Home » Eclipse Projects » Eclipse Platform » CVS and watch / edit command
CVS and watch / edit command [message #86728] Tue, 01 July 2003 16:20 Go to next message
Originally posted by: marco.dubacher.com
Hi all
I use Eclipse together with CVS. As far as I know the watch/edit commands
haven't been implemented yet in eclipse. Is that right?
As I want to use these commands nevertheless, I tried to trigger them
through the external tool feature. Everything is fine with this feature, but
the variables like ${container_loc}, ${resource_name}, ... can not be
expanded. When I try to run the external tool the error "The variable named
'resource_name' for the arguments does not exist. What am I doint wrong?
Thanks for any comments
-Marco
Re: CVS and watch / edit command [message #86751 is a reply to message #86728] Tue, 01 July 2003 16:42 Go to previous message
Originally posted by: stefan.jagieniak.gmx.de
Edit/Watch is available from 2.1 on. You find it under
Window-Preferences-Team-CVS-Watch/Edit and it works fine. You may even configure
it to send a CVS edit to the server if a read-only file is edited.
Stefan
Marco Dubacher schrieb:
> Hi all
> -Marco
Previous Topic:rss/nntp/email client plugin
Next Topic:Build Path Entry Warning
Current Time: Thu Sep 04 15:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.03578 seconds
