Home » Archived » Visual Editor (VE) » ve doesnt start
ve doesnt start [message #88629] Tue, 26 April 2005 06:09 Go to next message
Originally posted by: thomas.thierfelder.bitctrl.de
I'm sort of new with eclipse, but nevertheless I have to get along with
Visual Editor. My problem goes as follows: The VE runs if I only create a
new Visual Class which is not derived from any swt container class. As soon
as I do so, the environment throws a nullpointerexeption (even if it
produces the right code). By the way, it also says that it's unable to open
the VE when I try to add a container class to the Visual Class from the
VE-Menue. So everything works instead of the visualization part of the VE
(menues...). Actually I'm pretty sure to have plugged in all the neccessary
libraries - so what am I supposed to do?
Thomas.
Re: ve doesnt start [message #88661 is a reply to message #88629] Tue, 26 April 2005 09:06 Go to previous messageGo to next message
Thomas Thierfelder wrote:
> Thomas.
Which level of VE/Eclipse/GEF/EMF are you using?
If it is VE1.1, have you tried the M1 download?
http://download.eclipse.org/tools/ve/downloads/drops/S-1.1M1 -200504251532/index.html
Re: ve doesnt start [message #88693 is a reply to message #88661] Tue, 26 April 2005 09:52 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Also what level of Java? It needs to be 1.4.2 or higher for SWT in the VE.
Rich Kulp
Re: ve doesnt start [message #607247 is a reply to message #88629] Tue, 26 April 2005 09:06 Go to previous message
> Thomas.
Re: ve doesnt start [message #607249 is a reply to message #88661] Tue, 26 April 2005 09:52 Go to previous message
Rich Kulp
Previous Topic:Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate)
Next Topic:CustomWidget Tutorial
Current Time: Sat Nov 01 15:38:59 EDT 2025
Powered by FUDForum. Page generated in 0.03690 seconds
