Home » Language IDEs » Java Development Tools (JDT) » Exception occured during launch: Reason: Source locator does not exist: org.eclipse.jdt.debug.ui.jav
Exception occured during launch: Reason: Source locator does not exist: org.eclipse.jdt.debug.ui.jav [message #88959] Mon, 25 August 2003 14:35 Go to next message
I'm getting this error when trying to launch or debug an application
under Eclipse. Restarting Eclipse doesn't seem to help. This occured
after Eclipse apparently froze under the debugger (while paused) and I
had to kill the process (under X-windows, with CTRL+ALT+ESC+click).
I am unable to work because of this problem. Any help appreciated. I've
attached my Eclipse/System configuration file. BTW this is a RedHat 9.0
installation.
*** Date: 8/25/03 11:32 AM
*** System properties:
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/java/eclipse-2.1.1/startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/java/j2sdk1.4.1_03/jre/lib/endorsed
java.ext.dirs=/usr/java/j2sdk1.4.1_03/jre/lib/ext
java.home=/usr/java/j2sdk1.4.1_03/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/j2sdk1.4.1_
03/jre/lib/i386/client:/usr/java/j2sdk1.4.1_
03/jre/lib/i386:/usr/java/j2sdk1.4.1_03/jre/../lib/i386
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.1_03-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesF
actory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.1_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.1_03-b02
line.separator=
os.arch=i386
os.name=Linux
os.version=2.4.20-18.9
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/java/j2sdk1.4.1_
03/jre/lib/rt.jar:/usr/java/j2sdk1.4.1_
03/jre/lib/i18n.jar:/usr/java/j2sdk1.4.1_
03/jre/lib/sunrsasign.jar:/usr/java/j2sdk1.4.1_
03/jre/lib/jsse.jar:/usr/java/j2sdk1.4.1_
03/jre/lib/jce.jar:/usr/java/j2sdk1.4.1_
03/jre/lib/charsets.jar:/usr/java/j2sdk1.4.1_03/jre/classes
sun.boot.library.path=/usr/java/j2sdk1.4.1_03/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=unknown
user.country=US
user.dir=/home/josh
user.home=/home/josh
user.language=en
user.name=josh
user.timezone=America/Los_Angeles
*** Features:
org.eclipse.jdt (2.1.1) "org.eclipse.jdt"
org.eclipse.jdt.source (2.1.1) "org.eclipse.jdt.source"
org.eclipse.pde (2.1.0) "org.eclipse.pde"
org.eclipse.platform (2.1.1) "org.eclipse.platform"
org.eclipse.platform.linux.gtk (2.1.1) "org.eclipse.platform.linux.gtk"
org.eclipse.platform.linux.gtk.source (2.1.1)
"org.eclipse.platform.linux.gtk.source"
org.eclipse.platform.source (2.1.1) "org.eclipse.platform.source"
org.eclipse.sdk.linux.gtk (2.1.1) "org.eclipse.sdk.linux.gtk"
*** Plug-in Registry:
org.apache.ant (1.5.3) "Apache Ant"
org.apache.lucene (1.2.1) "Apache Lucene"
org.apache.xerces (4.0.13) "Xerces Based XML Parser"
org.eclipse.ant.core (2.1.1) "Ant Build Tool Core"
org.eclipse.compare (2.1.0) "Compare Support"
org.eclipse.core.boot (2.1.1) "Core Boot"
org.eclipse.core.resources (2.1.1) "Core Resource Management"
org.eclipse.core.resources.linux (2.1.0) "%linuxFragmentName"
org.eclipse.core.runtime (2.1.1) "Core Runtime"
org.eclipse.debug.core (2.1.0) "Debug Core"
