Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » no implementation classes of "java.lang.Object" have been found!
no implementation classes of "java.lang.Object" have been found! [message #87365] Mon, 25 June 2007 18:11 Go to next message
Originally posted by: juliayip.us.ibm.clom
Hi Martin,
I'm using jpox 1.1.8 with DB2 v9
I'm getting this error when I try to create the schema for a xsd. Is it
saying that it can't find some jdk classes? That I need to add it to the
classpath?
Julia
Exception in thread "main" javax.jdo.JDOUserException: Field
" com.ibm.isclite.wccm.clientevent.impl.PortletDefinitionRefIm pl.supportedPublishingEvent "
is declared as a reference type (interface/Object) but no implementation
org.jpox.metadata.MetaDataUtils.getImplementationNamesForRef erenceField(MetaDataUtils.java:441)
org.jpox.metadata.AbstractPropertyMetaData.setRelation(Abstr actPropertyMetaData.java:1959)
org.jpox.metadata.AbstractPropertyMetaData.getRelatedFieldMe taData(AbstractPropertyMetaData.java:2147)
org.jpox.store.rdbms.sqlidentifier.JPOXIdentifierFactory.new DatastoreContainerIdentifier(JPOXIdentifierFactory.java:132)
org.jpox.store.rdbms.RDBMSManager.getTableIdentifier(RDBMSMa nager.java:2315)
at org.jpox.store.rdbms.RDBMSManager.access$6100(RDBMSManager.j ava:165)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addJoinTableFor Container(RDBMSManager.java:3368)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.access$700(RDBM SManager.java:2470)
org.jpox.store.rdbms.RDBMSManager.newJoinDatastoreContainerO bject(RDBMSManager.java:1033)
org.jpox.store.mapping.AbstractContainerMapping.initialize(A bstractContainerMapping.java:102)
org.jpox.store.mapping.MappingFactory.createMapping(MappingF actory.java:88)
org.jpox.store.mapping.AbstractMappingManager.getMapping(Abs tractMappingManager.java:231)
org.jpox.store.rdbms.table.ClassTable.addFieldMetaData(Class Table.java:458)
at org.jpox.store.rdbms.table.ClassTable.manageClass(ClassTable .java:397)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.initializeClass Tables(RDBMSManager.java:2966)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:3311)
org.jpox.store.rdbms.RDBMSManager$ClassAdder.run(RDBMSManage r.java:2554)
org.jpox.store.rdbms.RDBMSManager$MgmtTransaction.execute(RD BMSManager.java:2406)
at org.jpox.store.rdbms.RDBMSManager.addClasses(RDBMSManager.ja va:821)
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:468)
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:196)
at com.ibm.isclite.wccm.clientevent.Tutorial2.main(Tutorial2.ja va:99)
The section of the jdo for hte above
looks like this:
<class
name=" com.ibm.isclite.wccm.clientevent.impl.PortletDefinitionRefIm pl "
requires-extent="true" persistence-modifier="persistence-capable"
detachable="true" identity-type="datastore">
<implements name="com.ibm.isclite.wccm.clientevent.PortletDefinitionRef "/>
<inheritance strategy="superclass-table">
<discriminator value="PortletDefinitionRef"/>
</inheritance>
<version strategy="version-number" column="e_version"/>
<field name="supportedPublishingEvent" persistence-modifier="persistent">
<collection element-type="java.lang.Object">
<extension vendor-name="jpox" key="cache-lazy-loading" value="true"/>
</collection>
<join/>
<order column="PORTLETDEFINITIONREF_SUPPORTEDPUBLISHINGEVENT_IDX"/ >
</field>
<field name="supportedSubscribedEvent" persistence-modifier="persistent">
</collection>
<join/>
<order column="PORTLETDEFINITIONREF_SUPPORTEDSUBSCRIBEDEVENT_IDX"/ >
</field>
<field name="portletDefinitionRef" persistence-modifier="persistent"
null-value="none"/>
</class>
Re: no implementation classes of "java.lang.Object" have been found! [message #87380 is a reply to message #87365] Tue, 26 June 2007 03:42 Go to previous messageGo to next message
Hi Julia,
Teneo can't find the implementation class for the supportedPublishingEvent efeature (or it's type is
really java.lang.Object). When you check the generated java code for this efeature is it's type then
also java.lang.Object?
