Home » Archived » M2M (model-to-model transformation) » helper produces execution error:java.lang.RuntimeException.Can you help me,pleas
helper produces execution error:java.lang.RuntimeException.Can you help me,pleas [message #88968] Tue, 26 August 2008 03:15 Go to next message
I have a helper that return a enumeration, the code is:
helper def :getCardinality (cardinality: Logical!CardinaltyType) :
MCD_MetaModel!TipoCardinalidad =
if (cardinality=#ZERO_TO_MANY) then
#cero_a_muchos
else
#cero_a_uno
endif;
But this code produces a execution error:java.lang.RuntimeException
I want to know how I create a helper that reurn a helper and run OK.
Thank you.
[ATL] Re: helper produces execution error:java.lang.RuntimeException.Can you help me,pleas [message #89033 is a reply to message #88968] Tue, 26 August 2008 04:49 Go to previous message
Can you please remember to prefix the subject of your ATL-related posts
with [ATL] as I just did in this reply? Thanks.
Your helper has no context, do you call it using "thisModule." ?
Like here :
to var : MM!Element (
cardinality <- thisModule.getCardinality (input.cardinality)
Otherwise, check that there is no typo in "#cero_a_muchos" or "#cero_a_uno".
William
Amalia Garcia a écrit :
> Hello,
> MCD_MetaModel!TipoCardinalidad = if (cardinality=#ZERO_TO_MANY) then
> #cero_a_muchos
> else
> #cero_a_uno
> endif;
> Thank you.
Previous Topic:[ATL]How to get the element type by the element's attribute?
Next Topic:Question about EMFVM
Current Time: Wed Jul 16 08:25:56 EDT 2025
Powered by FUDForum. Page generated in 0.46720 seconds
