Home » Archived » Test and Performance Tools Platform (TPTP) » Passing parameters through Automation API
Passing parameters through Automation API [message #87107] Tue, 14 November 2006 10:39 Go to next message
Originally posted by: luca.holmen.nospam.accurate.no
I have successfully created a small java application that launches a custome
written test type that interacts with a remote custom test agent.
I need to pass some parameters to the Agent (e.g. from the java application
to the agent), as I'm able to do within a test editor. As I can see it the
only way is to pass some properties.
Any other ideas or small sample available that shows how?
BR
L
Re: Passing parameters through Automation API [message #103734 is a reply to message #87107] Mon, 09 July 2007 11:12 Go to previous message
Hi Luca,
Yes, you can use custom commands between your client and agent. For
more information, see:
http://help.eclipse.org/help33/topic/org.eclipse.tptp.platfo rm.agentcontroller.doc.isv/concepts/ac/c_dc_framework_intro. html
Paul
"Luca" <luca.holmen@nospam.accurate.no> wrote in message
news:ejco0b$115$1@utils.eclipse.org...
> custome written test type that interacts with a remote custom test agent.
> application to the agent), as I'm able to do within a test editor. As I
> can see it the only way is to pass some properties.
> BR
> L
Previous Topic:[AGR] Hang problem when running many tests with the ant <tptp:execution> task
Next Topic:Deployment, Artifacts, and shared TPTP projects.
Current Time: Fri Nov 07 02:12:11 EST 2025
Powered by FUDForum. Page generated in 0.04853 seconds
