Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Invoking context-menu items inside an editor pane
[AGR] Invoking context-menu items inside an editor pane [message #86803] Fri, 10 November 2006 14:00 Go to next message
Hello All,
I seem to be having alot of problems with version 4.2.1 trying to get
the playback functionality to execute recorded context menu invocations
from inside an editor pane.
All I'm doing, is trying to record the creation of a Java project, a
Java class and trying to open up a "Quick Outline" from the editor pane
using the context menu. The quick playback (in my development workbench)
will replay this context menu invocation with no problem. However, when
I actually run the Test runtime configuration, it fails at this point
with a CoreException thrown by MacroObjectLocator.locatePopupMenuItem().
The message is "Cannot locate menu item ..."
I have tried to debug this problem myself but I cannot run the Test
configuration in Debug mode. Is there a way that I can bootstrap a PDE
runtime-workbench configuration to make it perform the test so that I
can debug it or somehow debug it another way?
Chris
Re: [AGR] Invoking context-menu items inside an editor pane [message #86818 is a reply to message #86803] Fri, 10 November 2006 18:49 Go to previous messageGo to next message
You can attach a debugger to the process:
1) Check-out test/org.eclipse.tptp.test.auto.gui from the 4_2_1 branch
2) Open org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIExecOb jAdapter
3) Set DEBUG to true
4) Set your break points
5) Launch the test suite in standard mode
6) Create a debug launch configuration of type Remote Java Application
7) Change the port # to 8005 and click on debug
Make sure that you keep your source in sync with
<ECLIPSE-INSTANCE> /plugins/org.eclipse.tptp.test.auto.gui_4.2.0.v200608302257/ autogui.jar
when you make any changes.
I have also attached a test suite that uses key events to select an entry
from the quick outline.
Ali Mehregani
"Chris McGee" <cbmcgee@ca.ibm.com> wrote in message
news:ej2i7c$mde$1@utils.eclipse.org...
> Hello All,
> Chris
Re: [AGR] Invoking context-menu items inside an editor pane [message #87014 is a reply to message #86818] Mon, 13 November 2006 15:23 Go to previous messageGo to next message
Hi Ali,
Thanks for the debugging help. I managed to run through a number of
debugging scenarios.
For the JDT Quick Outline menu item, I discovered the problem in
MacroObjectLocator.foundWidget(). Basically, the recorder records the
widget ID of the menu item as "{{Quick Outline&#x9Ctrl-O}}-{{1.0}}"
whereas the widget found in the actual menu is "{{Quick
Out&line}}-{{1.0}}." It looks like the recorder just needs to be
consistent with the MacroObjectLocator. I managed to hack the name in
the XML for the test case and it works perfectly.
I tested the same context menu capability in structured editor (an EMF
reflective editor with a tree-based content view) and I found that it
could not find a particular context menu item. The problem here is a
little more complicated. It seems that there is a difference in the way
that an editor is activated when be invoked from the AGR than when the
user manually opens up an editor. Here is a stack trace:
EXTLibraryEditor$7.requestActivation() line: 1106
EXTLibraryEditor$7(ViewerPane).handleEvent(Event) line: 211
EventTable.sendEvent(Event) line: 66
ViewForm(Widget).sendEvent(Event) line: 928
ViewForm(Widget).sendEvent(int, Event, boolean) line: 952
ViewForm(Widget).sendEvent(int) line: 933
Shell.setActiveControl(Control) line: 1199
ToolBar(Control).sendFocusEvent(int) line: 1984
ToolBar(Widget).wmSetFocus(int, int, int) line: 2145
ToolBar(Control).WM_SETFOCUS(int, int) line: 3860
ToolBar.WM_SETFOCUS(int, int) line: 1170
ToolBar(Control).windowProc(int, int, int, int) line: 3312
Display.windowProc(int, int, int, int) line: 4025
^ The above part of the trace does not get invoked when using the AGR
OS.SetFocus(int) line: not available [native method]
ToolBar(Control).forceFocus() line: 735
ToolBar(Control).setFocus() line: 2315
ToolBar(Composite).setFocus() line: 790
ViewForm(Composite).setFocus() line: 788
EXTLibraryEditor.setFocus() line: 1759
EditorPane(PartPane).setFocus() line: 309
EditorPane.setFocus() line: 117
