Home » Language IDEs » Java Development Tools (JDT) » -> Strange icon behaviour in jface TreeViewer
-> Strange icon behaviour in jface TreeViewer [message #87712] Thu, 21 August 2003 09:11 Go to next message
Hi there,
Currently I develop a TreeViewer dialog using Eclipse 2.1.
I got a strange behaviour about the label icons, which I think is
incorrect. I would like to ask if the behaviour is corrected in 2.1.1 or
3.0.
Here is the 'problem':
this works: (first case)
myTreeViewer.setLabelProvider(myLabelProvider);
myTreeViewer.setInput(myInput);
this doesn't work: (first case)
The default label provider of myTreeViewer uses a
ImageDescriptor.getMissingImageDescriptor() to label
the tree items.
The myLabelProvider uses images of 16x16 but the
missing image has a size smaller than that (8x8 or 4x4 not sure).
So in the first case the tree is rendered using the correct
images and display 'em with a size of 16x16 (correct).
In the second case the tree is rendered using the correct
images but display 'em with a size of 8x8 (incorrect).
This brings me to the conclusion that if I ever change
the label provider I have to do something like:
setInput(getInput());
I think this should be done by the TreeViewer base
class ;)
I am using Eclipse 2.1 and Win2k.
Martin (Kersten)
Re: -> Strange icon behaviour in jface TreeViewer [message #88421 is a reply to message #87712] Fri, 22 August 2003 15:42 Go to previous messageGo to next message
Should I file in a bug report on this?
Martin (Kersten)
> Hi there,
> 3.0.
> the tree items.
> class ;)
> Martin (Kersten)
Re: -> Strange icon behaviour in jface TreeViewer [message #88436 is a reply to message #88421] Fri, 22 August 2003 15:51 Go to previous message
Filed in as #41881:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=41881
Martin (Kersten)
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> schrieb im
Newsbeitrag news:bi5rin$u4f$1@eclipse.org...
> Martin (Kersten)
> > Hi there,
> > 3.0.
> > the tree items.
> > class ;)
> > Martin (Kersten)
Previous Topic:Debug-variable window
Next Topic:Suggestion for optimized compilation of Anonymous inner classes
Current Time: Mon Jul 21 21:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.04623 seconds
