Home » Archived » BIRT » Cannot get POJO
Cannot get POJO [message #87249] Thu, 03 November 2005 16:00 Go to next message
Originally posted by: mlorenz.nc.rr.com
I have some logic that I have tested in Java and it works fine, but when I
try it through BIRT I get null as my object.
My initialize script for the report looks thusly:
importPackage(Packages.com.labcorp.cels.pla.domain.organizat ion);
labCorp = LabCorp.INSTANCE;
lab = labCorp.getLabNamed( "CMBP" );
dept = lab.getDepartmentNamed( "Molecular Biology" );
The Lab class, which is to be returned from getLabNamed() and LabCorp are
both in the organization package.
I have a Data object from the palette with the following expression:
labCorp.getName()
That works fine. But, I have another Data object with:
lab.toString()
which does NOT work. An error for the report initialization script says:
TypeError: Cannot call method "getDepartmentNamed" of null (#9)
So, the Lab is obviously not being retrieved through my LabCorp instance.
If anyone sees what I'm doing wrong, I'd greatly appreciate advice.
(I'm on BIRT 1.0.1 and Eclipse 3.1)
Thanks, Mark
Re: Cannot get POJO [message #87264 is a reply to message #87249] Thu, 03 November 2005 16:27 Go to previous messageGo to next message
Originally posted by: m.n.com
What are you using underneath to get the data?
> I try it through BIRT I get null as my object.
> are both in the organization package.
> labCorp.getName()
> lab.toString()
> Thanks, Mark
Re: Cannot get POJO [message #87278 is a reply to message #87249] Thu, 03 November 2005 16:47 Go to previous messageGo to next message
Also, check the log file in the log directory in the viewer plugin directory
...\plugins\org.eclipse.birt.report.viewer_1.0.1\birt\logs
> labCorp.getName()
> lab.toString()
> Thanks, Mark
Re: Cannot get POJO [message #87295 is a reply to message #87249] Thu, 03 November 2005 16:56 Go to previous messageGo to next message
Mark,
Have you tried
LC = Packages.com.labcorp.cels.pla.domain.organization.LabCorp;
if not static do
LC = new Packages.com.labcorp.cels.pla.domain.organization.LabCorp();
Jason Weathersby
BIRT PMC
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:8d23237422c0dcac396aeb2723401197$1@www.eclipse.org...
> importPackage(Packages.com.labcorp.cels.pla.domain.organizat ion); labCorp
> = LabCorp.INSTANCE;
> labCorp.getName()
> lab.toString()
> Thanks, Mark
Re: Cannot get POJO [message #87504 is a reply to message #87295] Fri, 04 November 2005 07:31 Go to previous messageGo to next message
Jason -
I can get the LabCorp instance OK - that was the one you had helped with
before. So, "labCorp = LabCorp.INSTANCE;" works fine. The problem is that
I then do:
and "lab" is null. This exact same code works in Java, just not in BIRT.
My .jar is obviously being found since LabCorp is found. And Lab and
LabCorp are in the same package.
I'll try what you suggest, but it doesn't seem related to me.
Thanks for the reply.
Mark
Re: Cannot get POJO [message #87518 is a reply to message #87278] Fri, 04 November 2005 07:40 Go to previous messageGo to next message
Thanks for the tip Mark. I checked in the file from yesterday and found
this:
"SEVERE: TypeError: Cannot call method "getDepartmentNamed" of null
(<inline>#11) org.mozilla.javascript.EcmaError: TypeError: Cannot call
method "getDepartmentNamed" of null (<inline>#11)"
So, my "lab" instance is NOT being returned from my (valid) "labCorp"
instance. Same code works in Java, just not BIRT.
Thanks again.
Mark L
Re: Cannot get POJO [message #87533 is a reply to message #87264] Fri, 04 November 2005 07:41 Go to previous messageGo to next message
I am using Mock objects to return the values for now. Just focusing on
BIRT, not the persistence.
Mark L
Re: Cannot get POJO [message #87609 is a reply to message #87518] Fri, 04 November 2005 10:37 Go to previous messageGo to next message
Log what is being passed to getLabNamed and try it both ways. Also
delimit the value like: "'" + param + "'"
> this:
> Thanks again.
> Mark L
Re: Cannot get POJO [message #87663 is a reply to message #87249] Fri, 04 November 2005 10:58 Go to previous messageGo to next message
Mark,
If you just have this in the initialize
> = LabCorp.INSTANCE;
Nothing on controls does the report complain?
Any way you could upload a stub class so we could try it?
Jason Weathersby
BIRT PMC
> = LabCorp.INSTANCE;
> labCorp.getName()
> lab.toString()
> Thanks, Mark
Re: Cannot get POJO [message #87770 is a reply to message #87663] Fri, 04 November 2005 13:01 Go to previous message
Sending via email directly to you...Mark
Previous Topic:BIRT-Report parameter default value as null
Next Topic:BIRT viewer and dynamic parameters
Current Time: Thu Jul 17 21:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.08609 seconds
