Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo @Index support
Teneo @Index support [message #87056] Thu, 21 June 2007 15:27 Go to next message
My DBA wont allow me to use teneo to drive DB management unless I can
establish arbitrary indexes on columns. (This is completely reasonable
since we will be putting 52 million consumer records in to it)
It seems that this just isn't supported, but hopefully I just haven't found
the right way to do it.
<xsd:element name="SSN" type="xsd:string">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">
@Column(name="SSN",length="9")
@Index(name="IDX_CMR36013")
</xsd:appinfo>
<xsd:documentation>Social Security Number</xsd:documentation>
</xsd:annotation>
</xsd:element>
I've also tried:
<xsd:complexType name="Consumer">
<xsd:annotation><xsd:appinfo source="teneo.jpa">
@Table(
name="CMR3601T"
uniqueConstraints = { @UniqueConstraint(columnNames={"CONSUMER_SK"}),
@UniqueConstraint(columnNames={"CONSUMER_SK", "DATE_OF_BIRTH"})}
indexes = {
@Index(name="CMR36011", columnNames={"CONSUMER_SK"}),
@Index(name="CMR36016",
columnNames={"CONSUMER_SK","DATE_OF_BIRTH"}),
@Index(name="CMR36013", columnNames={"SSN"}),
@Index(name="CMR36014", columnNames={"DATE_OF_BIRTH"}),
@Index(name="CMR36015", columnNames={"CONSUMER_ID"})
</xsd:appinfo></xsd:annotation>
</xsd:complexType>
The unique constraints seem to work fine, but the indexes cause an
exception. Any help getting this work would be greatly appreciated. If it
isn't supported, is there anything I could do to help get it working?
Thanks very much,
Jason Henriksen
Re: Teneo @Index support [message #87071 is a reply to message #87056] Thu, 21 June 2007 18:12 Go to previous messageGo to next message
I have included this a few weeks ago in Teneo and have used it at a customer. So it's there but it
will be some time (a few weeks) before I can release a new build.
gr. Martin
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> I've also tried:
> @Table(
> name="CMR3601T"
> indexes = {
> </xsd:complexType>
> Thanks very much,
> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo @Index support [message #87086 is a reply to message #87071] Thu, 21 June 2007 19:09 Go to previous message
Excellent. I'll definitely be excited to get that deployed.
Thank you for all of your work on this project,
Jason
"Martin Taal" <mtaal@elver.org> wrote in message
news:f5et4u$4jp$1@build.eclipse.org...
> gr. Martin
found
> > <xsd:annotation>
> > </xsd:appinfo>
> > </xsd:annotation>
> > </xsd:element>
> > I've also tried:
> > @Table(
> > name="CMR3601T"
> > indexes = {
> > </xsd:complexType>
it
> > Thanks very much,
> > Jason Henriksen
> The Netherlands
Re: Teneo @Index support [message #607036 is a reply to message #87056] Thu, 21 June 2007 18:12 Go to previous message
gr. Martin
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> I've also tried:
> @Table(
> name="CMR3601T"
> indexes = {
> </xsd:complexType>
> Thanks very much,
> Jason Henriksen
The Netherlands
Re: Teneo @Index support [message #607037 is a reply to message #87071] Thu, 21 June 2007 19:09 Go to previous message
Jason
> gr. Martin
found
> > <xsd:annotation>
> > </xsd:appinfo>
> > </xsd:annotation>
> > </xsd:element>
> > I've also tried:
> > @Table(
> > name="CMR3601T"
> > indexes = {
> > </xsd:complexType>
it
> > Thanks very much,
> > Jason Henriksen
> The Netherlands
Previous Topic:Teneo @Index support
Next Topic:[EMF Compare] text compare instead of emf compare
Current Time: Thu Nov 20 14:25:37 EST 2025
Powered by FUDForum. Page generated in 0.05040 seconds
