Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo / JPOX]
[Teneo / JPOX] [message #87508] Wed, 27 June 2007 05:32 Go to next message
Originally posted by: fc_supercanard.yahoo.fr
I need to use many *Package.eINSTANCE and I would like to initialize
jpoxDataStore with all of them.
I use this code :
EPackage[] packageArray = new EPackage[] {ApprolesPackage.eINSTANCE,
IdmapPackage.eINSTANCE, BasePackage.eINSTANCE, RegistryPackage.eINSTANCE};
jpoxDataStore.setEPackages(packageArray);
jpoxDataStore.initialize();
And everything works well.
But an exception is thrown when I add another *Package.eINSTANCE in the
array, and I don't see why - it occurs when the initialize() method is
called by the jpoxDataStore object.
[07-6-27 12:02:50:847 EEST] 0000001d ServletWrappe E SRVE0068E:
Uncaught exception thrown in one of the service methods of the servlet:
IdMap. Exception thrown : javax.jdo.JDOFatalInternalException:
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:3342)
at org.jpox.store.rdbms.RDBMSManager$ClassAdder.run(RDBMSManage r.java:2554)
org.jpox.store.rdbms.RDBMSManager$MgmtTransaction.execute(RD BMSManager.java:2406)
at org.jpox.store.rdbms.RDBMSManager.addClasses(RDBMSManager.ja va:821)
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:508)
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:196)
com.ibm.isclite.datastore.global.DatastoreInstall.initDb(Dat astoreInstall.java:94)
com.ibm.isclite.datastore.global.DatastoreInstall.<init>(DatastoreInstall.java:70)
at idmap.IdMapPortlet.init(IdMapPortlet.java:66)
at javax.portlet.GenericPortlet.init(GenericPortlet.java:85)
com.ibm.ws.portletcontainer.core.PortletServlet.doInit(Portl etServlet.java:400)
NestedThrowablesStackTrace:
org.jpox.store.rdbms.table.AbstractTable.addDatastoreField(A bstractTable.java:223)
org.jpox.store.rdbms.table.ClassTable.runSpecifiedCallbacks( ClassTable.java:1045)
at org.jpox.store.rdbms.table.ClassTable.runCallBacks(ClassTabl e.java:891)
org.jpox.store.rdbms.table.ClassTable.addFieldMetaData(Class Table.java:578)
at org.jpox.store.rdbms.table.ClassTable.manageClass(ClassTable .java:397)
org.jpox.store.rdbms.table.ClassTable.initializeForClass(Cla ssTable.java:831)
at org.jpox.store.rdbms.table.ClassTable.initialize(ClassTable. java:269)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.initializeClass Tables(RDBMSManager.java:2950)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:3311)
Quentin
Re: [Teneo / JPOX] [message #87570 is a reply to message #87508] Thu, 28 June 2007 02:17 Go to previous messageGo to next message
Hi Quentin,
I think this is the same exception as here:
http://www.jpox.org/servlet/forum/viewthread?thread=4418
My guess was that this was related to the following mapping:
<collection>..</collection>
<order/>
<column/>
<foreign-key/>
It should be:
<order/>
<foreign-key>
<column/>
<foreign-key>
You can try to repair this manually in the jdo file. This will be solved in the next release of
Teneo. It is filed under this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194381
gr. Martin
french.cancan wrote:
> I use this code :
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Quentin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo / JPOX] [message #87616 is a reply to message #87570] Thu, 28 June 2007 09:46 Go to previous messageGo to next message
Thank you for the suggestion.
I have modified manually each package.jdo file and used new enhanced
classes, but nothing has changed.
I will wait for the next release of Teneo.
Quentin
Martin Taal wrote:
> Hi Quentin,
> <order/>
> <column/>
> <foreign-key/>
> It should be:
> <order/>
> <foreign-key>
> <column/>
> <foreign-key>
> in the next release of Teneo. It is filed under this bugzilla:
> gr. Martin
>> I use this code :
>> the array, and I don't see why - it occurs when the initialize()
>> method is called by the jpoxDataStore object.
>> servlet: IdMap. Exception thrown :
>> javax.jdo.JDOFatalInternalException: java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Quentin
Re: [Teneo / JPOX] [message #87631 is a reply to message #87616] Thu, 28 June 2007 10:00 Go to previous messageGo to next message
I will be very grateful if you could suggest another direction for
solving the problem, or some workaround. Thanks a lot!