Can you post the ecore of this efeature?
gr. Martin
Julia wrote:
> Hi Martin,
> classpath?
> Julia
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> looks like this:
> <class
> </inheritance>
> value="true"/>
> </collection>
> <join/>
> </field>
> value="true"/>
> </collection>
> <join/>
> </field>
> persistence-modifier="persistent" null-value="none"/>
> </class>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: no implementation classes of "java.lang.Object" have been found! [message #87413 is a reply to message #87380] Tue, 26 June 2007 09:01 Go to previous messageGo to next message
Hi Martin,
This is the generated model code that point of error
protected EList<Object> supportedPublishingEvent = null;
public EList<Object> getSupportedPublishingEvent() {
if (supportedPublishingEvent == null) {
supportedPublishingEvent = new EDataTypeEList<Object>(Object.class,
this,
ClienteventPackage.PORTLET_DEFINITION_REF__SUPPORTED_PUBLISH ING_EVENT);
return supportedPublishingEvent;
This the section in the jdo:
<class
<implements
</inheritance>
</collection>
<join/>
</field>
</collection>
<join/>
</field>
null-value="none"/>
</class>
This is the ecore
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="clientevent"
nsURI=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-clientevent.xsd"
nsPrefix="clientevent">
<eAnnotations source="http://www.w3.org/XML/1998/namespace">
<details key="lang" value="en"/>
</eAnnotations>
<eClassifiers xsi:type="ecore:EClass" name="ClientEvents">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="This is the root element and
holds list of Client Events"/>
</eAnnotations>
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="ClientEvents"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference"
name="paramDefinition" upperBound="-1"
eType="#//ParamDefinition" containment="true"
resolveProxies="false">
<details key="documentation" value="The definition of one or
client parameters"/>
</eAnnotations>
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="param-definition"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
name="eventDefinition" upperBound="-1"
eType="#//EventDefinition" containment="true"
<details key="documentation" value="The definition of client side
events"/>
</eAnnotations>
<eAnnotations
<details key="name" value="event-definition"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute"
name="elementSupportingEventsGroup"
unique="false" upperBound="-1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<details key="documentation" value="Abstract base element for
specifying elements supporting events. For each concrete subtype of
element there must be an element defined that can substitute
element-supporting-events"/>
</eAnnotations>
<eAnnotations
<details key="kind" value="group"/>
<details key="name" value="element-supporting-events:group"/>
</eAnnotations>
name="elementSupportingEvents"
upperBound="-1" eType="#//Elements" changeable="false"
volatile="true" transient="true"
derived="true" containment="true" resolveProxies="false">
</eAnnotations>
<eAnnotations
<details key="name" value="element-supporting-events"/>
<details key="group" value="element-supporting-events:group"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DocumentRoot">
<eAnnotations
<details key="name" value=""/>
<details key="kind" value="mixed"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="mixed"
<eAnnotations
<details key="kind" value="elementWildcard"/>
<details key="name" value=":mixed"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="xMLNSPrefixMap"
upperBound="-1"
eType="ecore:EClass
http://www.eclipse.org/emf/2002/Ecore#//EStringToStringMapEn try"
transient="true" containment="true" resolveProxies="false">
<eAnnotations
<details key="kind" value="attribute"/>
<details key="name" value="xmlns:prefix"/>
</eAnnotations>
name="xSISchemaLocation" upperBound="-1"
eType="ecore:EClass
<eAnnotations
<details key="name" value="xsi:schemaLocation"/>
</eAnnotations>
upperBound="-2" eType="#//Elements" changeable="false"
</eAnnotations>
<eAnnotations
</eAnnotations>
name="ibmPortalClientevent" upperBound="-2"
