| How to forward a request through the equinox bridge to OSGi [message #86399] |
Mon, 09 April 2007 17:42  |
Originally posted by: lsyang.us.ibm.com
I got the equinox bridge running in both Tomcat and WAS. I am wondering
how the equinox bridge accepts request. Is it possible get it work in
the follow senario:
Servlet A running in Tomcat,
Servlet B running in OSGi,
Plugin C running in OSGi,
Servlet A get a request. Can the servlet A forward the request to
servlet B through the equinox bridge?
Servlet A get a request. Can the servlet A forward the request to plugin
C through the equinox bridge?
Any suggestion or sample code would be greatly appreciated!
Susan
| Re: How to forward a request through the equinox bridge to OSGi [message #86542 is a reply to message #86443] |
Wed, 11 April 2007 14:12   |
Simon Kaegi wrote:
> Hi Susan,
> In general the servletbridge accepts requests by path/URL.
> What this means for your specific examples is that to forward a request from
> Servlet A to Servlet B you could fetch a RequestDispatcher and send a
> request to the path associated with Servlet B inside the bridge.
> The second use case where (if I'm understanding correctly) you have Servlet
> A trying to directly use functionality in an arbitrary is not directly
> supported by the servletbridge as it only supports interaction via the
> Servlet API. You could create your own custom bridge to do this sort of
> communication (some have done -- search the newsgroup archives) however
> that's a fair bit of work so I'd be a bit cautious for this use-case until
> you fully understood what's involved.
> HTH
> -Simon
> "Susan Diamond" <lsyang@us.ibm.com> wrote in message
> news:evebvl$ca5$1@build.eclipse.org...
>>Hi,
>>how the equinox bridge accepts request. Is it possible get it work in the
>>follow senario:
>>Servlet A get a request. Can the servlet A forward the request to servlet
>>Servlet A get a request. Can the servlet A forward the request to plugin C
>>Susan
Hi Simon,
Thank you for your reply.
I decided to use the first use case. I did some prototype. However,
RequestDispatcher only works when servlet A and servlet B are in the
same WAR. In my case, servlet A is in WAR_A, servlet B is inside the
bridge WAR in OSGi. Do you have any suggestion on how to forward request
and response from one WAR to another WAR?
Susan
| Re: How to forward a request through the equinox bridge to OSGi [message #86557 is a reply to message #86542] |
Wed, 11 April 2007 14:53  |
If you want to do inter-WAR RequestDispatching you first have to get the
other WARs context.
e.g. ServletContext.getContext("other")
....and then use that context to do your request dispatching
-Simon
news:evj8d5$7q8$1@build.eclipse.org...
> Simon Kaegi wrote:
>> Hi Susan,
>> from Servlet A to Servlet B you could fetch a RequestDispatcher and send
>> a request to the path associated with Servlet B inside the bridge.
>> Servlet A trying to directly use functionality in an arbitrary is not
>> directly supported by the servletbridge as it only supports interaction
>> via the Servlet API. You could create your own custom bridge to do this
>> sort of communication (some have done -- search the newsgroup archives)
>> however that's a fair bit of work so I'd be a bit cautious for this
>> use-case until you fully understood what's involved.
>> HTH
>> -Simon
>>>Hi,
>>>follow senario:
>>>Susan
> Hi Simon,
> RequestDispatcher only works when servlet A and servlet B are in the same
> WAR. In my case, servlet A is in WAR_A, servlet B is inside the bridge WAR
> in OSGi. Do you have any suggestion on how to forward request and response
> Susan
FUDForum. Page generated in 0.03907 seconds
