Home » Archived » Test and Performance Tools Platform (TPTP) » error during launch of profiling and logging -- piAgent
error during launch of profiling and logging -- piAgent [message #86936] Mon, 13 November 2006 09:56 Go to next message
Originally posted by: jonathan.alvarsson.gmail.com
Hi.
I Installed the Eclipse monitoring tools from the Callisto Discovery site
with the Eclipse update manager but when I try it out I get the following
error message:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent
And I quite frankly haven't got a clue about what I am supposed to do
about it...
Can someone please help me?
// Jonathan Alvarsson
Re: error during launch of profiling and logging -- piAgent [message #86952 is a reply to message #86936] Mon, 13 November 2006 10:36 Go to previous messageGo to next message
Jonathan Alvarsson wrote:
> Hi.
> site with the Eclipse update manager but when I try it out I get the
> following error message:
> directory: piAgent
> about it...
The monitoring tools only, and not the rest of TPTP? Because the piAgent
is the profiling agent that, I assume, would be in the Trace component.
So have you tried to launch something for profiling? If so, you probably
want to get the rest of TPTP.
Of course, even if you have it all you can run into that message if
you're "mixing and matching" 32- and 64-bit stuff. E.g., if you have
downloaded a 64-bit JVM but are trying to run 32-bit TPTP, the JVM won't
"see" the piAgent.
So can you launch the "statistical analysis agent"? (Perfmon on Windows
and LinuxAgent on Linux) Because that's the agent you would have
available with the monitoring component.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: error during launch of profiling and logging -- piAgent [message #87059 is a reply to message #86952] Tue, 14 November 2006 05:00 Go to previous messageGo to next message
Well yes I first installed the monitoring system and all required
dependencies (which didn't include the Trace component). I just now
installed the trace component but that didn't make any difference.
> "see" the piAgent.
Okey. How do I know if I have a mix and match of 32 and 64 bit stuff
installed? Perhaps a slightly bit naively I thought I automagicly would
get the right components with the automatic updater and that the
components would complain if they were mixed and matched with the wrong
components. But I guess we are not in that world yet...
I don't know. How would I do that? To my great dissapointment googling
didn't really help me with that question. Maybee I am asking the wrong
question?
btw I run Ubuntu linux and Eclipse 3.2
Re: error during launch of profiling and logging -- piAgent [message #87123 is a reply to message #87059] Tue, 14 November 2006 10:48 Go to previous messageGo to next message
>> piAgent is the profiling agent that, I assume, would be in the Trace
>> component.
>> probably want to get the rest of TPTP.
>> won't "see" the piAgent.
>> Windows and LinuxAgent on Linux) Because that's the agent you would
>> have available with the monitoring component.
> question?
What kind of hardware? If you're on a 32-bit hardware system, then we
shouldn't be seeing any of these.
If you're on a 64-bit system, did you get the 32-bit Eclipse for Linux
x86 or the 64-bit Eclipse for x86_64? If the latter, are you running
with a 64-bit JVM?
You're right that the update manager should automatically get all the
right stuff... for Eclipse... but it can't control what JVM you're getting.
Bottom line, the "Cannot find agent library...piAgent" message generally
comes from either (1) not being able to find libpiAgent.so... path
issues and the like, or (2) it finding it, but the JVM and the
libpiAgent.so being different "bit-ness".
RDS
Re: error during launch of profiling and logging -- piAgent [message #87370 is a reply to message #87123] Wed, 15 November 2006 08:05 Go to previous messageGo to next message
It's an intel centrino Duo so I guess 64 bit?
> with a 64-bit JVM?
I have no idea. It normally works well but maybe that doesn't mean
anything? How do I find out? java -help didn't really say anything
meaningful (at least not to me... :( )
Is there a way to see if Eclipse is compiled for 32 bit och 64 bit? I
found this line: "sun.arch.data.model=32" in configuration details is that
a sign that I have a 32 bit version of Eclipse?
Re: error during launch of profiling and logging -- piAgent [message #87430 is a reply to message #87370] Wed, 15 November 2006 11:11 Go to previous messageGo to next message
>> with a 64-bit JVM?
> that a sign that I have a 32 bit version of Eclipse?
Run "java -version" and tell me what it says.
As for the Eclipse version... what is the exact name of the zip file you
downloaded and installed?
RDS
Re: error during launch of profiling and logging -- piAgent [message #87674 is a reply to message #87430] Thu, 16 November 2006 12:52 Go to previous messageGo to next message
$ java -version
java version "1.5.0_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_07-b03)
Java HotSpot(TM) Client VM (build 1.5.0_07-b03, mixed mode, sharing)
eclipse-SDK-3.2-linux-gtk.tar.gz
the build id is: M20060629-1905
Re: error during launch of profiling and logging -- piAgent [message #87690 is a reply to message #87674] Thu, 16 November 2006 13:04 Go to previous messageGo to next message
> $ java -version
>> you downloaded and installed?
Okay, so you're running stock 32-bit software across the board... so
there should be no problem outside of path issues, and if you're running
Eclipse for profiling without an external agent controller (and it
doesn't sound like you downloaded the agent controller for remote
profiling, right?) then technically the IAC (internal agent controller)
should handle the path for you.
This sounds like an old problem whereby the Linux version wasn't finding
the piAgent library in the plugins directory and needed to be added to
the path... but I thought that was fixed.
How about trying:
find <eclipse installation directory> -name "*piAgent*" -print
and then add that directory to your path before restarting Eclipse. Then
when it looks for libpiAgent.so it will find it this time.
There is a release note in the versions affected by this problem about
this behavior... but I don't tend to read release notes either so I
can't fault others for not doing so.
RDS
Re: error during launch of profiling and logging -- piAgent [message #87795 is a reply to message #87690] Fri, 17 November 2006 11:08 Go to previous messageGo to next message
> How about trying:
I tried
export
PATH=$PATH:/home/jonathan/programs/eclipse/plugins/org.eclip se.hyades.execution.linux.x86_4.2.0.v200606131519/
which is where the file libpiAgent.so is but it didn't make any
difference.
Hm release note? Did it flash by during the automagic installation in
Eclipse or is it something I have to search more to find? Can't say that I
usually read it I thought they mostly contained info about differences in
a new version for users used with older versions.
Re: error during launch of profiling and logging -- piAgent [message #87854 is a reply to message #87795] Fri, 17 November 2006 14:50 Go to previous message
>> How about trying:
>> Then when it looks for libpiAgent.so it will find it this time.
> I tried
> export
> which is where the file libpiAgent.so is but it didn't make any difference.
> I usually read it I thought they mostly contained info about differences
> in a new version for users used with older versions.
Release note is at <
http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_2_0.html
>, but it won't do any good since this item is 3.PT.4 there, and you've
already taken the corrective action.
I'm stumped. I know we've had problems getting things working on
Ubuntu... something about libstdc++ compatibility needs, but I don't see
anything in the release note about that. Perhaps one of the other buys
(Bob? Samson?) can chime in now since I've been no help.
RDS
Previous Topic:Strange error when starting Tomcat with TPTP command-line options
Next Topic:No more handles during startup of AGR test on Linux
Current Time: Wed Jul 16 02:45:14 EDT 2025
Powered by FUDForum. Page generated in 0.07764 seconds
