Home » Language IDEs » C / C++ IDE (CDT) » Unable to attach source
Unable to attach source [message #86549] Fri, 21 November 2003 16:28 Go to next message
Originally posted by: jim.brown.mindspring.com
I'm attempting to step into a library that I built
with command line tools with make and gcc.
When I step into it, I get C/C++ File Editor message
Source not found.
I press the Attach Source... button,
file system directory
next
browse to the directory where the source is.
Finish
Nothing changes. Still no source.
I'm not sure what the "associate with" part of the
dialog is supposed to do. Anything I can find in the
documentation about associate or attach has to do with
java classes and jar files.
Any help appreciated.
I'm on Solaris 9 and MinGW on WIn XP. Same problem both
places
Jim
Re: Unable to attach source [message #86564 is a reply to message #86549] Fri, 21 November 2003 19:11 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
What is the path that debugger is looking for? Is it the same as you
specified in the "Attach source" dialog?
<jim.brown@mindspring.com> wrote in message
news:3FBE8370.3070501@mindspring.com...
> Source not found.
> next
> Finish
> places
> Jim
Re: Unable to attach source [message #86579 is a reply to message #86564] Fri, 21 November 2003 23:57 Go to previous messageGo to next message
I'm not sure how to tell what path the debugger is looking for.
I tried browsing to the directory that contains the source
and I tried entering an absolute path to the directory.
>>Source not found.
>>next
>>Finish
>>places
>>Jim
Re: Unable to attach source [message #86621 is a reply to message #86579] Sat, 22 November 2003 10:17 Go to previous messageGo to next message
When debugger doesn't find a source it displays a special editor with the
"Attach source" button. The message in the editor contains the name of file
news:3FBEECAF.4050200@mindspring.com...
> >>Source not found.
> >>next
> >>Finish
> >>places
> >>Jim
Re: Unable to attach source [message #86647 is a reply to message #86621] Sat, 22 November 2003 11:46 Go to previous messageGo to next message
Now I see the path name.
I'm in my home directory and I execute ./eclipse/eclipse
The source I want is in a directory in my home directory.
The path I see in the "Attach source" is a relative path
from my home directory. "src/file.cpp"
I guessed that maybe I needed to start eclipse from the
directory where the executable is. I tried that but it
made no difference. Attach source still says "src/file.cpp"
Does this suggest anything I should try?
Jim
>>>>Source not found.
>>>>next
>>>>Finish
>>>>places
>>>>Jim
Re: Unable to attach source [message #86670 is a reply to message #86549] Sat, 22 November 2003 13:53 Go to previous messageGo to next message
Just some further information. I decided to check out that the
GNU tools were set up OK. I wrote a simple make file,
build my test program that uses the shared lib I want to debug,
ran ddd and got in to the shared library OK.
This tells me that I'm doing something - probably trivially - wrong
in eclipse. If I can get eclipse to attach the source for my
shared library, I can begin debugging in earnest.
Any suggestions welcome.
Jim
> Source not found.
> next
> Finish
> places
> Jim
Re: Unable to attach source [message #87250 is a reply to message #86647] Mon, 24 November 2003 12:41 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Just add your home directory as an additional source location. On Windows it
should look like "C:\home..", on Solaris - "/home/...". Uncheck the
"Assosciate" option. This should work.
news:3FBF92CE.80405@mindspring.com...
> Jim
the
file
> >>>>Source not found.
> >>>>next
> >>>>Finish
> >>>>places
> >>>>Jim
Re: Unable to attach source [message #87265 is a reply to message #86647] Mon, 24 November 2003 12:46 Go to previous messageGo to next message
> Jim
the
file
> >>>>Source not found.
> >>>>next
> >>>>Finish
> >>>>places
> >>>>Jim
Re: Unable to attach source [message #87302 is a reply to message #87250] Mon, 24 November 2003 13:52 Go to previous message
Adding my home directory as a source location worked.
I think this is the final step to getting the system
set up so I can work on my code.
Many Many Thanks.
Jim
>>Jim
> the
> file
>>>>>>Source not found.
>>>>>>next
>>>>>>Finish
>>>>>>places
>>>>>>Jim
Previous Topic:What are relative paths relative to
Next Topic:outline view and classes
Current Time: Thu Nov 13 22:35:15 EST 2025
Powered by FUDForum. Page generated in 0.03949 seconds