org.eclipse.debug.ui (2.1.1) "Debug UI"
org.eclipse.help (2.1.1) "Help System Core"
org.eclipse.help.appserver (2.1.0) "Help Application Server"
org.eclipse.help.ui (2.1.1) "Help System UI"
org.eclipse.help.webapp (2.1.1) "Help System Webapp"
org.eclipse.jdt (2.1.1) "Eclipse Java Development Tools"
org.eclipse.jdt.core (2.1.1) "Java Development Tools Core"
org.eclipse.jdt.debug (2.1.0) "JDI Debug Model"
org.eclipse.jdt.debug.ui (2.1.1) "JDI Debug UI"
org.eclipse.jdt.doc.isv (2.1.0) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (2.1.0) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (2.1.1) "Java Development Tools JUnit support"
org.eclipse.jdt.launching (2.1.1) "Java Development Tools Launching
Support"
org.eclipse.jdt.source (2.1.1) "Eclipse Java Development Tools SDK"
org.eclipse.jdt.ui (2.1.1) "Java Development Tools UI"
org.eclipse.jface (2.1.1) "JFace"
org.eclipse.jface.text (2.1.0) "JFace Text"
org.eclipse.pde (2.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.build (2.1.0) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (2.1.0) "Plug-in Development Core"
org.eclipse.pde.doc.user (2.1.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.runtime (2.1.0) "Plug-in Development Environment Runtime"
org.eclipse.pde.source (2.1.0) "Eclipse Plug-in Development Environment
Source Code"
org.eclipse.pde.ui (2.1.0) "Plug-in Development UI"
org.eclipse.platform (2.1.1) "Eclipse Platform"
org.eclipse.platform.doc.isv (2.1.0) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (2.1.1) "Eclipse Workbench User Guide"
org.eclipse.platform.linux.gtk (2.1.1) "Eclipse Platform (Linux GTK)"
org.eclipse.platform.linux.gtk.source (2.1.1) "Eclipse Platform Plug-in
Developer Resources (Linux GTK)"
org.eclipse.platform.source (2.1.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk.linux.gtk (2.1.1) "Eclipse Project SDK (Linux GTK)"
org.eclipse.search (2.1.1) "Search Support"
org.eclipse.swt (2.1.1) "Standard Widget Toolkit"
org.eclipse.swt.gtk (2.1.1) "%fragmentName"
org.eclipse.team.core (2.1.1) "Team Support Core"
org.eclipse.team.cvs.core (2.1.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (2.1.1) "CVS SSH Core"
org.eclipse.team.cvs.ui (2.1.1) "CVS Team Provider UI"
org.eclipse.team.ui (2.1.0) "Team Support UI"
org.eclipse.text (2.1.0) "Text"
org.eclipse.tomcat (4.0.6.1) "Tomcat Wrapper"
org.eclipse.ui (2.1.1) "Eclipse UI"
org.eclipse.ui.editors (2.1.0) "Default Text Editor"
org.eclipse.ui.externaltools (2.1.1) "External Tools"
org.eclipse.ui.versioncheck (2.1.1) "Eclipse Version Check"
org.eclipse.ui.views (2.1.0) "Views"
org.eclipse.ui.workbench (2.1.1) "Workbench"
org.eclipse.ui.workbench.texteditor (2.1.0) "Text Editor Framework"
org.eclipse.update.core (2.1.0) "Install/Update Core"
org.eclipse.update.core.linux (2.1.0) "%fragmentNameLinux"
org.eclipse.update.ui (2.1.1) "Install/Update UI"
org.eclipse.update.ui.forms (2.1.0) "Install/Update Forms"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Mon Aug 25 11:32:20 PDT 2003
org.eclipse.team.ui/pref_always_in_incoming_outgoing=true