eType="#//ClientEvents" volatile="true" transient="true"
<eAnnotations
<details key="name" value="ibm-portal-clientevent"/>
</eAnnotations>
name="portletDefinitionRef" upperBound="-2"
eType="#//PortletDefinitionRef" volatile="true" transient="true"
derived="true"
<details key="documentation" value="wire target definition for
specifying portlet as an element supporting events"/>
</eAnnotations>
<eAnnotations
<details key="name" value="portlet-definition-ref"/>
<details key="affiliation" value="element-supporting-events"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Elements" abstract="true">
<details key="documentation" value="This is an abstract type that
can never be used directly; actual XML documents can only contain derived
types"/>
</eAnnotations>
<eAnnotations
<details key="name" value="elements"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="description"
eType="ecore:EClass base.ecore#//Text"
<eAnnotations
<details key="name" value="description"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EventDefinition">
<details key="documentation" value="The event-definitionType is used
to declare events the portlet can either receive or emit. The name must be
unique and must be the one the portlet is using in its code for
referencing this event."/>
</eAnnotations>
<eAnnotations
<details key="name" value="EventDefinition"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
unique="false" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//QName">
<eAnnotations
<details key="name" value="name"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="alias"
<eAnnotations
<details key="name" value="alias"/>
</eAnnotations>
name="paramDefinitionRef" unique="false"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//IDREF">
<eAnnotations
<details key="name" value="paramDefinitionRef"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Param">
<details key="documentation" value=" Add details"/>
</eAnnotations>
<eAnnotations
<details key="name" value="Param"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
unique="false" lowerBound="1"
http://www.eclipse.org/emf/2003/XMLType#//String">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="option"
unique="false"
http://www.eclipse.org/emf/2003/XMLType#//Boolean"
unsettable="true">
<eAnnotations
<details key="name" value="option"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ParamDefinition">
<details key="documentation" value="details"/>
</eAnnotations>
<eAnnotations
<details key="name" value="ParamDefinition"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="param"
lowerBound="1" upperBound="-1"
eType="#//Param" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="param"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="uniqueName"
unique="false"
http://www.eclipse.org/emf/2003/XMLType#//ID"
iD="true">
<eAnnotations
<details key="name" value="uniqueName"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="PortletDefinitionRef"
eSuperTypes="#//Elements">
<details key="documentation" value="Portlet that supports the
event"/>
</eAnnotations>
<eAnnotations
<details key="name" value="PortletDefinitionRef"/>
</eAnnotations>
<eAnnotations
<details key="name" value="supported-publishing-event"/>
</eAnnotations>
<eAnnotations
<details key="name" value="supported-subscribed-event"/>
</eAnnotations>
name="portletDefinitionRef" unique="false"
<eAnnotations
<details key="name" value="portletDefinitionRef"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: no implementation classes of "java.lang.Object" have been found! [message #87431 is a reply to message #87413] Tue, 26 June 2007 09:22 Go to previous messageGo to next message
Hi Julia,
Teneo won't be able to discover which type the supportedPublishingEvent is as the generated java
code also uses java.lang.Doc. The only way to solve this is to make the type in the schema more
specific (if you control the schema). If you don't control the schema then maybe this would help?:
http://www.jpox.org/docs/1_1/objects.html
Following these guidelines, can you manually change the mapping? If this works then maybe I can add
it to Teneo using annotations.
