Home » Newcomers » Newcomers » software update problem connecting to rtpgsa.ibm.com
software update problem connecting to rtpgsa.ibm.com [message #87279] Mon, 18 July 2005 06:39 Go to next message
Originally posted by: oriorke.ie.ibm.com
Hey all,
Not sure if this particular problem has been posted before, did a quick
search and it doesn't seem like it has. When I go Software Updates I'm
asked for a username/password for "rtpgsa.ibm.com". This is a new
problem that comes up since I was trying to diagnose an earlier problem,
by typing the following URL into my web browser:
https://rtpgsa.ibm.com/projects/b/build.portal/Gibraltar/Ecl ipse_wplc_Plugin/
The original problem was that it couldn't find a certificate chain for
the above site
Any ideas?
Are there cookies I can clear somewhere maybe? The options given in
"Install/update preferences" are pretty limited.
Kevin.
Re: software update problem connecting to rtpgsa.ibm.com [message #87301 is a reply to message #87279] Mon, 18 July 2005 06:43 Go to previous messageGo to next message
Kevin O'Riordan wrote:
> Hey all,
> the above site
> Any ideas?
> Kevin.
Actually got back the original problem after I clicked "Cancel" a few
times for the username/password message:
Network connection problems encountered during search.
Unable to access
" https://rtpgsa.ibm.com/projects/b/build.portal/Gibraltar/Ecl ipse_wplc_Plugin/".
Unable to access site:
[Server returned HTTP response code: "401 Authorization Required" for
URL:
https://rtpgsa.ibm.com/projects/b/build.portal/Gibraltar/Ecl ipse_wplc_Plugin/.]
URL:
Re: software update problem connecting to ... [message #87316 is a reply to message #87301] Mon, 18 July 2005 07:06 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Kevin,
You should be more careful in not posting internal IBM info like this to
a public newsgroup.
- Jeff
Previous Topic:Eclipse 3.1 can't start with IBM Java SDK 1.4.2 on PPC platform with Yellow Dog Linux OS.
Next Topic:problem with 3.1 on SUSE9.3
Current Time: Wed Nov 05 14:27:39 EST 2025
Powered by FUDForum. Page generated in 0.29763 seconds