org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.visib ilityCheck=en
abled
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.complianc e=1.4
org.eclipse.ui/defaultPerspectiveId=org.eclipse.jdt.ui.JavaP erspective
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1. 4
org.eclipse.team.cvs.ui/pref_text_ksubst=-kkv
org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.cuchildren=fa lse
org.eclipse.ui=2.1.1
org.eclipse.jdt.ui/outlinesortoption=T,SI,SF,SM,I,F,C,M,
org.eclipse.ui.workbench/org.eclipse.jface.textfont=1|Courie r|10|0|GTK|1
org.eclipse.search=2.1.1
org.eclipse.ui.workbench/ENABLED_DECORATORS=org.eclipse.pde. ui.binaryProj
ectDecorator\:false,org.eclipse.team.cvs.ui.decorator
\:true,org.eclipse.ui.LinkedResourceDecorator\:true,
org.eclipse.team.cvs.ui/pref_compression_level=3
org.eclipse.ui.editors=2.1.0
org.eclipse.search/org.eclipse.search.reuseEditor=true
org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0"
encoding\="UTF-8"?>\n<org.eclipse.ui.commands><activeKeyConfiguration
value\="org.eclipse.ui.defaultAcceleratorConfiguration"/>
</org.eclipse.ui.commands>
org.eclipse.team.cvs.ui/pref_filetext_decoration={dirty_flag }{name}
{revision} {tag}
org.eclipse.ui.workbench/RECENT_FILES=8
org.eclipse.ui.workbench/WELCOME_DIALOG=false
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathContainer .local|org.ec
lipse.jdt.launching.JRE_CONTAINER=<?xml version\="1.0" encoding\="UTF-
8"?>\n<classpath><classpathentry kind\="lib" path\="/usr/j2sdk1.4.1_
02/jre/lib/rt.jar" rootpath\="" sourcepath\="/usr/j2sdk1.4.1_
02/src.zip"/><classpathentry kind\="lib" path\="/usr/j2sdk1.4.1_
02/jre/lib/sunrsasign.jar" rootpath\="" sourcepath\="/usr/j2sdk1.4.1_
02/jre/lib/jsse.jar" rootpath\="" sourcepath\="/usr/j2sdk1.4.1_
02/jre/lib/jce.jar" rootpath\="" sourcepath\="/usr/j2sdk1.4.1_
02/jre/lib/charsets.jar" rootpath\="" sourcepath\="/usr/j2sdk1.4.1_
02/jre/lib/ext/sunjce_provider.jar" rootpath\="" sourcepath\=""/>
02/jre/lib/ext/dnsns.jar" rootpath\="" sourcepath\=""/><classpathentry
kind\="lib" path\="/usr/j2sdk1.4.1_02/jre/lib/ext/localedata.jar"
rootpath\="" sourcepath\=""/><classpathentry kind\="lib" path
\="/usr/j2sdk1.4.1_02/jre/lib/ext/ldapsec.jar" rootpath\="" sourcepath
\=""/></classpath>
org.eclipse.jdt.ui/hoverModifiers=org.eclipse.jdt.ui.BestMat chHover;0;org
..eclipse.jdt.ui.JavadocHover;\!0;org.eclipse.jdt.ui.Problem Hover;\!
0;org.eclipse.jdt.ui.JavaSourceHover;Ctrl;org.eclipse.jdt.in ternal.debug.
ui.JavaDebugHover;\!0;
org.eclipse.ui.editors/lineNumberRuler=true
org.eclipse.ui.externaltools=2.1.1
org.eclipse.team.ui=2.1.0
org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_ XML= <?xml
version\="1.0" encoding\="UTF-8"?>\n<vmSettings\n defaultVM
\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\n <vmType id
\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n
<vm id\="0" javadocURL\="http\://java.sun.com/j2se/1.4.1/docs/api"\n
name\="j2sdk1.4.1_02" path\="/usr/j2sdk1.4.1_02"/>\n </vmType>\n
</vmSettings>\n
org.eclipse.jdt.core=2.1.1
org.eclipse.jdt.ui/PackagesView.pkgNamePatternForPackagesVie w=.
