Home » Archived » Test and Performance Tools Platform (TPTP) » the test execution service launches additional JVM and Eclipse instance
the test execution service launches additional JVM and Eclipse instance [message #86683] Wed, 08 November 2006 09:32 Go to next message
Originally posted by: ted.nospam.org
The test execution service sample described in the documentation
(see belove)launches an additional JVM and Eclipse instance. This behaviour
is not the wanted when the test execution is launched from within an already
running Eclipse instance (e.g. from a plug-in). How can I configure the
test client adapter to not start a extra version of Eclipse?
/T
// Create the Java adapter associated with the specified Eclipse home
AutomationClientAdapter automation = new
AutomationClientAdapter("d:\\development\\eclipse");
// Create and configure a properties object
Properties properties = new Properties();
properties.setProperty("workspace", "D:\\development\\workspace");
properties.setProperty("project", "tests");
properties.setProperty("suite", "unit-tests/testA.testsuite");
// Execute the service named below using the configured properties
automation.execute("org.eclipse.hyades.test.tools.core.execute ",
properties);
Re: the test execution service launches additional JVM and Eclipse instance [message #103829 is a reply to message #86683] Mon, 09 July 2007 12:15 Go to previous messageGo to next message
Hi Ted,
This has since been fixed in 4.2. Please move up to the latest TPTP
release:
http://www.eclipse.org/tptp/home/downloads/?ver=4.4.0
Paul
"Ted" <ted@nospam.org> wrote in message
news:eispqo$ojl$1@utils.eclipse.org...
> behaviour
> already running Eclipse instance (e.g. from a plug-in). How can I
> configure the
> /T
> properties);
Re: the test execution service launches additional JVM and Eclipse instance [message #103915 is a reply to message #103829] Mon, 09 July 2007 16:12 Go to previous message
I think there are two issues in question here. The first issue (which
was fixed in TPTP 4.2) was that we launched an unnecessary additional
eclipse instance when running ASF services from outside of eclipse (in
order to change the workspace or VM arguments.) This has been corrected
in the OutOfProcessStrategy so now we launch the eclipse instance with
the correct workspace and VM args, thus eliminating the unnecessary JVM.
The second issue, which is what I believe Ted was asking about, is how
to use the current Eclipse/TPTP instance when invoking an ASF service
_from within an existing Eclipse/TPTP shell_. This behavior is
unchanged, and can be done easily by simply choosing the no-arg
constructor for the Java AutomationClientAdapter. The no-arg
constructor does not attempt to launch a new eclipse instance, and
instead invokes the service from within the existing Eclipse/TPTP instance.
Hope this helps,
--Joe
Paul Slauenwhite wrote:
> Hi Ted,
> release:
> Paul
>> behaviour
>> configure the
>> /T
>> properties);
Previous Topic:[AGR] Compatibility between AGR 4.3 and AGR 4.4
Next Topic:AGR - Defining the name of the generated .execution file
Current Time: Fri Nov 07 08:08:08 EST 2025
Powered by FUDForum. Page generated in 0.03917 seconds
