Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and JBoss JAAS
RAP and JBoss JAAS [message #88492] Mon, 19 May 2008 11:15 Go to next message
I have a project consists two parts: ejb3-server part and RAP-client. Both
parts are deployed in JBoss 4.2.1. I need to implement Authentication and
Authorization in the project.
I do this:
1. add this to web.xml in RAP client war-file
<security-constraint>
<web-resource-collection>
<web-resource-name>MyProject</web-resource-name>
<url-pattern>/*</url-pattern>
<http-method>POST</http-method>
<http-method>GET</http-method>
</web-resource-collection>
<auth-constraint>
<role-name>User_MyProject_system</role-name>
</auth-constraint>
</security-constraint>
<login-config>
<auth-method>BASIC</auth-method>
<realm-name>MyProjectRealm</realm-name>
</login-config>
<security-role>
</security-role>
2. add file jboss-web.xml to rap client war-file
<jboss-web>
<security-domain>java:/jaas/MyProjectPolicy</security-domain >
</jboss-web>
Now, when I access RAP-client application via web the browser login window is
displayed. I enter correct login/password and all works fine.
Next, I configure EJB3 security. I add annotations
@SecurityDomain("MyProjectPolicy") and @PermitAll tо stateless session bean
classes and restart JBoss. After this, I open the rap application in my
browser, enter correct login/password. The application's first screen is
displayed. But when I try to do something which interact with EJB3-part I see
exception (in JBoss logs and RAP): "javax.ejb.EJBAccessException:
Authentication failure".
What I do wrong???
Environment:
JBoss 4.2.1
Eclise 3.3
Rap 1.1M2
Java 1.5.0_14
Stacktrace from JBoss logs:
21:07:30,735 ERROR [STDERR] javax.ejb.EJBAccessException: Authentication failure
21:07:30,735 ERROR [STDERR] at
org.jboss.ejb3.security.Ejb3AuthenticationInterceptor.handle GeneralSecurityException(Ejb3AuthenticationInterceptor.java: 68)
org.jboss.aspects.security.AuthenticationInterceptor.invoke( AuthenticationInterceptor.java:70)
org.jboss.ejb3.security.Ejb3AuthenticationInterceptor.invoke (Ejb3AuthenticationInterceptor.java:106)
org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodIn vocation.java:101)
org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagati onInterceptor.java:46)
org.jboss.ejb3.asynchronous.AsynchronousInterceptor.invoke(A synchronousInterceptor.java:106)
21:07:30,736 ERROR [STDERR] at
org.jboss.ejb3.stateless.StatelessContainer.dynamicInvoke(St atelessContainer.java:278)
org.jboss.aop.Dispatcher.invoke(Dispatcher.java:106)
org.jboss.aspects.remoting.AOPRemotingInvocationHandler.invo ke(AOPRemotingInvocationHandler.java:82)
org.jboss.remoting.ServerInvoker.invoke(ServerInvoker.java:7 34)
org.jboss.remoting.transport.socket.ServerThread.processInvo cation(ServerThread.java:560)
org.jboss.remoting.transport.socket.ServerThread.dorun(Serve rThread.java:369)
org.jboss.remoting.transport.socket.ServerThread.run(ServerT hread.java:165)
org.jboss.remoting.MicroRemoteClientInvoker.invoke(MicroRemo teClientInvoker.java:163)
org.jboss.remoting.Client.invoke(Client.java:1550)
org.jboss.remoting.Client.invoke(Client.java:530)
org.jboss.aspects.remoting.InvokeRemoteInterceptor.invoke(In vokeRemoteInterceptor.java:62)
21:07:30,737 ERROR [STDERR] at
org.jboss.aspects.tx.ClientTxPropagationInterceptor.invoke(C lientTxPropagationInterceptor.java:61)
org.jboss.aspects.security.SecurityClientInterceptor.invoke( SecurityClientInterceptor.java:53)
org.jboss.ejb3.remoting.IsLocalInterceptor.invoke(IsLocalInt erceptor.java:72)
org.jboss.ejb3.stateless.StatelessRemoteProxy.invoke(Statele ssRemoteProxy.java:103)
21:07:30,737 ERROR [STDERR] at $Proxy214.find(Unknown Source)
com.company.myproject.ui.server.SelectServerAction.run(Selec tServerAction.java:26)
com.company.myproject.ui.server.SelectServerAction.run(Selec tServerAction.java:1)
21:07:30,738 ERROR [STDERR] at
com.company.myproject.ui.server.common.AJob.run(AJob.java:23 )
org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
org.jboss.aspects.remoting.InvokeRemoteInterceptor.invoke(In vokeRemoteInterceptor.java:74)
21:07:30,739 ERROR [STDERR] at $Proxy214.find(Unknown Source)
Denis Kostousov
Re: RAP and JBoss JAAS [message #88520 is a reply to message #88492] Mon, 19 May 2008 11:30 Go to previous message
Originally posted by: rherrmann.innoopract.com
Hi Denis,
sorry to say so, but this isn't my domain at all. But as RAP runs as
a servlet on top of Equinox, you might be lucky by searching or
asking on the Equinox newsgroup:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t echnology.equinox
Rüdiger
Denis Kostousov wrote:
> Both parts are deployed in JBoss 4.2.1. I need to implement
> Authentication and Authorization in the project.
> I do this:
> <auth-constraint>
> </auth-constraint>
> <login-config>
> </login-config>
> <security-role>
> </security-role>
> <jboss-web>
> </jboss-web>
> window is displayed. I enter correct login/password and all works fine.
> bean classes and restart JBoss. After this, I open the rap application
> in my browser, enter correct login/password. The application's first
> screen is displayed. But when I try to do something which interact with
> EJB3-part I see exception (in JBoss logs and RAP):
> "javax.ejb.EJBAccessException: Authentication failure".
> What I do wrong???
> Environment:
> JBoss 4.2.1
> Eclise 3.3
> Rap 1.1M2
> Java 1.5.0_14
> failure
> Denis Kostousov
Previous Topic:Dynamic Font Size??
Next Topic:Reload RAP with another parameter / Browser redirect
Current Time: Mon Nov 10 16:03:17 EST 2025
Powered by FUDForum. Page generated in 0.03661 seconds