org.eclipse.team.cvs.ui=2.1.1
org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier|10|0 |GTK|1|;
org.eclipse.ui.workbench/editors=<?xml version\="1.0" encoding\="UTF-8"?>
\n<editors><descriptor class
\=" org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetE ditor " id
\="org.eclipse.jdt.debug.ui.SnippetEditor" image
\="icons/full/obj16/jsbook_obj.gif" internal\="true" label\="Scrapbook"
open_in_place\="false" plugin\="org.eclipse.jdt.debug.ui"/><descriptor
class\="org.eclipse.ui.editors.text.TextEditor" id
\="org.eclipse.ui.DefaultTextEditor" image
\="icons/full/obj16/file_obj.gif" internal\="true" label\="Text Editor"
open_in_place\="false" plugin\="org.eclipse.ui"/><descriptor class
\="org.eclipse.pde.internal.ui.editor.schema.SchemaEditor" id
\="org.eclipse.pde.ui.schemaEditor" image
\="icons/full/obj16/schema_obj.gif" internal\="true" label\="Extension
Point Schema Editor" open_in_place\="false" plugin
\="org.eclipse.pde.ui"/><descriptor class
\=" org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor " id
\="org.eclipse.jdt.ui.CompilationUnitEditor" image
\="icons/full/obj16/jcu_obj.gif" internal\="true" label\="Java Editor"
open_in_place\="false" plugin\="org.eclipse.jdt.ui"/><descriptor class
\="org.eclipse.pde.internal.ui.editor.feature.FeatureEditor " id
\="org.eclipse.pde.ui.featureEditor" image
\="icons/full/obj16/ftr_xml_obj.gif" internal\="true" label\="Feature
Manifest Editor" open_in_place\="false" plugin\="org.eclipse.pde.ui"/>
<descriptor class
\="org.eclipse.pde.internal.ui.editor.manifest.ManifestEditor " id
\="org.eclipse.pde.ui.manifestEditor" image
\="icons/full/obj16/plugin_mf_obj.gif" internal\="true" label\="Plug-in
<descriptor class
\=" org.eclipse.pde.internal.ui.editor.build.BuildPropertiesEdit or " id
\="org.eclipse.pde.ui.buildEditor" image
\="icons/full/obj16/build_exec.gif" internal\="true" label\="Build
Properties Editor" open_in_place\="false" plugin\="org.eclipse.pde.ui"/>
<descriptor class
\=" org.eclipse.ui.externaltools.internal.ant.editor.PlantyEdito r " id
\="org.eclipse.ui.externaltools.internal.ant.editor.AntEditor " image
\="icons/full/obj16/ant_buildfile.gif" internal\="true" label\="Ant
Editor" open_in_place\="false" plugin\="org.eclipse.ui.externaltools"/>
<descriptor class\="org.eclipse.ui.editors.text.TextEditor" id
\="org.eclipse.jdt.ui.DefaultTextEditor" image
\="icons/full/obj16/file_obj.gif" internal\="true" label\="Properties
File Editor" open_in_place\="false" plugin\="org.eclipse.jdt.ui"/>
\="org.eclipse.jdt.ui.JARDescEditor" image
\="icons/full/obj16/jar_desc_obj.gif" internal\="true" label\="JAR
Description Editor" open_in_place\="false" plugin\="org.eclipse.jdt.ui"/>
<descriptor class
\="org.eclipse.jdt.internal.ui.javaeditor.ClassFileEditor" id
\="org.eclipse.jdt.ui.ClassFileEditor" image
\="icons/full/obj16/classf_obj.gif" internal\="true" label\="Class File
Viewer" open_in_place\="false" plugin\="org.eclipse.jdt.ui"/><descriptor
class\="org.eclipse.pde.internal.ui.editor.site.SiteEditor" id
\="org.eclipse.pde.ui.siteEditor" image
\="icons/full/obj16/site_xml_obj.gif" internal\="true" label\="Site
<descriptor class
\=" org.eclipse.pde.internal.ui.editor.manifest.FragmentManifest Editor " id
\="org.eclipse.pde.ui.fragmentEditor" image
\="icons/full/obj16/frgmt_mf_obj.gif" internal\="true" label\="Fragment
</editors>
org.eclipse.help=2.1.1
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.t argetPlatform
=1.4
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable. JRE_LIB=/usr/
j2sdk1.4.1_02/jre/lib/rt.jar
org.eclipse.core.resources/description.autobuilding=false
org.eclipse.ui.workbench/REFRESH_WORKSPACE_ON_STARTUP=true
org.eclipse.pde.core/platform_path=/usr/java/eclipse-2.1.1
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.s taticAccessRe
ceiver=ignore
org.eclipse.jdt.ui/closeBrackets=false
org.eclipse.core.resources=2.1.1
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.d eprecationInD
eprecatedCode=enabled
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.u nusedPrivateM
ember=warning
org.eclipse.jdt.ui/org.eclipse.jdt.ui.importorder=java;javax ;org;com;
