Home » Eclipse Projects » GEF » Question on EditParts as an IPropertySource
Question on EditParts as an IPropertySource [message #87092] Mon, 14 July 2003 08:56 Go to next message
Originally posted by: jgreen.upb.de
all my EditParts are now IPropertySources, so I can use the Properties
View to edit them. (as described in the article "Take control of your
properties" by Dicky Johan)
Everything works fine, but now I have to implement the "Reset to
Default" feature for some properties.
Is it possible that another "resetPropertyValue(Object id)" method is
called when I hit the associated button in the Properties View? Not the
one in the associated EditPart?
Does anyone have a hint on this?
Thanks a lot
Joel
Heres my log message:
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.gef.internal.ui.properties.UndoablePropertySheet Entry.resetPropertyValue(UndoablePropertySheetEntry.java:562 )
org.eclipse.ui.views.properties.PropertySheetViewer.resetPro perties(PropertySheetViewer.java:743)
org.eclipse.ui.views.properties.DefaultsAction.run(DefaultsA ction.java:36)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
Re: Question on EditParts as an IPropertySource [message #87121 is a reply to message #87092] Mon, 14 July 2003 09:38 Go to previous message
You could also implement IProperySource directly on your model, in some
cases. The only other alternative is to wrapper the editpart (or model)
with an adapter which implements IProperySource.
"Joel Greenyer" <jgreen@upb.de> wrote in message
news:beu9cs$q1b$1@eclipse.org...
> Thanks a lot
> Joel
> !STACK 0
> at
rtyValue(UndoablePropertySheetEntry.java:562)
> at
> at
> at
Previous Topic:tracking tool activate in palette-less applications
Next Topic:ScrollableThumbnail - image disposal
Current Time: Fri Nov 07 20:51:47 EST 2025
Powered by FUDForum. Page generated in 0.03687 seconds