> Quentin
> Martin Taal wrote:
>> Hi Quentin,
>> <order/>
>> <column/>
>> <foreign-key/>
>> It should be:
>> <order/>
>> <foreign-key>
>> <column/>
>> <foreign-key>
>> solved in the next release of Teneo. It is filed under this bugzilla:
>> gr. Martin
>>> Hi,
>>> I use this code :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Quentin
Re: [Teneo / JPOX] [message #87749 is a reply to message #87631] Fri, 29 June 2007 00:18 Go to previous messageGo to next message
There is also another user having this same issue (see thread: "does not translate to an instance
class"). So I will for sure look into it further but I would need a testcase to debug/analyse what
goes wrong here. Can you provide a (simple) testcase which reproduces this issue?
gr. Martin
>> Quentin
>> Martin Taal wrote:
>>> Hi Quentin,
>>> <order/>
>>> <column/>
>>> <foreign-key/>
>>> It should be:
>>> <order/>
>>> <foreign-key>
>>> <column/>
>>> <foreign-key>
>>> gr. Martin
>>>> Hi,
>>>> I use this code :
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] [message #88041 is a reply to message #87749] Tue, 03 July 2007 10:59 Go to previous messageGo to next message
Hi Martin,
I have sent a testcase to you on your email.
Quentin
> translate to an instance class"). So I will for sure look into it
> further but I would need a testcase to debug/analyse what goes wrong
> gr. Martin
>>> Quentin
>>> Martin Taal wrote:
>>>> Hi Quentin,
>>>> <order/>
>>>> <column/>
>>>> <foreign-key/>
>>>> It should be:
>>>> <order/>
>>>> <foreign-key>
>>>> <column/>
>>>> <foreign-key>
>>>> gr. Martin
>>>>> Hi,
>>>>> initialize jpoxDataStore with all of them.
>>>>> I use this code :
>>>>> {ApprolesPackage.eINSTANCE, IdmapPackage.eINSTANCE,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Quentin
Re: [Teneo / JPOX] [message #88434 is a reply to message #88041] Fri, 06 July 2007 09:47 Go to previous messageGo to next message
Hi Quentin,
I think I have found a way of improving the mapping so that this error does not occur. Apparently
for a 1-n association the fk-column tag has to be inside an element tag.
So this was the old mapping for the 1-n:
<field name="bigtree" persistence-modifier="persistent" delete-action="restrict">
<collection element-type="tc.tree.impl.BigTreeImpl" dependent-element="true">
<extension vendor-name="jpox" key="cache-lazy-loading" value="true"/>
</collection>
<order column="FRUIT_BIGTREE_IDX"/>
<column name="fruit_bigtree_e_id" allows-null="true"/>
<foreign-key delete-action="cascade" update-action="cascade"/>
</field>
and it should be:
</collection>
<element>
</element>
</field>
I am working to change this in the mapping logic. This will be in the next release. In the meantime
you can try to manually change the mapping and see if it works now on your side.
gr. Martin
> Hi Martin,
> Quentin
>> not translate to an instance class"). So I will for sure look into it
>> gr. Martin
>>>> Quentin
>>>> Martin Taal wrote:
>>>>> Hi Quentin,
>>>>> <order/>
>>>>> <column/>
>>>>> <foreign-key/>
>>>>> It should be:
>>>>> <order/>
>>>>> <foreign-key>
>>>>> <column/>
>>>>> <foreign-key>
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> I use this code :
>>>>>> in the array, and I don't see why - it occurs when the
>>>>>> initialize() method is called by the jpoxDataStore object.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] [message #88672 is a reply to message #88434] Mon, 09 July 2007 09:42 Go to previous message
Ok, it seems that it works using this way.
There isn't NPE anymore, and I can use tables which are well created.
Thank you !
Quentin
Martin Taal wrote:
> Hi Quentin,
> does not occur. Apparently for a 1-n association the fk-column tag has
> value="true"/>
> </collection>
> </field>
> and it should be:
> value="true"/>
> </collection>
> <element>
> </element>
> </field>
> next release. In the meantime you can try to manually change the mapping
> gr. Martin
>> Hi Martin,
>> Quentin
>>> gr. Martin
>>>>> enhanced classes, but nothing has changed.