org.eclipse.ui.workbench/SAVE_ALL_BEFORE_BUILD=true
org.eclipse.core.resources/description.maxfilestatesize=2097 152
org.eclipse.jdt.ui/org.eclipse.jdt.ui.wizards.srcBinFoldersI nNewProjects=
true
org.eclipse.ui.workbench=2.1.1
org.eclipse.jdt.ui/spacesForTabs=true
org.eclipse.jdt.ui/lineNumberRuler=true
org.eclipse.help/default_browser=org.eclipse.help.mozillaLin ux
org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors _before_launc
h_radio=org.eclipse.debug.ui.auto_save_dirty_editors_before_ launch
org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCo pyExclusionFi
lter=*.launch
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable. JRE_SRCROOT=
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.u nusedLocal=wa
rning
org.eclipse.team.cvs.ui/pref_save_dirty_editors=3
org.eclipse.jdt.ui=2.1.1
org.eclipse.ui.externaltools/lineNumberRuler=true
org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding
\="UTF-8"?>\n<editors><info extension\="jpage" name\="*"><editor id
\="org.eclipse.jdt.debug.ui.SnippetEditor"/></info><info extension
\="html" name\="*"><editor id\="org.eclipse.ui.DefaultTextEditor"/>
</info><info extension\="exsd" name\="*"><editor id
\="org.eclipse.pde.ui.schemaEditor"/></info><info extension\="java" name
\="*"><editor id\="org.eclipse.jdt.ui.CompilationUnitEditor"/></info>
<info extension\="xml" name\="feature"><editor id
\="org.eclipse.pde.ui.featureEditor"/></info><info extension\="xml" name
\="plugin"><editor id\="org.eclipse.pde.ui.manifestEditor"/></info><info
extension\="properties" name\="build"><editor id
\="org.eclipse.pde.ui.buildEditor"/></info><info extension\="xml" name
\="org.eclipse.ui.externaltools.internal.ant.editor.AntEditor "/></info>
<info extension\="properties" name\="*"><editor id
\="org.eclipse.jdt.ui.DefaultTextEditor"/></info><info extension
\="jardesc" name\="*"><editor id\="org.eclipse.jdt.ui.JARDescEditor"/>
</info><info extension\="class" name\="*"><editor id
\="org.eclipse.jdt.ui.ClassFileEditor"/></info><info extension\="xml"
name\="site"><editor id\="org.eclipse.pde.ui.siteEditor"/></info><info
extension\="xsd" name\="*"><editor id
\="org.eclipse.pde.ui.schemaEditor"/></info><info extension\="txt" name
\="*"><editor id\="org.eclipse.ui.DefaultTextEditor"/></info><info
extension\="xml" name\="fragment"><editor id
\="org.eclipse.pde.ui.fragmentEditor"/></info><info extension\="mxsd"
name\="*"><editor id\="org.eclipse.pde.ui.schemaEditor"/></info>
</editors>
org.eclipse.jdt.ui/hoverModifierMasks=org.eclipse.jdt.ui.Bes tMatchHover;0
;org.eclipse.jdt.ui.JavadocHover;0;org.eclipse.jdt.ui.Proble mHover;0;org.
eclipse.jdt.ui.JavaSourceHover;262144;org.eclipse.jdt.intern al.debug.ui.J
avaDebugHover;0;
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathContainer .abbot|org.ec
\=""/></classpath>
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable. JRE_SRC=/usr/
j2sdk1.4.1_02/src.zip
org.eclipse.ui.workbench/SWITCH_PERSPECTIVE_ON_PROJECT_CREAT ION=always
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathContainer .tools|org.ec
\=""/></classpath>
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable. ECLIPSE_HOME=
org.eclipse.ui.workbench/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=fa lse
org.eclipse.jdt.launching=2.1.1
org.eclipse.pde.core=2.1.0
org.eclipse.jdt.ui/org.eclipse.jdt.ui.flatPackagesInPackageE xplorer=false
org.eclipse.jdt.ui/org.eclipse.jdt.ui.compresspackagenames=t rue
org.eclipse.ui.workbench/AUTO_BUILD=false
org.eclipse.jdt.ui/fontPropagated=true
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.d eprecation=ig
nore
org.eclipse.debug.ui=2.1.1
org.eclipse.debug.ui/org.eclipse.debug.ui.auto_remove_old_la unches=true
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.u nusedImport=i
gnore
org.eclipse.jdt.junit=2.1.1
org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.a ssertIdentifi
er=error
org.eclipse.jdt.ui/closeStrings=false
org.eclipse.jdt.core/org.eclipse.jdt.core.formatter.tabulati on.char=space
org.eclipse.debug.ui/Console.highWaterMark=88000
org.eclipse.jdt.junit/org.eclipse.jdt.junit.active_filters=o rg.eclipse.jd
t.internal.junit.runner.*,org.eclipse.jdt.internal.junit.ui.
