Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Disablement of test macros in suite editor's Behavior tab
[AGR] Disablement of test macros in suite editor's Behavior tab [message #88185] Tue, 21 November 2006 10:05 Go to next message
Hello everybody.
In the Behavior tab of a test suite I have a sequence of macros listed.
I want to exclude one temporarily from the sequence and therefore I
disable it using the Disable/Enable button to the right of the list, but
the macro is still being ran. Why is that? Am I misunderstanding the
purpose of the Disable/Enable button?
TIA
B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #88325 is a reply to message #88185] Tue, 21 November 2006 13:56 Go to previous messageGo to next message
The disable/enable button is only applicable when the test suite is launched
in standard mode. It seems to be working fine in TPTP4.2.1.
Are you experiencing this with newly created test suites or existing test
suites?
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:ejv4jl$q8f$1@utils.eclipse.org...
> Hello everybody.
> In the Behavior tab of a test suite I have a sequence of macros listed. I
> want to exclude one temporarily from the sequence and therefore I disable
> it using the Disable/Enable button to the right of the list, but the macro
> is still being ran. Why is that? Am I misunderstanding the purpose of the
> TIA
> B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #88414 is a reply to message #88325] Wed, 22 November 2006 10:15 Go to previous messageGo to next message
> suites?
>> Hello everybody.
>> TIA
>> B.
Hi Ali.
Thanks for your reply.
Yes, I am launching the suite in standard mode, under TPTP4.2.1 and
Eclipse 3.2.1 and I have this problem with an existing test suite (I
have not yet tried with a new suite). The test case that I am disabling
does not belong to the same suite, but is defined elsewhere and invoked
in this suite.
B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #88596 is a reply to message #88414] Thu, 23 November 2006 10:42 Go to previous messageGo to next message
I can't reproduce this problem with newly created test suites.
I even tried disabling test invocations that belong to other test suites.
news:ek1pil$8rv$1@utils.eclipse.org...
>> launched in standard mode. It seems to be working fine in TPTP4.2.1.
>> suites?
>> message news:ejv4jl$q8f$1@utils.eclipse.org...
>>> Hello everybody.
>>> TIA
>>> B.
> Hi Ali.
> Eclipse 3.2.1 and I have this problem with an existing test suite (I have
> not yet tried with a new suite). The test case that I am disabling does
> not belong to the same suite, but is defined elsewhere and invoked in this
> suite.
> B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #88669 is a reply to message #88596] Fri, 24 November 2006 03:37 Go to previous messageGo to next message
So does this mean that I cannot use the feature with pre existing test
suites? Or is it a bug that I should enter in Bugzilla?
B.
>>> suites?
>>>> Hello everybody.
>>>> TIA
>>>> B.
>> Hi Ali.
>> suite.
>> Thanks,
>> B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #88762 is a reply to message #88669] Mon, 27 November 2006 09:59 Go to previous messageGo to next message
If you can verify that the option works for newly created test suites and it
doesn't function for pre-existing test suites, then it is a defect.
news:ek6b00$u42$1@utils.eclipse.org...
> B.
>> message news:ek1pil$8rv$1@utils.eclipse.org...
>>>> test suites?
>>>>> Hello everybody.
>>>>> listed. I want to exclude one temporarily from the sequence and
>>>>> therefore I disable it using the Disable/Enable button to the right of
>>>>> the list, but the macro is still being ran. Why is that? Am I
>>>>> misunderstanding the purpose of the Disable/Enable button?
>>>>> TIA
>>>>> B.
>>> Hi Ali.
>>> in this suite.
>>> Thanks,
>>> B.
Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #89041 is a reply to message #88762] Wed, 29 November 2006 07:39 Go to previous message
No, I cannot get it to work either with old or with newly recorded test
suites. Adn still I cannot understand what I am doing wrong... :-(
B.
>> Thanks,
>> B.
>>>>> test suites?
>>>>>> Hello everybody.
>>>>>> TIA
>>>>>> B.
>>>> Hi Ali.
>>>> in this suite.
>>>> Thanks,
>>>> B.
Previous Topic:No Execution Statistics on stand-alone
Next Topic:libpiAgent.so can not be found
Current Time: Fri Nov 21 10:27:56 EST 2025
Powered by FUDForum. Page generated in 0.05811 seconds