>>>>> Quentin
>>>>> Martin Taal wrote:
>>>>>> Hi Quentin,
>>>>>> <order/>
>>>>>> <column/>
>>>>>> <foreign-key/>
>>>>>> It should be:
>>>>>> <order/>
>>>>>> <foreign-key>
>>>>>> <column/>
>>>>>> <foreign-key>
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> I use this code :
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Quentin
Re: [Teneo / JPOX] [message #608602 is a reply to message #87508] Thu, 28 June 2007 02:17 Go to previous message
Hi Quentin,
<order/>
<column/>
<foreign-key/>
It should be:
<order/>
<foreign-key>
<column/>
<foreign-key>
gr. Martin
> I use this code :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Quentin
The Netherlands
Re: [Teneo / JPOX] [message #608605 is a reply to message #87570] Thu, 28 June 2007 09:46 Go to previous message
Quentin
Martin Taal wrote:
> Hi Quentin,
> <order/>
> <column/>
> <foreign-key/>
> It should be:
> <order/>
> <foreign-key>
> <column/>
> <foreign-key>
> gr. Martin
>> I use this code :
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Quentin
Re: [Teneo / JPOX] [message #608606 is a reply to message #87616] Thu, 28 June 2007 10:00 Go to previous message
> Quentin
> Martin Taal wrote:
>> Hi Quentin,
>> <order/>
>> <column/>
>> <foreign-key/>
>> It should be:
>> <order/>
>> <foreign-key>
>> <column/>
>> <foreign-key>
>> gr. Martin
>>> Hi,
>>> I use this code :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Quentin
Re: [Teneo / JPOX] [message #608614 is a reply to message #87631] Fri, 29 June 2007 00:18 Go to previous message
gr. Martin
>> Quentin
>> Martin Taal wrote:
>>> Hi Quentin,
>>> <order/>
>>> <column/>
>>> <foreign-key/>
>>> It should be:
>>> <order/>
>>> <foreign-key>
>>> <column/>
>>> <foreign-key>
>>> gr. Martin
>>>> Hi,
>>>> I use this code :
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] [message #608634 is a reply to message #87749] Tue, 03 July 2007 10:59 Go to previous message
Hi Martin,
Quentin
> gr. Martin
>>> Quentin
>>> Martin Taal wrote:
>>>> Hi Quentin,
>>>> <order/>
>>>> <column/>
>>>> <foreign-key/>
>>>> It should be:
>>>> <order/>
>>>> <foreign-key>
>>>> <column/>
>>>> <foreign-key>
>>>> gr. Martin
>>>>> Hi,
>>>>> I use this code :
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Quentin
Re: [Teneo / JPOX] [message #608660 is a reply to message #88041] Fri, 06 July 2007 09:47 Go to previous message
Hi Quentin,
</collection>
</field>
and it should be:
</collection>
<element>
</element>
</field>
gr. Martin
> Hi Martin,
> Quentin
>> gr. Martin
>>>> Quentin
>>>> Martin Taal wrote:
>>>>> Hi Quentin,
>>>>> <order/>
>>>>> <column/>
>>>>> <foreign-key/>
>>>>> It should be:
>>>>> <order/>
>>>>> <foreign-key>
>>>>> <column/>
>>>>> <foreign-key>
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> I use this code :
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Quentin
The Netherlands
Re: [Teneo / JPOX] [message #608676 is a reply to message #88434] Mon, 09 July 2007 09:42 Go to previous message
Thank you !
Quentin
Martin Taal wrote:
> Hi Quentin,
> value="true"/>
> </collection>
> </field>
> and it should be:
> value="true"/>
> </collection>
> <element>
> </element>
> </field>
> gr. Martin
>> Hi Martin,
>> Quentin
>>> gr. Martin
>>>>> Quentin
>>>>> Martin Taal wrote:
>>>>>> Hi Quentin,
>>>>>> <order/>
>>>>>> <column/>
>>>>>> <foreign-key/>
>>>>>> It should be:
>>>>>> <order/>
>>>>>> <foreign-key>
>>>>>> <column/>
>>>>>> <foreign-key>
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> I use this code :
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Quentin
Previous Topic:[EMF Compare] 0.7.0RC1 release !
Next Topic:Import XMI
Current Time: Sun Jul 20 04:51:14 EDT 2025
Powered by FUDForum. Page generated in 0.29201 seconds
