Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » DLTK Ruby & Watir
DLTK Ruby & Watir [message #8013] Sat, 23 June 2007 15:12 Go to next message
Originally posted by: java.gbrun.gmail.com
i'm currently using Eclipse 3.3RC4 with DLTK (ruby) 0.9 on windows
i install both ruby & watir with installer :
ruby186-25.exe
& watir-1.4.1.exe
i can run simple script,
but didn't find out how to get the completion to work.
IE ie = IE.new()
ie.| <-- pressing Ctrl+Space
DLTK keep on saying "No completions available."
anyone out there know how to solve the prob ?
Thanks in advance
Re: DLTK Ruby & Watir [message #8077 is a reply to message #8013] Mon, 25 June 2007 02:22 Go to previous messageGo to next message
> ruby186-25.exe
> & watir-1.4.1.exe
> IE ie = IE.new()
> Thanks in advance
In current release of DLTK you should specify path to your gem by adding
external source folder to Ruby project.
You could do it from project preferences -> Ruby Build Path -> Libraries
-> Add external source folder.
Then completion will work.
Andrei.
Re: DLTK Ruby & Watir [message #8107 is a reply to message #8077] Mon, 25 June 2007 17:14 Go to previous messageGo to next message
> Andrei Sobolev wrote:
> Andrei.
first of all, thanks for your advice.
i should have write that i already add the watir directory to the Ruby
Build Path libraries.
%ruby%\lib\ruby\gems\1.8\gems\watir-1.4.1
in fact, the DLTK Ruby behavior is strange :
if i stay near a ie function like goto,text_field or button,
a yellow tip window open with function definition.
that's cool!
but if i look at the Ruby documentation view, goto or text_field are ok
but button show this:
"Note: This element has no attached documentation and hence no
information could be found"
weird!
how can i have the documentation but can't use the completion (Ctrl+space) ?
strange notice : if i use the projet/clean then the scriptbuilder is
called, it's quite slow but when it heat 26% it's stopped (i dont know
if it's finnished)
any help is welcome.
G.BRUN
Re: DLTK Ruby & Watir [message #8363 is a reply to message #8107] Sun, 08 July 2007 12:05 Go to previous message
help yourself!
if that can help others, i found the solution to my problem
if solved it by modifying the source
i replace :
IE ie = IE.new();
by
IE ie = Watir::IE.new();
both source run well, but only the second one works in DLTK editor
(Ctrl+Space work and Ruby documentation view is OK)
full source if you want to reproduce:
require 'watir'
include Watir
site = 'http://www.google.com'
ie.goto(site);
ie.text_field(:name, "q").set("pickaxe");
ie.button(:name, "btnG").click;
if ie.contains_text("Programming Ruby")
puts "Test Passed.";
else
puts "Test Failed!";
end
ie.close();
G.BRUN
Previous Topic:IEvaluatedType representing an Array of a certain type
Next Topic:JRuby debugging?
Current Time: Fri Nov 07 00:20:57 EST 2025
Powered by FUDForum. Page generated in 0.02843 seconds