gr. Martin
Julia wrote:
> Hi Martin,
> EDataTypeEList<Object>(Object.class, this,
> <class
> <implements
> </inheritance>
> </collection>
> <join/>
> <order
> </field>
> </collection>
> <join/>
> <order
> </field>
> </class>
> This is the ecore
> xmlns:xmi="http://www.omg.org/XMI"
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> events"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> name="xMLNSPrefixMap" upperBound="-1"
> eType="ecore:EClass
> <eAnnotations
> </eAnnotations>
> eType="ecore:EClass
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> derived="true"
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> derived types"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> used to declare events the portlet can either receive or emit. The name
> must be unique and must be the one the portlet is using in its code for
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> unsettable="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> iD="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> event"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #87445 is a reply to message #87431] Tue, 26 June 2007 09:23 Go to previous messageGo to next message
I made a small typo, here is the correct post:
Hi Julia,
code also uses java.lang.Object. The only way to solve this is to make the type in the schema more
gr. Martin
Martin Taal wrote:
> Hi Julia,
> is as the generated java code also uses java.lang.Doc. The only way to
> solve this is to make the type in the schema more specific (if you
> would help?:
> works then maybe I can add it to Teneo using annotations.
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> <class
>> <implements
>> </inheritance>
>> </collection>
>> <join/>
>> <order
>> </field>
>> </collection>
>> <join/>
>> <order
>> </field>
>> </class>
>> This is the ecore
>> <?xml version="1.0" encoding="UTF-8"?>
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> side events"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> eType="ecore:EClass
>> <eAnnotations
>> </eAnnotations>
>> eType="ecore:EClass
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> transient="true" derived="true"
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> derived types"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> name must be unique and must be the one the portlet is using in its
>> code for referencing this event."/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> unsettable="true">
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> iD="true">
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> event"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #87460 is a reply to message #87445] Tue, 26 June 2007 15:45 Go to previous messageGo to next message
Hi Martin,
I spoke to the developer. She said that Qname is correct as it identify
the URI,local-name pair in the element.
In the xsd
<xs:complexType name="EventDefinition">
<xs:element name="supported-publishing-event" type="xs:QName"
minOccurs="0" maxOccurs="1"/>
</xs:complexType>
would end up loooking like this in the xml file
<EventDefinition>
<supported-publishing-event
xmlns:x="http:acme.com/event">com.acme.foo</supported-publishing-event >
</EventDefinition>
where [xmlns:x="http:acme.com/event"] and [com.acme.foo] would be user
defined data.
Could the metadata look like this:
<class
</inheritance>
<collection element-type="java.lang.String">
</collection> //for the URI
</collection> //for the local name
<join/>
</field>
</collection>
<join/>
</field>
null-value="none"/>
</class>
Re: no implementation classes of "java.lang.Object" have been found! [message #87475 is a reply to message #87460] Tue, 26 June 2007 17:44 Go to previous messageGo to next message
Hi Julia,
No that won't work afaik. Looking at the generated java code, what type of object would be put in
the EList declared in the generated java code?
gr. Martin
Julia wrote:
> Hi Martin,
> In the xsd
> </xs:complexType>
> <EventDefinition>
> </EventDefinition>
> user defined data.
> <class
> </inheritance>
> <join/>
> </field>
> </collection>
> <join/>
> </field>
> null-value="none"/>
> </class>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #87554 is a reply to message #87475] Wed, 27 June 2007 19:53 Go to previous messageGo to next message
Hi Martin,
I don't think I have any generated code for Qname. I thought QName was a
primitive type similiar to IDREF. IDREF is translated to java.lang.string.
Would not QName be the same?
We have it declared as
minOccurs="0" maxOccurs="unbounded"/>
where xs namespace refers to xmlns:xs="http://www.w3.org/2001/XMLSchema.
Would I need to add code for this?
Re: no implementation classes of "java.lang.Object" have been found! [message #87586 is a reply to message #87554] Thu, 28 June 2007 02:26 Go to previous message
Hi Julia,
Yes that was also my first thought (that it is a String) but because you mentioned that it existed
of two parts (uri and local-name) I thought that in your case it was more complex.
