Home » Archived » M2M (model-to-model transformation) » [QVTO] Parser error using ParameterDirectionKind enumeration
| [QVTO] Parser error using ParameterDirectionKind enumeration [message #88702] |
Fri, 22 August 2008 04:30  |
Originally posted by: koen.yskout.cs.kuleuven.be
The UML metamodel contains a ParameterDirectionKind enum.
However, its elements (in, out, inout, return) are reserved words in
QVTO, resulting in parser errors when I try to use them (example at the
end). Can this be fixed, or is there a way to get around this problem?
Koen
modeltype UML uses uml("http://www.eclipse.org/uml2/2.1.0/UML");
transformation demo();
main() {
var param := object UML::Parameter {
direction := ParameterDirectionKind::in;
| Re: [QVTO] Parser error using ParameterDirectionKind enumeration [message #88717 is a reply to message #88702] |
Fri, 22 August 2008 06:26   |
Hoi Koen,
Have you tried to put them in quotes? Double or single.
Alfons
"Koen Yskout" <koen.yskout@cs.kuleuven.be> schreef in bericht
news:g8ltf7$to8$1@build.eclipse.org...
> However, its elements (in, out, inout, return) are reserved words in QVTO,
> resulting in parser errors when I try to use them (example at the end).
> Koen
> main() {
| Re: [QVTO] Parser error using ParameterDirectionKind enumeration [message #88732 is a reply to message #88717] |
Fri, 22 August 2008 07:02   |
I tried, but I didn't find a method that the parser accepts :-(
I suspect that quotes are only used for strings.
The QVT spec once mentions an 'asEnumeration()' string operation, which
sounds as if it would be useful in my case, but I can't find more info
on that.
regards,
Koen
Alfons Laarman wrote:
> Hoi Koen,
> Alfons
>> Thanks,
>> Koen
>> main() {
| Re: [QVTO] Parser error using ParameterDirectionKind enumeration [message #88747 is a reply to message #88702] |
Fri, 22 August 2008 07:07  |
Hi Koen,
Just prepend the '_' character to the clashing identifier.
ParameterDirectionKind::_in
The OCL spec defines this way for resolving such conflicts,
See "9.3 Concrete Syntax"
/Radek
On Fri, 22 Aug 2008 10:30:30 +0200, Koen Yskout =
<koen.yskout@cs.kuleuven.be> wrote:
> However, its elements (in, out, inout, return) are reserved words in =
> QVTO, resulting in parser errors when I try to use them (example at th=
e =
> end). Can this be fixed, or is there a way to get around this problem?=
> Koen
> main() {
> var param :=3D object UML::Parameter {
> direction :=3D ParameterDirectionKind::in;
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Current Time: Mon Nov 17 00:51:50 EST 2025
Powered by FUDForum. Page generated in 0.03973 seconds