*,junit.framework.TestCase,junit.framework.TestResult,junit. framework.Tes
tSuite,junit.framework.Assert,java.lang.reflect.Method.invok e
org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.linktoeditor= true
org.eclipse.jdt.ui/closeBraces=false
*** Update Manager Log:
Configuration=Aug 1, 2003 11:35:42 PM
Is current configuration=false
Configuration=Aug 7, 2003 3:22:20 PM
Is current configuration=true
*** Error Log:
!SESSION Aug 25, 2003 11:23:10.950
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -data
/home/josh/.eclipse -install file:/usr/java/eclipse-2.1.1/
!ENTRY org.eclipse.jface 4 2 Aug 25, 2003 11:23:10.960
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.dnd.DND.error(DND.java:230)
at org.eclipse.swt.dnd.DND.error(DND.java:181)
at org.eclipse.swt.dnd.Clipboard.getContents(Clipboard.java:140 )
org.eclipse.jdt.internal.ui.reorg.PasteResourcesFromClipboar dAction.getCl
ipboardFiles(PasteResourcesFromClipboardAction.java:204)
org.eclipse.jdt.internal.ui.reorg.PasteResourcesFromClipboar dAction.canPa
steFiles(PasteResourcesFromClipboardAction.java:158)
org.eclipse.jdt.internal.ui.reorg.PasteResourcesFromClipboar dAction.canOp
erateOn(PasteResourcesFromClipboardAction.java:117)
org.eclipse.jdt.internal.ui.reorg.PasteResourcesFromClipboar dAction.selec
tionChanged(PasteResourcesFromClipboardAction.java:59)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchS electionChang
ed(SelectionDispatchAction.java:181)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.selection Changed
(SelectionDispatchAction.java:176)
org.eclipse.jdt.internal.ui.reorg.DualReorgAction.selectionC hanged
(DualReorgAction.java:50)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:159)
at org.eclipse.core.internal.runtime.InternalPlatform.run
(InternalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged
(Viewer.java:157)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection
(StructuredViewer.java:1290)
at org.eclipse.jface.viewers.StructuredViewer.setSelection
(StructuredViewer.java:1020)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:36 2)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. showInput
(PackageExplorerPart.java:950)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. editorActivat
ed(PackageExplorerPart.java:932)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart
$9.partActivated(PackageExplorerPart.java:170)
at org.eclipse.ui.internal.PartListenerList$1.run
(PartListenerList.java:49)
at org.eclipse.ui.internal.PartListenerList.firePartActivated
(PartListenerList.java:47)
at org.eclipse.ui.internal.WorkbenchPage.firePartActivated
(WorkbenchPage.java:1180)
at org.eclipse.ui.internal.WorkbenchPage.setActivePart
(WorkbenchPage.java:2504)
at org.eclipse.ui.internal.WorkbenchPage.requestActivation
(WorkbenchPage.java:2217)
at org.eclipse.ui.internal.PartPane.requestActivation
(PartPane.java:334)
at org.eclipse.ui.internal.EditorPane.requestActivation
(EditorPane.java:136)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:3 14)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:923)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:948)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:79 2)
at org.eclipse.swt.widgets.Control.gtk_button_press_event
(Control.java:1606)
at org.eclipse.swt.widgets.Composite.gtk_button_press_event
(Composite.java:326)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1158)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2084 )
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Native Method)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:635)
at org.eclipse.swt.internal.gtk.OS.gtk_clipboard_wait_for_conte nts
(Native Method)
at org.eclipse.swt.dnd.Clipboard.getContents(Clipboard.java:147 )
ipboardResources(PasteResourcesFromClipboardAction.java:208)
erateOn(PasteResourcesFromClipboardAction.java:115)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.update
