Home » Newcomers » Newcomers » workspace not saved
workspace not saved [message #87463] Mon, 18 July 2005 15:27 Go to next message
Originally posted by: andre.trusoft.co.za
I use eclipse on my workstation and on my laptop. On the workstation,
eclipse remember the last workspace I used and starts directly in it, but
on my laptop it does not.
I had a look at possible places where the information might be stored and I
found that the last workspace location is stored in
$HOME/.eclipse/.metadata/.plugins/org.eclipse.ui.workbench/d ialog_settings.xml
On my workstation this file contains some detail about the workspace, but on
my laptop the file does not change. It always contains only the following
two lines:
<section name="Workbench"/>
I have set my workbench preferences to 'Prompt for workspace on startup' and
to 'Confirm exit when closing', but it does not do any of these, even
though the boxes are still ticked when I exit and restart eclipse.
So, now each time I start eclipse on the laptop, I need to switch to my
workspace as it always start with the default ($HOME/.eclipse) which has no
projects
As far as I can see, the settings are the same on both instances of eclipse
Any idea what could cause this?
Andre Truter | Software Engineer | Registered Linux user #185282
~ The box said: "Windows 95 or better", so I installed Linux ~
Re: workspace not saved [message #87507 is a reply to message #87463] Mon, 18 July 2005 16:00 Go to previous messageGo to next message
"Andre Truter" <andre@trusoft.co.za> wrote in message
news:dbgvrd$fv3$1@news.eclipse.org...
and
no
> projects
Assuming the installs are identical, same version, same OS, could you have a
permission issue (looks like you run on Linux) ?
Re: workspace not saved [message #87521 is a reply to message #87507] Mon, 18 July 2005 16:18 Go to previous messageGo to next message
> a permission issue (looks like you run on Linux) ?
No, I checked that first and double-checked it again.
I did also notice now that on the workstation I have a 'preferences.epf'
file in my workspace directory, but on the laptop that file is not present.
Re: workspace not saved [message #87549 is a reply to message #87521] Mon, 18 July 2005 17:04 Go to previous messageGo to next message
news:dbh2q6$jjn$1@news.eclipse.org...
have
present.
..epf is just a preferences export. Did you check logs for errors?
Re: workspace not saved [message #87581 is a reply to message #87549] Mon, 18 July 2005 17:54 Go to previous messageGo to next message
Ah, yes, I forgot that I exported the preferences a while ago on the
workstation.
The only log file that I know of is in $HOME/.eclipse/.metadata/.log
Are there any other?
There were only old log entries in that file. I moved the file and created a
new emty log and stared eclipse again, but no messages was logged.
Re: workspace not saved [message #87639 is a reply to message #87581] Tue, 19 July 2005 00:31 Go to previous message
news:dbh8dp$q97$1@news.eclipse.org...
a
Under your <wokspace>/.metadata
Also playing with Eclipse own metadata may be a cause for many problems, if
you have already done so.
That is typically a no-no ;-)
BTW, what Eclipse version , java version and OS do you run?
Where did you get eclipse from?
What I would suggest, for now is to try to start eclipse with -clean
If you still have a problem, export your preferences, then try to start with
a clean install of Eclipse, pointing to your workspace, then import your
exported prefs.
Cheers, Philippe
philippe ombredanne | nexB
1 650 799 0949 | pombredanne at nexb.com
http://www.nexb.com
http://eclipse.techforge.com
http://sf.net/projects/easyeclipse
Previous Topic:How do I install an Eclipse plug-in?
Next Topic:how to download 3.1 in US?
Current Time: Sun Nov 09 00:10:01 EST 2025
Powered by FUDForum. Page generated in 0.09603 seconds
