Home » Language IDEs » C / C++ IDE (CDT) » problem with make targets
problem with make targets [message #87391] Tue, 25 November 2003 17:05 Go to next message
I set up an additional Make Target (to compile one .o)
When I try to build it I get:
Target Build Error
Error Building Target
Reason:
Internal Error
..log shows:
!ENTRY org.eclipse.cdt.make.ui 4 0 Nov 25, 2003 15:44:18.359
!MESSAGE Invalid thread access
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2330)
at org.eclipse.swt.SWT.error(SWT.java:2260)
at org.eclipse.swt.widgets.Widget.error(Widget.java:385)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:315)
at org.eclipse.swt.widgets.Control.isEnabled(Control.java:1108)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1381)
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorManager.java:966)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1095)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2353)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2365)
org.eclipse.cdt.make.ui.TargetBuild.saveAllResources(TargetB uild.java:63)
at org.eclipse.cdt.make.ui.TargetBuild$2.run(TargetBuild.java:8 8)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1595)
at org.eclipse.cdt.make.ui.TargetBuild$1.run(TargetBuild.java:9 5)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
Any suggestions?
My setup:
OS: Windows XP
Eclipse Version: 2.1.2 (updated from 2.1.1 via update site)
Eclipse Path: c:/eclipse
CDT Version: 1.2.0 (installed from update site)
MinGW Version: 3.1.0 (GDB 5.2.1)
MinGW Path: c:/mingw310
andrew
PS. The documentation is classic :-)
"In the Build Target box, type a build target."
Re: problem with make targets [message #87435 is a reply to message #87391] Wed, 26 November 2003 09:29 Go to previous messageGo to next message
Please submit a bug for this here
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=CDT
> Target Build Error
> Reason:
> Internal Error
> .log shows:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> Any suggestions?
> My setup:
> OS: Windows XP
> andrew
Re: problem with make targets [message #87484 is a reply to message #87435] Wed, 26 November 2003 18:39 Go to previous message
Ok, I submitted a bug.
BTW The workaround is to save before trying to build a Make Target
>> Target Build Error
>> Reason:
>> Internal Error
>> .log shows:
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any suggestions?
>> My setup:
>> OS: Windows XP
>> andrew
Previous Topic:writing for other platforms
Next Topic:Support for Linux Motif on CDT 2.0
Current Time: Tue Jul 22 15:30:27 EDT 2025
Powered by FUDForum. Page generated in 0.03478 seconds
