRP8
+JDcKzlWiQV9LUVartdDphmUoWSirJL8La7eXXq2yKzt47S0htYmlaOGNY1M srSuQBgbnYlm
PqWJJ6kk1wnxg05IYNK8SW2oa1a38Gt6NaqLbV7mG3eKTU7eORXgSQRSbkld SWQkggdhj0Cs
b/hE/Cv/AAk//CU/8I1ov9v/APQU+wxfa/ueX/rdu/7ny9fu8dKwPMep4z8b /wDhPE1/xBf+
HbjxMmpWdsJdCs7Ow1C5iuQkCvvV4LiGzTEvmgw3KTSsUPEqSQw1s+JdM1h9 cudE0WTxm+ne
Pvs9zBqRvdQQ6D5beZdglmBst0RUwR7fmmLxyjylVF9mooA+efjBa+ONP1HW X8L3Xi0X2l2K
f8I/axW2p363SxW6sJDNHcx2u4SCUGO7WeaQoTiVZIYa2vHdzql74qurzSF8 cr4Wni0yXxIs
MOpQ3QDPmAaYigMjcj7YqAERYCgTb69sooAxtX1/+zvE+h6F/YmtXf8Aa/2j /TrW132ll5SB
/wDSJM/u9+dqcHcwI4rx/wCMEGtat4t1m20rU/HMF1FElvZ2dpp+rQRXDmFW UW17azJZxKWf
b5t1HKY5BIX3RKiD3migDwz416T42XxPr7eGI/E00et6JFb2r2mqXix2t0qX Y8yJY5RHA5uB
pKkkBTG87H5BcOvQeP7m28NeOfBEtovjmdbKUxagLKHVtQtmsfsd2iGYRiSK WXzzBlm3TfdY
nbzXqdFAHhnxPfWIPF/j+90m5+IAmsfDdrd6PbWVvqEllNq6mdVMYVCkmA9o GhUmF9ztKjmN
mjp/GHVNSXw9471sT/ECy1MabJdeGJdNS8treGx/s+NnaYELbRuJftZYTgXK gDy8OIK9/rG1
Xwn4V1bXLTXdU8NaLf6tZ7Pst9c2MUlxBsYumyRlLLtYlhgjBJI5oAguNWj0 HWfDnhaHR/EF
9FfxTRJqCRvcwWYgjDA3U7sWDP0Vm3F2zk55rk/HV9rerahP4Tm0a9Mw8SaP eaVLBYTNby2E
FxZXE8ktyAYY3VorsBGZGIRAFJdC/plFAHkHirRdX8WfFnxd4ct7mbTdF1Pw tZabqVxPoFzI
tynmXnnJbXRZIUlWO6TkiUZf7p8t1rn/AI3/APCeJr/iC/8ADtx4mTUrO2Eu hWdnYahcxXIS
BX3q8FxDZpiXzQYblJpWKHiVJIYa9/ooA8G+IF5qk/iLxvrWhz/EZGg8LWeo aJaQWOpLbSar
+/CFYzHgsoktA9v/AKtt0hmjZo3McPjtvFeoeM9T1MeJvE2hWsn2eXw/9m8L a3e+Xbm2ibe8
VpMkG8XBnzDdQs/ygODGUUe/0UAec/FbWoLDxh4HD6b4gul0/V5L+6ksNCvL yOKFtPvoAS8M
Tru8yRBsB3AMCRt5rT+Jf/IX8DfaP+Qb/wAJIn23zP8AU/8AHpdfZ/Mz8v8A x9fZdmf+Wvlb
fn212dQ3tpa3sKw3ltDcxLLHMqSxh1DxuHRwD/ErqrA9QVBHIoA5K8/5Lfpf 2T/oW7z+0/K/
6+bX7H52P+37yt3/AE8bf46h1+7tb34y+GtJgufFv27TLG4v7qHT5BHpYhmB ijN9ux5jF45P
KRNzBkdiAoJrs0tLVL6W+S2hW7miSGWcRgSOiFiiFupVTI5APALtjqamoAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooA8y8V6prg8TaV4a8P3GnWV1e2d3 fPd31o90ipA9
uhjESSxHLG5B3b8AIRtO7K8X4Y+JfibW7BfEv9n6Ra6GNR0e0+y5kkupP7Qg sWx5mVRPJe93
btreaBt2xEb217PxH4b+IFhoMPiXwBeDSdb23GkSa5bWVxBcSGB5k2oksrI5 hErAuqgAMCQS
FPdSaXpknneZp1m/n3Ed1NugU+ZNHs8uVuOXXyo8MeR5a4+6Mce25oW6KKKk YUUUUAFFFFAE
tp/x9Rf76/zrhvigm8acPL3/AOtX7m772xcfcbru24/i3bdsu7yZO5tP+PqL /fX+dcN8UE3j
Th5e/wD1q/c3fe2Lj7jdd23H8W7btl3eTJ1YP+ND1McR/DZxP+s/6ab/APge /d/33uz5v/TT
