Home » Newcomers » Newcomers » Simple to Java Project
Simple to Java Project [message #88883] Sun, 24 July 2005 16:17 Go to next message
Originally posted by: vogernewsletters.yahoo___p____.gr
I have created a simple project and in that i added some source files.
But now i want to convert that project to a java project because i can't
use help for api and auto complete. It pop's up a message that says
"The resource is not in a build path of a java project"
Is there any way to change the project type to java without having to
delete it and recreate?
Thank you very much for you time
Re: Simple to Java Project [message #90013 is a reply to message #88883] Thu, 28 July 2005 10:15 Go to previous message
The simplest thing I think is to delete the project, but when Eclipse
asks tell it DO NOT delete the contents (files). Then re-create the
project with the same name, this time as a Java project. Eclipse will
prompt you for source folder, build output location, etc.
HTH,
Eric
Previous Topic:FrameworkEvent.ERROR eclipse3.1
Next Topic:How can I change jvm which eclipse runs on?
Current Time: Wed Dec 03 17:16:04 EST 2025
Powered by FUDForum. Page generated in 0.08656 seconds
