| hibernate and collection setters [message #87877] |
Mon, 02 July 2007 22:33  |
Originally posted by: jerry_frain.yahoo.com
Ok, this has to be a FAQ but I can't find the answer after digging
around for quite a while.
When I generate my Java code from an ecore model the collection
attributes don't have setters. I believe that this is well known.
When I use teneo to generate hibernate mappings, the default
PropertyAccessors don't understand that there's no setter implementation
for my collections, so I get exceptions about setters not being defined.
I could write my own PropertyAccessor, but surely this problem has
already been solved?
Jerry
| Re: hibernate and collection setters [message #87924 is a reply to message #87893] |
Tue, 03 July 2007 03:32  |
Hi Jerry,
The HbDataStore also does some behind-the-scenes Hibernate configuration. You can check out the
initializeDataStore method to see what happens. One of the things it does is set a specific tuplizer
for each persistentclass. The one used by Teneo is the EMFTuplizer. This tuplizer takes care of
assigning the correct propertyaccessor to each property.
See also the HbUtil.getPropertyAccessor method.
The propertyaccessors can be found in org.eclipse.emf.teneo.hibernate.mapping package and its
subclasses.
The main purpose of the HbDataStore is to configure hibernate and not much more. You can use the
HbDataStore in combination with your dao pattern. Just initialize the hbdatastore, get its
sessionfactory and for the rest use your dao's.
gr. Martin
>> implementation for my collections, so I get exceptions about setters
>> not being defined.
> BTW, it would probably help if I'd say that I'm persisting EMF objects
> myself, by using the teneo-generated hibernate mappings and a DAO
> pattern (for the moment). I'm guessing that everyone else is using the
> HbDataStore.
> Jerry
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: hibernate and collection setters [message #608624 is a reply to message #87877] |
Mon, 02 July 2007 22:41  |
HbDataStore.
Jerry
| Re: hibernate and collection setters [message #608626 is a reply to message #87893] |
Hi Jerry,
subclasses.
gr. Martin
>> not being defined.
> HbDataStore.
> Jerry
The Netherlands
FUDForum. Page generated in 0.12782 seconds
