Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Help with API
[EMF Compare] Help with API [message #88718] Tue, 10 July 2007 10:59 Go to next message
How would one match (and diff) between two instance models of the same
metamodel and then go on to merge those differences in java? I was
looking at the source but I can't find any concrete implementation of
MatchEngine. I tried doing a modelMatch() on DifferencesServices but it
throws and error looking for a window.
org.eclipse.emf.compare.match.statistic.DifferencesServices. getDefaultSearchWindow(DifferencesServices.java:327)
Are there any tutorials on this too or code samples ?
Thanks!
Andrew.
Re: [EMF Compare] Help with API [message #88775 is a reply to message #88718] Tue, 10 July 2007 12:09 Go to previous messageGo to next message
Hi Andrew,
tutorials and code samples are not yet ready, it's coming :)
Though, to compare two models the process is basically this one:
EObject eObject1 = ModelUtils.load(model1URI);
EObject eObject2 = ModelUtils.load(model2URI);
final MatchModel match = new MatchService().doMatch(
eObject1, eObject2, new NullProgressMonitor());
final DiffModel diff = new DiffMaker().doDiff(match);
Then you can browse the diff, if you want to merge stuffs you'll have to
create a merger using the diffelement:
final AbstractMerger merger = MergeFactory.createMerger(element);
Then you can choose:
merger.undoInTarget();
or
merger.applyInOrigin();
The "getDefaultSearchWindow()" issue is a bug :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195859 , it appears when the
preferences have not been initialized.
There is a workaround : you should open the preferences pages and set the
default value for the "Search Window" - which is 100 by default.
Cédric
Andrew Carton wrote:
> Thanks!
> Andrew.
Re: [EMF Compare] Help with API [message #88790 is a reply to message #88775] Tue, 10 July 2007 12:10 Go to previous messageGo to next message
Thats grand, thanks very much!
Andrew.
Ar 10/07/2007 17:09, Scríobh Cédric Brun:
> Hi Andrew,
> or
> Cédric
>> Thanks!
>> Andrew.
Re: [EMF Compare] Help with API [message #88805 is a reply to message #88775] Tue, 10 July 2007 12:30 Go to previous messageGo to next message
Hey Cédric,
Unfortunately when I am doing that, I get this error. It looks like it
wants to be a plugin!
ption in thread "main" java.lang.NullPointerException at
org.eclipse.emf.compare.match.service.MatchService.parseExte nsionMetadata(MatchService.java:52)
org.eclipse.emf.compare.match.service.MatchService.<init>(MatchService.java:48)
EObject e1 = ModelUtils.load(URI.createURI("model1.uml"));
EObject e2 = ModelUtils.load(URI.createURI("model2.uml"));
MatchModel match = null;
match = new MatchService().doMatch(e1, e2, new
Thanks again,
Andrew
Ar 10/07/2007 17
> Hi Andrew,
> or
> Cédric
>> Thanks!
>> Andrew.
Re: [EMF Compare] Help with API [message #88905 is a reply to message #88805] Wed, 11 July 2007 03:56 Go to previous message
I did not understood you wanted to use EMF compare without using plugins and
extension points.
As you won't use the extension points you'll have to choose the match engine
by yourself. Basically the generic one should fit:
final MatchModel match = new DifferencesServices().modelMatch(
Cédric
> Hey Cédric,
> at
> Thanks again,
> Andrew
> Ar 10/07/2007 17
>> Hi Andrew,
>> or
>> the preferences have not been initialized.
>> the
>> Cédric
>>> Hi,
>>> Thanks!
>>> Andrew.
Re: [EMF Compare] Help with API [message #608682 is a reply to message #88718] Tue, 10 July 2007 12:09 Go to previous message
Hi Andrew,
or
Cédric
> Thanks!
> Andrew.
Re: [EMF Compare] Help with API [message #608683 is a reply to message #88775] Tue, 10 July 2007 12:10 Go to previous message
Andrew.
> Hi Andrew,
> or
> Cédric
>> Thanks!
>> Andrew.
Re: [EMF Compare] Help with API [message #608684 is a reply to message #88775] Tue, 10 July 2007 12:30 Go to previous message
Hey Cédric,
Thanks again,
Andrew
Ar 10/07/2007 17
> Hi Andrew,
> or
> Cédric
>> Thanks!
>> Andrew.
Re: [EMF Compare] Help with API [message #608691 is a reply to message #88805] Wed, 11 July 2007 03:56 Go to previous message
extension points.
Cédric
> Hey Cédric,
> at
> Thanks again,
> Andrew
> Ar 10/07/2007 17
>> Hi Andrew,
>> or
>> the
>> Cédric
>>> Hi,
>>> Thanks!
>>> Andrew.
Previous Topic:Integrating OCL - providing EvaluationEnvironment
Next Topic:[EMF Compare] Standalone run and in-memory-only objects
Current Time: Tue Jun 10 05:14:23 EDT 2025
Powered by FUDForum. Page generated in 0.19554 seconds
