Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » problem with object in mulitple lists
| problem with object in mulitple lists [message #86473] |
Thu, 14 June 2007 11:17  |
I have a case where TypeC extends TypeB, which extends TypeA. TypeC has an
EList<TypeB> getter method. If I have two instances of TypeC, and add the
same instance of TypeB to the ELists in both instances of TypeC, it doesn't
work. The first TypeC's EList has the position where the TypeB object
should have been set to null.
I created a test using the names listed above, created two TypeB objects
named TestNameB1 and TestNameB2, and then added both to an instance of
TypeC, and only TestNameB1 to a second instance of TypeC. Here is the
output when I spit them out to the console. The "members" is a println of
the EList.
typeC:com.syntellect.test.model.impl.TypeCImpl@178655 (name: TestNameC1)
members:[[null, com.syntellect.test.model.impl.TypeBImpl@1be4663 (name:
TestNameB2) (someData: Some test data2)]]
typeC:com.syntellect.test.model.impl.TypeCImpl@746ad0 (name: TestNameC2)
members:[[com.syntellect.test.model.impl.TypeBImpl@d8a1a0 (name:
TestNameB1) (someData: Some test data1)]]
Note the null in the first position of the first TypeC's list. If don't add
TestNameB1 to the second TypeC, the first position is filled fine, as it
should be.
Paul
| Re: problem with object in mulitple lists [message #86490 is a reply to message #86473] |
Thu, 14 June 2007 15:12  |
The following is probably the cause, the reference from the table of B to C is modeled in tableB as
a foreign key, this foreign key can only have one value so when saving both c's the second one wins.
Because this happens hidden for hibernate the index of the second element in the first c's list is
not corrected to one, resulting in the null element at index 0.
To prevent this a join table should be used for this reference, there are several ways to accomplish
this;
1) add a @JoinTable annotation to the ereference
2) http://www.elver.org/hibernate/hibernate_relations.html#Forc e+a+join+table+for+1%3An+relations
3) Set the option: PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS to true
gr. Martin
> the EList.
> should be.
> Paul
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: problem with object in mulitple lists [message #606992 is a reply to message #86473] |
this;
gr. Martin
> the EList.
> should be.
> Paul
The Netherlands
Current Time: Thu Nov 06 21:06:00 EST 2025
Powered by FUDForum. Page generated in 0.08016 seconds
