Home » Eclipse Projects » Eclipse Platform » GDK_USE_XFT anti-anti-aliasing issue
GDK_USE_XFT anti-anti-aliasing issue [message #86412] Tue, 01 July 2003 09:44
Hey all,
I'm using the 2.1.1 GTK eclipse and due to performance issues with
anti-aliased fonts, I set GDK_USE_XFT=0 before firing up the IDE. The
short is, it don't work.
Anybody run into this?
Todd
System:
RH9 (with Ximian Desktop)
Eclipse GTK 2.1.1 build id: 200306201433
Sun jvm 1.4.2
Running this script:
#!/bin/sh
export GDK_USE_XFT=0
cd /home/chambery/progs/eclipse-2.1.1
../eclipse -data /home/chambery/dev/workspaces/dbedit-2.1.1
Getting this error in the console:
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:2318)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.graphics.GC.drawImage(GC.java:368)
at org.eclipse.swt.graphics.GC.drawImage(GC.java:351)
at org.eclipse.swt.custom.CTabFolder.scaleImage(CTabFolder.java :1760)
at org.eclipse.swt.custom.CTabFolder.updateArrowBar(CTabFolder. java:1883 )
at org.eclipse.swt.custom.CTabFolder.setButtonBounds(CTabFolder .java:969 )
at org.eclipse.swt.custom.CTabFolder.setItemLocation(CTabFolder .java:104 4)
at org.eclipse.swt.custom.CTabFolder.setItemBounds(CTabFolder.j ava:1127)
at org.eclipse.swt.custom.CTabFolder.onResize(CTabFolder.java:1 308)
at org.eclipse.swt.custom.CTabFolder.access$2(CTabFolder.java:1 301)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:199)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:923)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:948)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:932)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:8 03)
at org.eclipse.swt.custom.CTabFolder.resetTabSize(CTabFolder.ja va:2147)
at org.eclipse.swt.custom.CTabFolder.createItem(CTabFolder.java :386)
at org.eclipse.swt.custom.CTabItem.<init>(CTabItem.java:100)
at org.eclipse.ui.internal.PartTabFolder.createPartTab(PartTabF older.jav a:247)
at org.eclipse.ui.internal.PartTabFolder.createControl(PartTabF older.jav a:224)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashConta iner.java:192)
at org.eclipse.ui.internal.PerspectivePresentation.activate(Per spectiveP resentation.java:96)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:725)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1 799)
at org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:14 96)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow .java:1483)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow. java:416)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:11 88)
at org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java :1185)
at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java: 1074)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoa der.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl. java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces sorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Previous Topic:screenshot
Next Topic:Hashtable
Current Time: Sun Nov 09 15:00:52 EST 2025
Powered by FUDForum. Page generated in 0.17043 seconds