d5v/AC183/T/AHnw+/meFNJk8zzN1rbNv3792QvO7e+frvbP95up8G/1n/TT f/wPfu/773Z8
3/ppu83/AJa+b/p/vPh9/M8KaTJ5nmbrW2bfv37shed298/Xe2f7zdT7GY/A jiwfxM1qKKK8
s7gooooAKKKKACiiigAooooAKKKKAOF+KltqFrJoviK01y8g+yazpkC2P2a1 kgbz7yO2lfdJ
C0qOYbiRMpIuAfds4XjC18EX3iLxFZfFa2066W4kWLw9DfpveS0a2iDrZKPm M5uDOGEP78kw
548iu6u/CejXmvrrV2NRuLhZElWCXVLlrQOmNjfZTJ5OVKqwOzIcBx8wzW7X pU8bGlGKje6T
1VotbPRq+zT1fdkONzyLx74u1DTtV8UAeMv7I1fS/wDkXvD2LUf25i1ilj/d yxtPN5lw8sH7
h0z5e1cOGY0/iR421DQ/Ffjn7L8QbO1h8PeHrbWIdKlW1LNdEzr9nZiu8QuR bb0/1ha4i2SR
hgre00VVLH0Yct6Sdlbpr8P919n3fvPXoDg+55RqmtQWfxRn1a9+JOo2Gg32 laddaRZwvayW
+qN5lx5sNsphd5iy+QSISZW89BkgxBcj4h+MvFlh471i0h8YeFvDUFjJEum2 2s63BYpeoYI5
DM8UlpLJLGZXkjLRTRAiJlGx1Zz7dRRTzClGalKkpWVtbdLWfw76a3vv0Bwf c8W+JHjbUND8
V+OfsvxBs7WHw94ettYh0qVbUs10TOv2dmK7xC5FtvT/AFha4i2SRhgraWqa 1BZ/FGfVr34k
6jYaDfaVp11pFnC9rJb6o3mXHmw2ymF3mLL5BIhJlbz0GSDEF9XooWPpcqj7 NbWfw9o/3d7q
93d6v1Dkfc8L8ZaDpnib44eKNH0XT/CEmuS+HrAyalPcKmo6TNvul+1wIsTO 80aNbN9+Ijbb
jeAylT4zePfFHhzXNduNL1+ztf7HtxPbaRPcRwy3ypAsrSLb/ZZprmHJdWlS WBQI5FPl+U0z
e6UVpDNIc8HVp80YpKzfor7O22yWgnDszxHx18QJrHX/ABne6P8AEnTv7P0b w1aa7Z2ANpIJ
p284LD5mNxgkxbFl5kJuIvLkjDBWh8bePPEY8Xai2meOfCGh6fD5D6Omqa9b 2kGowvbxSi4K
PaSyTwtI8ib4Z4wRGVXaylz7pRSp5jh42vQTsra27R1+HfR733YOD7mNq/in QtJ8T6H4Z1C+
8nVte+0f2bb+U7ef5CB5fmAKrtUg/MRntk14/wDGDxrrlt4t1nTPD/xK0zTb iwiSFdJgu7VN
R85oVkVIrK4tJWvpX8xCgjnhVyyxfIytI3vNFeQaHg3xJ8b+MNO+IOtWcHjX wl4WgsJYV0y1
1zXbewjvkNvFIZniks5ZZojK8sReKeIERMg2OrOeg8Sai+hfGe/udd+I2taJ pM2m6dLpul4t
mi1GZZboT21vG8DSyuQINywnziZ0GcGFV9ZooA8T1/xj8NvAnxt8eeI9Yv8A w/a6pbeFtOaR
Fmt0v7l1e9eSFAzKzytGlp8mckCDPGysz43/ABC8WeGdf8QXGk+IrK0/sW2E 9ro1xcxQy36p
AszSLbfZJ57qHJdXljmt1URSqfL8l529/ooA8g+IereKotWupfDXjDU5LTxR pECeE2sbaznt
YL8yoGdnMDM0TRvHNw0h8mO+cAeXHil418Watolz4ltpfiFNZa9osSJ4e0OZ bFZPEhWzilR2
iaHzZmmuWlgP2YxgmPYgVwTXqeo+GNI1DxPpviS8S9lv9MybMfb5xbxsUkjL +QH8ovsmkXeU
LYbGeBjZoA8Z+M3jHV/CP/CfA+LL3TXPhuDUPDMYtIJH+2R/avtEcCmFjMgW K3eXcH8pJWct
GpBWfVtdt7L4s3GsX3xQ1PTvD1/pGmXejWUD2kttqr+Zc+bDaqYXknZlEBIg Jlb7QgyQYQvr
9FAHGfEv/SNX8DaTN81lf+JE+0x9PM+z2l1eQ8jkbZ7aB+CM7MHKlgfJvG/x B8XaTqXxR1LS
PGMt3aeEbvTDY2ht7R4H+0SATwSssQkIQ7kG11cYILFgTXv+s6XYaxZx2mow efDHcwXSrvZc
SwTJNE2VIPyyRo2Ohxg5BIq7WlOai9Vc6sLXhRk3KCltv6p9nulb5ngfjPx7 41m+I2tWHh/x
