Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo / JPOX] Spaces with type string
[Teneo / JPOX] Spaces with type string [message #88132] Thu, 05 July 2007 08:47 Go to next message
Originally posted by: fc_supercanard.yahoo.fr
How to put spaces in element of type string using Teneo ?
If there is a space it throws a
org.eclipse.emf.teneo.StoreValidationException and complains that
"The feature 'uniqueName' of ... contains a bad value
Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88151 is a reply to message #88132] Thu, 05 July 2007 09:05 Go to previous messageGo to next message
I would need the stack trace to comment on this.
gr. Martin
> Quentin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo / JPOX] Spaces with type string [message #88195 is a reply to message #88151] Thu, 05 July 2007 09:33 Go to previous messageGo to next message
sure :
org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
MyClassImpl@5d985d98{jpox://?dsname=MyPMF&query1=select from
MyRootElementImpl#db space[OID]MyClassImpl}
'MyClassImpl@5d985d98{jpox://?dsname=MyPMF&query1=select from
MyRootElementImpl#db space[OID]MyClassImpl}' contains a bad value
org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:426)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:360)
CallingClass.save(CallingClass.java:80)
> gr. Martin
>> Regards,
>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88210 is a reply to message #88195] Thu, 05 July 2007 09:46 Go to previous messageGo to next message
This is not a Teneo issue. The value of the uniqueName feature is not according to its type defined
in the ecore model. This is validated by emf.
gr. Martin
> sure :
> at
> at
>> gr. Martin
>>> Regards,
>>> Quentin
The Netherlands
Re: [Teneo / JPOX] Spaces with type string [message #88238 is a reply to message #88210] Thu, 05 July 2007 09:58 Go to previous messageGo to next message
But the type of uniqueName is xs:String. Containing a space in it is not
considered as a bad value from emf... Why Teneo says that it is a bad value?
> according to its type defined in the ecore model. This is validated by emf.
> gr. Martin
>> sure :
>> at
>> at
>>> gr. Martin
>>>> Regards,
>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88253 is a reply to message #88238] Thu, 05 July 2007 10:10 Go to previous messageGo to next message
It is actually not Teneo who says that it is a wrong value but it is the emf validation. Before
saving the resource Teneo validates its content using a BasicDiagnostic.
See the methods StoreResource.validateContents and StoreResource.validateObject. The
StoreValidationException has a method getDiagnostics which returns all diagnosed errors in the values.
I would also check the specific feature in the ecore model to see if it has any additional constraints.
gr. Martin
> value?
>> emf.
>> gr. Martin
>>> sure :
>>> at
>>> at
>>>> gr. Martin
>>>>> Regards,
>>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] Spaces with type string [message #88283 is a reply to message #88253] Thu, 05 July 2007 10:30 Go to previous message
You are right, sorry, it is my mistake... In fact the element is of type
xs:ID.
Thanks for help!
> emf validation. Before saving the resource Teneo validates its content
> StoreResource.validateObject. The StoreValidationException has a method
> gr. Martin
>> not considered as a bad value from emf... Why Teneo says that it is a
>> bad value?
>>> by emf.
>>> gr. Martin
>>>> sure :
>>>> at
>>>> at
>>>>> gr. Martin
>>>>>> Regards,
>>>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608641 is a reply to message #88132] Thu, 05 July 2007 09:05 Go to previous message
gr. Martin
> Quentin
The Netherlands
Re: [Teneo / JPOX] Spaces with type string [message #608644 is a reply to message #88151] Thu, 05 July 2007 09:33 Go to previous message
sure :
> gr. Martin
>> Regards,
>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608645 is a reply to message #88195] Thu, 05 July 2007 09:46 Go to previous message
gr. Martin
> sure :
> at
> at
>> gr. Martin
>>> Regards,
>>> Quentin
The Netherlands
Re: [Teneo / JPOX] Spaces with type string [message #608647 is a reply to message #88210] Thu, 05 July 2007 09:58 Go to previous message
> gr. Martin
>> sure :
>> at
>> at
>>> gr. Martin
>>>> Regards,
>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608648 is a reply to message #88238] Thu, 05 July 2007 10:10 Go to previous message
gr. Martin
> value?
>> emf.
>> gr. Martin
>>> sure :
>>> at
>>> at
>>>> gr. Martin
>>>>> Regards,
>>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] Spaces with type string [message #608650 is a reply to message #88253] Thu, 05 July 2007 10:30 Go to previous message
xs:ID.
Thanks for help!
> gr. Martin
>> bad value?
>>> by emf.
>>> gr. Martin
>>>> sure :
>>>> at
>>>> at
>>>>> gr. Martin
>>>>>> Regards,
>>>>>> Quentin
Previous Topic:invoke template from java with string return?
Next Topic:Live validation as default
Current Time: Mon Jul 14 12:21:07 EDT 2025
Powered by FUDForum. Page generated in 0.10364 seconds