WorkbenchPage$3.run() line: 600
SafeRunner.run(ISafeRunnable) line: 37
Platform.run(ISafeRunnable) line: 843
WorkbenchPage.activatePart(IWorkbenchPart) line: 595
WorkbenchPage.setActivePart(IWorkbenchPart) line: 3203
WorkbenchPage.activate(IWorkbenchPart) line: 588
WorkbenchPage.busyOpenEditorBatched(IEditorInput, String, boolean, int)
line: 2604
WorkbenchPage.busyOpenEditor(IEditorInput, String, boolean, int) line: 2528
WorkbenchPage.access$10(WorkbenchPage, IEditorInput, String, boolean,
int) line: 2520
WorkbenchPage$9.run() line: 2505
BusyIndicator.showWhile(Display, Runnable) line: 67
WorkbenchPage.openEditor(IEditorInput, String, boolean, int) line: 2500
WorkbenchPage.openEditor(IEditorInput, String, boolean) line: 2485
IDE.openEditor(IWorkbenchPage, IFile, boolean, boolean) line: 388
IDE.openEditor(IWorkbenchPage, IFile, boolean) line: 350
EditorUtility.openInEditor(IFile, boolean) line: 275
EditorUtility.openInEditor(Object, boolean) line: 139
OpenActionUtil.open(Object, boolean) line: 49
OpenAction.run(Object[]) line: 190
OpenAction.run(IStructuredSelection) line: 174
OpenAction(SelectionDispatchAction).dispatchRun(ISelection) line: 267
OpenAction(SelectionDispatchAction).run() line: 243
I can't seem to understand why the Java code behaves differently with
the AGR than with a regular user. Perhaps it has something to do with
SWT trying to send an OS event (OS.setFocus())? I even tried manually
inserting a wait state after opening up the editor to allow the display
to process any pending events.
If I can get some of these basic things working then I will definitely
be able to use the AGR to automate some UI tests.
Chris
> Ali Mehregani
>> Hello All,
>> Thanks,
>> Chris
Re: [AGR] Invoking context-menu items inside an editor pane [message #87192 is a reply to message #87014] Tue, 14 November 2006 15:55 Go to previous messageGo to next message
I managed to track down the latter case. It was because a modal dialog
was popping up in my eclipse. Removing the dialog fixed the problem.
Chris
Chris McGee wrote:
> Hi Ali,
> line: 2604
> 2528
> int) line: 2520
> Chris
>> 2) Open
>> entry from the quick outline.
>> Thanks,
>> Ali Mehregani
>>> Hello All,
>>> Thanks,
>>> Chris
Re: [AGR] Invoking context-menu items inside an editor pane [message #87520 is a reply to message #87014] Wed, 15 November 2006 18:54 Go to previous message
Hi Chris,
Please open a defect for the first case.
Ali Mehregani
news:ejak88$st1$1@utils.eclipse.org...
> Hi Ali,
> consistent with the MacroObjectLocator. I managed to hack the name in the
> EventTable.sendEvent(Event) line: 66 ViewForm(Widget).sendEvent(Event)
> line: 928 ViewForm(Widget).sendEvent(int, Event, boolean) line: 952
> ViewForm(Widget).sendEvent(int) line: 933 Shell.setActiveControl(Control)
> line: 1199 ToolBar(Control).sendFocusEvent(int) line: 1984
> ToolBar(Control).WM_SETFOCUS(int, int) line: 3860 ToolBar.WM_SETFOCUS(int,
> int) line: 1170 ToolBar(Control).windowProc(int, int, int, int) line: 3312
> ToolBar(Control).forceFocus() line: 735 ToolBar(Control).setFocus() line:
> 2315 ToolBar(Composite).setFocus() line: 790
> ViewForm(Composite).setFocus() line: 788 EXTLibraryEditor.setFocus() line:
> 1759 EditorPane(PartPane).setFocus() line: 309 EditorPane.setFocus() line:
> 117 WorkbenchPage$3.run() line: 600 SafeRunner.run(ISafeRunnable) line: 37
> line: 2604 WorkbenchPage.busyOpenEditor(IEditorInput, String, boolean,
> int) line: 2528 WorkbenchPage.access$10(WorkbenchPage, IEditorInput,
> String, boolean, int) line: 2520 WorkbenchPage$9.run() line: 2505
> OpenActionUtil.open(Object, boolean) line: 49 OpenAction.run(Object[])
> line: 190 OpenAction.run(IStructuredSelection) line: 174
> I can't seem to understand why the Java code behaves differently with the
> AGR than with a regular user. Perhaps it has something to do with SWT
> inserting a wait state after opening up the editor to allow the display to
> If I can get some of these basic things working then I will definitely be
> Chris
>> 2) Open
>> Thanks,
>> Ali Mehregani
>>> Hello All,
>>> Thanks,
>>> Chris
Previous Topic:FIT tests in the TPTP framework
Next Topic:Remote Import of log file
Current Time: Mon Jul 21 22:54:26 EDT 2025
Powered by FUDForum. Page generated in 0.27515 seconds