RoGl2FrBp1xokd7Moj1eOVTI7RosEst3vIaMCB4yCFA3MTWL4k8Z/EvStb17 whD4ylk1eLxD
Z6Zp91JZ2pjUXm17QPiAZHlC584hSQ6wbPlMmfpairVWK+ydMMfSjZeyTsl2 3VtdvJ39SKzi
kgtIYJbmW6kjjVGnlCh5SBgswUKuT1O0Ac8ADiuE+LltqNrLofiWy1+9t/se t6VbpYfZbSS3
b7Rex20sm6SFpkcw3MiZSRcA+7Z9Arn73wdod74iXXbwanc3CyxzLby6tdPZ h48bHFqZPI3K
VVwdmQ6hx8w3VgeYzyD43/ELxZ4Z1/xBcaT4isrT+xbYT2ujXF
Re: tree cannot be painted in the VE [message #607278 is a reply to message #89099] Sun, 01 May 2005 22:29 Go to previous message
> jTree = new JTree()
> to the following: jTree = new JTree(rootNode);
> the tree cannot be painted in the VISUAL EDITOR!
> Can you explain this with code sample?
Tischer,
private JTree getJTree() {
if (jTree == null) {
return jTree;
at design time.
Hope this helps,
- Jeff
Re: tree cannot be painted in the VE [message #607279 is a reply to message #89129] Mon, 02 May 2005 05:47 Go to previous message
> Tischer,
new JTable(){
return false;
will fail for VE.
Jiawei Ye
Re: tree cannot be painted in the VE [message #607280 is a reply to message #89144] Mon, 02 May 2005 05:48 Go to previous message
Re: tree cannot be painted in the VE [message #607283 is a reply to message #89099] Mon, 02 May 2005 10:06 Go to previous message
Tischer wrote:
> public class visual extends JFrame {
> private javax.swing.JPanel jContentPane = null;
> private JTree jTree = null;
> TreeNode rootNode = createNodes();
> return jTree;
> private TreeNode createNodes() {
> DefaultMutableTreeNode root;
> DefaultMutableTreeNode grandparent;
> DefaultMutableTreeNode parent;
> DefaultMutableTreeNode child;
> root = new DefaultMutableTreeNode("San Francisco");
> grandparent = new DefaultMutableTreeNode("Potrero Hill");
> root.add(grandparent);
> parent = new DefaultMutableTreeNode("Restaurants");
> grandparent.add(parent);
> child = new DefaultMutableTreeNode("Thai Barbeque");
> parent.add(child);
> child = new DefaultMutableTreeNode("Goat Hill Pizza");
> parent.add(child);
> return root;
visual component.
name="scrape.jpg"
Previous Topic:tree cannot be painted in the VE
Next Topic:jLabel.setFont(font);
Current Time: Thu Nov 13 12:35:47 EST 2025
Powered by FUDForum. Page generated in 0.09701 seconds
