Home » Archived » COSMOS » COSMOS Eclipsecon07 Demo Setup Instructions
COSMOS Eclipsecon07 Demo Setup Instructions [message #8014] Wed, 21 February 2007 19:59
Hi All,
Here are the instructions to run the COSMOS eclipsecon demo. Let me
know if you have any problems running the demo. Note: there are some
hard coded paths that have to be modified. We are currently making
modifications to make this configuration much easier.
Download
SUN JRE 1.5
Eclipse 3.2.1 -
http://fullmoon.torolab.ibm.com/downloads/drops/R-3.2.1-2006 09210945/download.php?dropFile=eclipse-SDK-3.2.1-win32.zip
EMF 2.2.1 -
http://download.eclipse.org/modeling/emf/emf/downloads/drops /2.2.1/R200609210005/emf-sdo-xsd-SDK-2.2.1.zip
GEF 3.2 -
http://download.eclipse.org/tools/gef/downloads/drops/R-3.2. 1-200609211617/GEF-runtime-3.2.1.zip
BIRT 2.1.1 -
http://download.eclipse.org/birt/downloads/drops/R-R1-2_1_1- 200609260959/birt-report-framework-2_1_1.zip
TPTP 4.4 -
http://www.eclipse.org/downloads/download.php?file=/tptp/4.4 .0/dev/TPTP-4.4.0-200702210100/tptp.platform.runtime-TPTP-4. 4.0-200702210100.zip
Download Derby - 10.2.2.0 -
http://mirror.cc.columbia.edu/pub/software/apache/db/derby/d b-derby-10.2.2.0/db-derby-10.2.2.0-bin.zip
Download sample database -
http://wiki.eclipse.org/images/0/0f/COSMOS-EclipseCon2007Dem o-log_stat-sample-Apache_Derby-db.zip
Checkout from CVS
Host: dev.eclipse.org
Repository: /cvsroot/tptp
Module: platform/org.eclipse.tptp.platform.models
Repository: /cvsroot/technology
Module:org.eclipse.cosmos/examples/eclipseCon07/org.eclipse. cosmos.examples.eclipsecon07.repository
Module:org.eclipse.cosmos/examples/eclipseCon07/org.eclipse. cosmos.examples.eclipsecon07.reports.oda
Module:org.eclipse.cosmos/examples/eclipseCon07/org.eclipse. cosmos.examples.eclipsecon07.reports.templates
Steps to run
1. Start up ecilpse.
2. Open
org.eclipse.cosmos.examples.eclipsecon07.reports.oda\src\org \eclipse\cosmos\dr\reports\oda\ResourcesDataAccessor.java
3. Modify the following line to point to the correct xml file
location.
private static String SML_RESOURCES_FOLDER =
" file:///c|/COSMOS-Demo-EclipseCon2007/eclipse/demo/org.eclip se.cosmos.examples.eclipsecon07.repository/topologies/";
4. Open
org.eclipse.tptp.platform.models\src-dms\org\eclipse\tptp\pl atform\internal\dms\log\impl\RDBLogDataStoreManager.java
5. Modify the following line to point to the correct derby jar file
location.
jdbcHelper.setURLString(" file:/c:/COSMOS-Demo-EclipseCon2007/derby/db-derby-10.2.2.0- bin/lib/derbyclient.jar ");
6. Open
org.eclipse.tptp.platform.models\src-dms\org\eclipse\tptp\pl atform\internal\dms\statistical\impl\RDBStatisticalDataStore Manager.java
7. Modify the following line to point to the correct derby jar file
location.
8. unzip sample data under
%DERBY_INSTALL%\frameworks\NetworkServer\bin
9. Run
%DERBY_INSTALL%\frameworks\NetworkServer\bin\setNetworkServe rCP.bat.
Note: you will need to modify the script to point to the DERBY_INSTALL
directory
10. Run
%DERBY_INSTALL%\frameworks\NetworkServer\bin\startNetworkSer ver.bat.
directory
11. In your eclipse workspace expand to:
org.eclipse.cosmos.examples.eclipsecon07.reports.templates > templates
12. Open cosmos-nodes.rptdesign in the Report Editor.
13. Click the "Preview" tab in the Report Editor. At this point you
should be able to navigate the topology and view the properties pages.
14. Click on the "Production" Link. Then click the "Properties" link
on "Machine 1". At this point there should be a statisitcal link on
the
Properties report. This will open the statistical report.
15. Go back to the root report. Click on the "Production" Link. Then
click the "Machine 2" link. Then click the "Properties" link on
"WindowServer1".
At this point there should be a Top 10 link on the Properties report.
This will open the TOp 10 report.
Previous Topic:smlfn:deref in assert
Next Topic:COSMOS Eclipsecon07 Demo Setup Instructions
Current Time: Wed Dec 03 00:19:24 EST 2025
Powered by FUDForum. Page generated in 0.02809 seconds
