Home » Modeling » GMF (Graphical Modeling Framework) » Multi-version semantic support in same editor, possible?
Multi-version semantic support in same editor, possible? [message #88616] Sun, 31 December 2006 03:34 Go to next message
Originally posted by: tiggo.kan.gmail.com
Hi guys,
Maybe some of you just suffering the same pain as me, there co-exists
two more version semantic models, and we hope all of them can be
edited/open in the same editor, not an editor per version:)
Any idea or tip is appreciated!
/tiggo
Re: Multi-version semantic support in same editor, possible? [message #89651 is a reply to message #88616] Fri, 05 January 2007 06:06 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
There is no special code/options to support this issue in GMF. Tooling
converts previous versions of models using MigrationResource so maybe
you could try similar approach.
tiggo wrote:
> Hi guys,
> /tiggo
Re: Multi-version semantic support in same editor, possible? [message #90981 is a reply to message #89651] Tue, 09 January 2007 11:59 Go to previous messageGo to next message
thanks for your reply.
Transform may alleviate the pain. It would be perfect if multi-versions'
semantic/gmfgraph models can be edited in one editor without transform!
So, how about map multiple semantic/gmfgraph to the same canvas
(gmfmap)? If reasonable, I will post it to bugzilla:)
> tiggo wrote:
>> Hi guys,
>> /tiggo
Re: Multi-version semantic support in same editor, possible? [message #91090 is a reply to message #90981] Wed, 10 January 2007 06:44 Go to previous messageGo to next message
I think that this idea is definitely worth exploring; please submit the
request )))
>> tiggo wrote:
>>> Hi guys,
>>> /tiggo
Re: Multi-version semantic support in same editor, possible? [message #92393 is a reply to message #91090] Sun, 14 January 2007 00:29 Go to previous message
Posted in bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=170397
> request )))
>> multi-versions' semantic/gmfgraph models can be edited in one editor
>> without transform!
>>> Tooling converts previous versions of models using MigrationResource
>>> so maybe you could try similar approach.
>>> tiggo wrote:
>>>> Hi guys,
>>>> co-exists two more version semantic models, and we hope all of them
>>>> can be edited/open in the same editor, not an editor per version:)
>>>> /tiggo
Previous Topic:how to resize the components on the canvas in GMF
Next Topic:Connection Problem
Current Time: Mon Jun 30 04:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.67271 seconds
