Home » Archived » BIRT » The dataset used by the Chart is invalid
The dataset used by the Chart is invalid [message #86469] Wed, 02 November 2005 05:28 Go to next message
I'm using BIRT 1.0.1.
I have successfully created a scripted dataset and I can display the
expected data in a table. But when I use the very same datasource in a pie
chart or bar chart, I get this error:
There are error(s) in Chart:null
Error0 : Error.ExtendedItemRenderingError(1 time)detail: There are
problems(s) rendering Chart extended item .
Is there any way to find out what could be wrong? The error message
doesn't really help.
The datasource returns two columns and I tried different datatypes
(Integer and String) but that didn't help.
Re: The dataset used by the Chart is invalid [message #86496 is a reply to message #86469] Wed, 02 November 2005 06:31 Go to previous messageGo to next message
Aaron,
Could you please file a bugzilla entry describing this problem and attach
your scripted dataset and the report where you're trying to use it?
https://bugs.eclipse.org/bugs/
David
"Aaron Digulla" <digulla@hepe.com> wrote in message
news:670dea497ddd92ddb10dbd74547133a7$1@www.eclipse.org...
> Hello,
Re: The dataset used by the Chart is invalid [message #86541 is a reply to message #86496] Wed, 02 November 2005 08:01 Go to previous messageGo to next message
You can find an example at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114745
The pure-JavaScript version works but it fails when I try to use the Java
version.
Regards.
Re: The dataset used by the Chart is invalid [message #86630 is a reply to message #86541] Wed, 02 November 2005 09:51 Go to previous message
Thank you, we will investigate this issue and attempt to resolve it for the
next milestone.
David
news:3d95c2445a06bf1d145d5d5ff55907a9$1@www.eclipse.org...
> version.
> Regards.
Previous Topic:Cascading Parameters
Next Topic:Headers in report
Current Time: Tue Nov 04 08:59:23 EST 2025
Powered by FUDForum. Page generated in 0.03673 seconds
