Home » Language IDEs » ServerTools (WTP) » Eclipse 2.1
Eclipse 2.1 [message #86521] Wed, 23 March 2005 18:23 Go to next message
Originally posted by: dmacias.xign.com
Is there any release of Web Tools which will work with Eclipse 2.1 and
jdk131_08?
Re: Eclipse 2.1 [message #86537 is a reply to message #86521] Wed, 23 March 2005 17:46 Go to previous messageGo to next message
Originally posted by: laurentd75___no.sp_am.yahoo.fr
Hi Diana,
> jdk131_08?
NO... Web Tools specifically requires Eclipse 3.1 because it uses features
from the 3.1 stream that are not available in the 2.1 or 3.0 streams.
The current pre-release for Web Tools Platform is 1.0M3 and it is meant to
be run under the Eclipse 3.1M5a pre-release.
Laurent
Re: Eclipse 2.1 [message #86581 is a reply to message #86537] Wed, 23 March 2005 20:02 Go to previous messageGo to next message
IBM's initial contribution to the WTP project runs on Eclipse 3.0.1 and
can be found at http://www.alphaworks.ibm.com/tech/webtools.
Laurent is correct that no version of the Web tools run on Eclipse 2.1. If
you're interested in running eariler versions of these tools on Eclipse
2.1 you can look at purchasing WebSphere Studio Application Developer from
IBM.
Lawrence
>Hi Diana,
>> jdk131_08?
features
to
>Laurent
Re: Eclipse 2.1 [message #87073 is a reply to message #86581] Thu, 24 March 2005 17:43 Go to previous messageGo to next message
Thank you for the info. Do you know of any JSP, JavaScript plugins for
Eclipse 2.1?
Re: Eclipse 2.1 [message #87342 is a reply to message #87073] Fri, 25 March 2005 12:17 Go to previous message
Originally posted by: laurentd75_n.o_spam.yahoo.fr
Hi Diana,
> Eclipse 2.1?
* Commercial suite of plugins for J2EE development: MyEClipse IDE
http://www.myeclipseide.com/
If you register, you can dowload a 30-day eval version of the
Eclipse 2.1 edition
* Open-source J2EE plugins for JSP development:
- Lomboz (J2EE development inc. JSP colouring/content-assist etc..)
http://www.objectlearn.com/index.jsp
- JBossIDE (http://www.jboss.org/products/jbosside) is not applicable
to you because its current versions require Eclipse 3.0 at least
* Open-source plugins for Javascript development (syntax colouring etc)
- JSEditor : syntax colouring only
http://jseditor.sourceforge.net/
Watch out though, it doesn't say clearly what version is compatible with
Eclipse 2.1
- myJSEditor: syntax colouring, code completion, and syntax error
reporting
http://eclipse.moelleryoung.com/jseditor/index.php
Note however that it was only tested with Eclipse 3.x, it might not
work under Eclipse 2.x
* Searching for other Eclipse plugins:
For other plugins, browse the Eclipse COmmunity site (aka "Eclipse
Corner") at: http://www.eclipse.org/community/
Use the left-hand menu to browse through the "open source plugins" and
"commercial plugins" pages.
Also try Eclipse Plugin Central at: http://www.eclipseplugincentral.com/
Hope this helps,
Laurent
Previous Topic:Publish to Server?
Next Topic:IWAB0019E Error in getting method from Java bean.
Current Time: Sun Nov 09 17:50:30 EST 2025
Powered by FUDForum. Page generated in 0.03800 seconds