(SelectionDispatchAction.java:109)
at org.eclipse.jdt.internal.ui.reorg.DualReorgAction.update
(DualReorgAction.java:59)
at org.eclipse.jdt.internal.ui.reorg.DualReorgAction.<init>
(DualReorgAction.java:32)
org.eclipse.jdt.internal.ui.reorg.ReorgActionFactory.createP asteAction
(ReorgActionFactory.java:62)
at org.eclipse.jdt.ui.actions.CCPActionGroup.<init>
(CCPActionGroup.java:77)
(CCPActionGroup.java:71)
org.eclipse.jdt.internal.ui.javaeditor.JavaOutlinePage.creat eControl
(JavaOutlinePage.java:928)
at org.eclipse.ui.views.contentoutline.ContentOutline.doCreateP age
(ContentOutline.java:125)
at org.eclipse.ui.part.PageBookView.createPage
(PageBookView.java:306)
at org.eclipse.ui.part.PageBookView.partActivated
(PageBookView.java:561)
org.eclipse.ui.views.contentoutline.ContentOutline.partBroug htToTop
(ContentOutline.java:191)
at org.eclipse.ui.internal.PartListenerList$2.run
(PartListenerList.java:69)
at org.eclipse.ui.internal.PartListenerList.firePartBroughtToTo p
(PartListenerList.java:67)
at org.eclipse.ui.internal.WorkbenchPage.firePartBroughtToTop
(WorkbenchPage.java:1194)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor
(WorkbenchPage.java:2082)
at org.eclipse.ui.internal.WorkbenchPage.access$6
(WorkbenchPage.java:2004)
at org.eclipse.ui.internal.WorkbenchPage$9.run
(WorkbenchPage.java:1991)
at org.eclipse.swt.custom.BusyIndicator.showWhile
(BusyIndicator.java:69)
at org.eclipse.ui.internal.WorkbenchPage.openEditor
(WorkbenchPage.java:1986)
(WorkbenchPage.java:1919)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$4.run
(LaunchView.java:820)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.openEd itor
(LaunchView.java:829)
(LaunchView.java:799)
org.eclipse.debug.internal.ui.views.launch.LaunchView.openEd itorForStackF
rame(LaunchView.java:651)
org.eclipse.debug.internal.ui.views.launch.LaunchView.showEd itorForCurren
tSelection(LaunchView.java:570)
org.eclipse.debug.internal.ui.views.launch.LaunchView.select ionChanged
(LaunchView.java:446)
(Viewer.java:157)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.autoEx pand
(LaunchView.java:973)
org.eclipse.debug.internal.ui.views.launch.LaunchViewEventHa ndler.doHandl
eSuspendThreadEvent(LaunchViewEventHandler.java:231)
eSuspendEvent(LaunchViewEventHandler.java:181)
eDebugEvents(LaunchViewEventHandler.java:102)
at org.eclipse.debug.internal.ui.views.AbstractDebugEventHandle r
$1.run(AbstractDebugEventHandler.java:70)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages
(Synchronizer.java:98)
at org.eclipse.swt.widgets.Display.runAsyncMessages
(Display.java:1618)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:1436)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at org.eclipse.core.internal.boot.InternalBootLoader.run
(InternalBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.jface 4 2 Aug 25, 2003 11:23:16.342
!STACK 0
org.eclipse.jdt.internal.corext.Assert$AssertionFailedExcept ion: null
argument;
at org.eclipse.jdt.internal.corext.Assert.isNotNull
(Assert.java:105)
at org.eclipse.jdt.internal.corext.Assert.isNotNull(Assert.java :83)
org.eclipse.jdt.internal.ui.reorg.PackageFragmentRootManipul ationQuery.
<init>(PackageFragmentRootManipulationQuery.java:53)
org.eclipse.jdt.internal.ui.reorg.JdtMoveAction.createUpdate ClasspathQuer
y(JdtMoveAction.java:393)
org.eclipse.jdt.internal.ui.reorg.JdtMoveAction.createRefact oring
(JdtMoveAction.java:112)
org.eclipse.jdt.internal.ui.reorg.ReorgDestinationAction.can OperateOn
(ReorgDestinationAction.java:103)
org.eclipse.jdt.internal.ui.reorg.ReorgDestinationAction.sel ectionChanged
(ReorgDestinationAction.java:91)
at org.eclipse.jdt.ui.actions.MoveAction.selectionChanged
(MoveAction.java:102)
(Viewer.java:157)
(PartPane.java:334)
(Control.java:1606)
(Native Method)
(Viewer.java:157)
(Display.java:1618)
(Display.java:1436)
!ENTRY org.eclipse.ui.workbench 4 2 Aug 25, 2003 11:23:18.556
"org.eclipse.ui.workbench".