If you always know that it is a String then setting it the element-type to java.lang.String (instead
of java.lang.Object) should work.
gr. Martin
Julia wrote:
> Hi Martin,
> java.lang.string. Would not QName be the same?
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #608590 is a reply to message #87365] Tue, 26 June 2007 03:42 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> classpath?
> Julia
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> looks like this:
> <class
> </inheritance>
> value="true"/>
> </collection>
> <join/>
> </field>
> value="true"/>
> </collection>
> <join/>
> </field>
> </class>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #608592 is a reply to message #87380] Tue, 26 June 2007 09:01 Go to previous message
Hi Martin,
this,
<class
<implements
</inheritance>
</collection>
<join/>
</field>
</collection>
<join/>
</field>
null-value="none"/>
</class>
This is the ecore
</eAnnotations>
</eAnnotations>
<eAnnotations
</eAnnotations>
</eAnnotations>
<eAnnotations
</eAnnotations>
events"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
</eAnnotations>
<eAnnotations
</eAnnotations>
</eAnnotations>
<eAnnotations
</eAnnotations>
</eClassifiers>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
upperBound="-1"
eType="ecore:EClass
<eAnnotations
</eAnnotations>
eType="ecore:EClass
<eAnnotations
</eAnnotations>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
derived="true"
</eAnnotations>
<eAnnotations
</eAnnotations>
</eClassifiers>
types"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
</eClassifiers>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
</eClassifiers>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
unique="false"
unsettable="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
unique="false"
iD="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
event"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: no implementation classes of "java.lang.Object" have been found! [message #608593 is a reply to message #87413] Tue, 26 June 2007 09:22 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> <class
> <implements
> </inheritance>
> </collection>
> <join/>
> <order
> </field>
> </collection>
> <join/>
> <order
> </field>
> </class>
> This is the ecore
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> events"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> eType="ecore:EClass
> <eAnnotations
> </eAnnotations>
> eType="ecore:EClass
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> derived="true"
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> derived types"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> unsettable="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> iD="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> event"/>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #608594 is a reply to message #87431] Tue, 26 June 2007 09:23 Go to previous message
Hi Julia,
gr. Martin
Martin Taal wrote:
> Hi Julia,
> would help?:
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> <class
>> <implements
>> </inheritance>
>> </collection>
>> <join/>
>> <order
>> </field>
>> </collection>
>> <join/>
>> <order
>> </field>
>> </class>
>> This is the ecore
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> side events"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> eType="ecore:EClass
>> <eAnnotations
>> </eAnnotations>
>> eType="ecore:EClass
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> derived types"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> unsettable="true">
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> iD="true">
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> event"/>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #608595 is a reply to message #87445] Tue, 26 June 2007 15:45 Go to previous message
Hi Martin,
In the xsd
</xs:complexType>
<EventDefinition>
</EventDefinition>
defined data.
<class
</inheritance>
<join/>
</field>
</collection>
<join/>
</field>
null-value="none"/>
</class>
Re: no implementation classes of "java.lang.Object" have been found! [message #608596 is a reply to message #87460] Tue, 26 June 2007 17:44 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> In the xsd
> </xs:complexType>
> <EventDefinition>
> </EventDefinition>
> user defined data.
> <class
> </inheritance>
> <join/>
> </field>
> </collection>
> <join/>
> </field>
> null-value="none"/>
> </class>
The Netherlands
Re: no implementation classes of "java.lang.Object" have been found! [message #608601 is a reply to message #87475] Wed, 27 June 2007 19:53 Go to previous message
Hi Martin,
Re: no implementation classes of "java.lang.Object" have been found! [message #608603 is a reply to message #87554] Thu, 28 June 2007 02:26 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
The Netherlands
Previous Topic:Comment information in the DB
Next Topic:Comment information in the DB
Current Time: Thu Jul 17 22:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.18312 seconds
