Home » Archived » M2M (model-to-model transformation) » ATL: Problems working with BigInteger
ATL: Problems working with BigInteger [message #87989] Mon, 11 August 2008 06:26 Go to next message
Originally posted by: not.anyone.de
Hello!
I want to assign a value to my output model, but as it seems to be of
the type "Java.math.BigInteger", I always get error messages like this one:
"Caused by: java.lang.ClassCastException: The value of type 'class
java.lang.Integer' must be of type 'class java.math.BigInteger'"
There is another thread with this subject, but I've opened up a new one
anyway, because I think there might be a quicker response this way.
Original is found here:
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg02856.html
With best regards,
Manu
Re: ATL: Problems working with BigInteger [message #88009 is a reply to message #87989] Mon, 11 August 2008 08:48 Go to previous message
As said in the discussion you mention, there is at this time no way to
set those types in ATL.
We are studying the possibility to provide a core extensibility for this
issue, in order to easily allow users to define theyre own types adapters.
For the moment, you can use the old way (quite hard but possible),
referring to that use case :
http://www.eclipse.org/m2m/atl/usecases/UML2AnyLogic/
In it you will find a custom model handler which allows the use of
specific data types.
William
Manu a écrit :
> Hello!
> With best regards,
> Manu
Previous Topic:[ATL]
Next Topic:[ATL] : How to deal with BigInteger Datatype
Current Time: Fri Oct 31 06:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