!STACK 0
at org.eclipse.swt.widgets.Widget.error(Widget.java:370)
at org.eclipse.swt.widgets.Control.getDisplay(Control.java:1365 )
at org.eclipse.swt.widgets.Widget.isValidThread(Widget.java:729 )
at org.eclipse.swt.widgets.Widget.checkParent(Widget.java:248)
at org.eclipse.swt.widgets.Widget.<init>(Widget.java:154)
at org.eclipse.swt.widgets.Control.<init>(Control.java:82)
at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:71)
at org.eclipse.swt.widgets.Composite.<init>(Composite.java:81)
at org.eclipse.swt.widgets.Tree.<init>(Tree.java:79)
(JavaOutlinePage.java:894)
(PartPane.java:334)
(Control.java:1606)
(Native Method)
(Viewer.java:157)
(Display.java:1618)
(Display.java:1436)
!ENTRY org.eclipse.ui.workbench 4 2 Aug 25, 2003 11:23:19.270
!STACK 0
at org.eclipse.jdt.ui.actions.GenerateActionGroup.<init>
(GenerateActionGroup.java:180)
(GenerateActionGroup.java:163)
(JavaOutlinePage.java:929)
(Viewer.java:157)
(Display.java:1618)
(Display.java:1436)
!SESSION Aug 25, 2003 11:24:59.168
!ENTRY org.eclipse.debug.core 4 120 Aug 25, 2003 11:24:59.170
!MESSAGE Error logged from Debug Core:
!STACK 1
org.eclipse.debug.core.DebugException: Missing breakpoint definition for
marker type org.eclipse.jdt.debug.javaLineBreak
Re: Exception occured during launch: Reason: Source locator does not exist: org.eclipse.jdt.debug.ui [message #88989 is a reply to message #88959] Mon, 25 August 2003 14:52 Go to previous messageGo to next message
Josh Rehman <jrehman@citysearch.com> wrote in
news:Xns93E275C26489Ejoshrehman@204.138.98.10:
I'm getting a different error
Exception occured creating launch configuration tabs
Reason:
No tab group defined for launch configuration type
org.eclipse.jdt.launching.localJavaApplication
Clicking ok gives:
No tabs defined for launch configuration type Java Application
Clicking ok brings up the "Run" dialog, but there is nothing in the lower
right hand portion (where normally run-time configuration parameters are
entered).
Note that running eclipse with a different (new) data directory seemed to
fix the problem. (I was able to launch and debug just fine). Therefore,
my workspace metadata must be corrupt, no?
I am loathe to replace all of that data, since there is some important
configuration information there. Can someone please advise on how I can
fix this problem and prevent it from happeneing without loosing important
project metadata?
Josh Rehman
Re: Exception occured during launch: Reason: Source locator does not exist: org.eclipse.jdt.debug.ui [message #89019 is a reply to message #88989] Mon, 25 August 2003 16:13 Go to previous messageGo to next message
There is a similar bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?id=40947
Darins
"Josh Rehman" <jrehman@citysearch.com> wrote in message
news:Xns93E278A57886Cjoshrehman@204.138.98.10...
> Reason:
> Clicking ok gives:
> entered).
> project metadata?
> Josh Rehman
Re: Exception occured during launch: Reason: Source locator does not exist: org.eclipse.jdt.debug.ui [message #89034 is a reply to message #89019] Mon, 25 August 2003 16:22 Go to previous message
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in news:bidqgj$g3t$1
@eclipse.org:
Thanks a bunch, Darin. I've added my comment, and my vote, to this bug.
Previous Topic:JUnit plug-in tests give "Could not resolve classpath container: org.eclipse.pde.core.requiredP
Next Topic:Error while closing applications in eclipse
Current Time: Fri Nov 07 22:19:18 EST 2025
Powered by FUDForum. Page generated in 0.04402 seconds
