Home » Eclipse Projects » Remote Application Platform (RAP) » Multi-Line Tooltip
Multi-Line Tooltip [message #88090] Fri, 16 May 2008 11:36 Go to next message
I'm using the Control#setToolTipText(String) function to set a tool tip
for a Button. My ToolTipMessage is long, so how can I add a line break?
I've tried \n and <br />, but nothing works.
Max
Re: Multi-Line Tooltip [message #88109 is a reply to message #88090] Fri, 16 May 2008 11:42 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Hi Max,
button.setToolTipText("hi there\nthis is line2");
should work (at least it does in RCP).
If this is not the case in RAP, can you open a bug for it?
Elias.
Maximilian Falkenstein wrote:
> Max
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: Multi-Line Tooltip [message #88153 is a reply to message #88109] Fri, 16 May 2008 13:10 Go to previous messageGo to next message
Hi Elias,
it doen't work in RAP, so I've just submitted a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232543
Max
Elias Volanakis schrieb:
> Hi Max,
> Elias.
>> tip for a Button. My ToolTipMessage is long, so how can I add a line
>> break?
>> Regards,
>> Max
Re: Multi-Line Tooltip [message #88168 is a reply to message #88153] Fri, 16 May 2008 13:33 Go to previous messageGo to next message
> Hi Elias,
This one was simple. Fixed.
Ralf
Re: Multi-Line Tooltip [message #88193 is a reply to message #88168] Sat, 17 May 2008 14:05 Go to previous message
It works fine. Thank you.
> Cheers,
> Ralf
Previous Topic:RAP in Tomcat strange Problem with IE
Next Topic:Shell Title Background
Current Time: Wed Nov 12 12:55:15 EST 2025
Powered by FUDForum. Page generated in 0.05286 seconds
