Home » Eclipse Projects » Eclipse Platform » MalformedURLException: Eclipse vs WebSphere
MalformedURLException: Eclipse vs WebSphere [message #86383] Tue, 01 July 2003 08:58 Go to next message
My plugin uses RMI and works perfectly under Eclipse 2.1. However, when I
ported it to WebSphere (WSAD 5.0), it throws a
"MalformedURLException: no protocol: Files\IBM\WebSphere" exception.
Initially I thought that it might be due to the fact that WSAD is based on
Eclipse 2.0 but later discovered that the problem is due to spaces in the
path where WebSphere is installed (C:\Program Files\IBM\WebSphere
Studio\eclipse).
Is there a way to counter this problem ?
Sudarshan Raghavan
www.spectrumscm.com
Re: MalformedURLException: Eclipse vs WebSphere [message #87050 is a reply to message #86383] Tue, 01 July 2003 23:43 Go to previous messageGo to next message
Who throws the exception? Can you give us a stack dump?
Chris Laffra
"Sudarshan Raghavan" <bali_n@yahoo.com> wrote in message
news:bds0hk$2gt$1@rogue.oti.com...
> Studio\eclipse).
> Sudarshan Raghavan
> www.spectrumscm.com
Re: MalformedURLException: Eclipse vs WebSphere [message #87379 is a reply to message #87050] Wed, 02 July 2003 10:48 Go to previous messageGo to next message
Heres the stack trace ...
Startup: using configuration file:C:/Documents and Settings/Bali/My
Documents/IBM/wsad/workspace/.metadata/.config/platform.cfg
Boot URL: file:C:/Program Files/IBM/WebSphere
Studio/eclipse/plugins/org.eclipse.core.boot_2.0.2.1/boot.ja r
Startup: splash path = C:\Program Files\IBM\WebSphere
Workspace location: C:\Documents and Settings\Bali\My
Documents\IBM\wsad\workspace
Debug-Options: file:C:/Program Files/IBM/WebSphere Studio/.options
Install URL: file:C:/Program Files/IBM/WebSphere Studio/eclipse/
java.rmi.ServerException: RemoteException occurred in server thread; nested
exception is:
sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServ er(StreamRemoteC
all.java:257)
sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteC all.java:232)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:135)
at scm.implementation.Scmd_i_Stub.login(Unknown Source)
scm.eclipse.wrappers.SpectrumSCM_AuthManager.validateServer( Unknown Source)
com.spectrumscm.eclipse.core.SpectrumSCM_ServerManager.addSe rver(SpectrumSCM
_ServerManager.java:49)
com.spectrumscm.eclipse.ui.wizards.SpectrumSCM_NewWizard.per formFinish(Spect
rumSCM_NewWizard.java:60)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:577)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:312)
org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:407)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:827)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1529)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:562 )
at org.eclipse.jface.window.Window.open(Window.java:542)
com.spectrumscm.eclipse.ui.views.SpectrumSCM_ServerView$4.ru n(SpectrumSCM_Se
rverView.java:142)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:749 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:407)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:361)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:352)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:47)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1343)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1326)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
---------------------- System Properties -------------------------------
J2RE 1.3.1 IBM Windows 32 build cn131-20020710
Studio\eclipse\jre\bin\java.exe -Xms64M -Xquickstart -Xgcpolicy:optavgpause
-cp C:\Program Files\IBM\WebSphere Studio\eclipse\startup.jar
org.eclipse.core.launcher.Main -os win32 -ws win32 -arch x86 -showsplash
C:\Program Files\IBM\WebSphere Studio\eclipse\eclipse.exe -showsplash 600
Files\IBM\WebSphere Studio\.\.\eclipse\eclipse.exe -data C:\Documents and
Settings\Bali\My Documents\IBM\wsad\workspace -debug
Java Home Dir: C:\Program Files\IBM\WebSphere Studio\eclipse\jre
Java DLL Dir: C:\Program Files\IBM\WebSphere Studio\eclipse\jre\bin
Sys Classpath: C:\Program Files\IBM\WebSphere
Studio\eclipse\jre\lib\rt.jar;C:\Program Files\IBM\WebSphere
Studio\eclipse\jre\lib\i18n.jar;C:\Program Files\IBM\WebSphere
Studio\eclipse\jre\classes
UserArgs:
-Djava.class.path=.
-Xms64M
-Xquickstart
-Djava.class.path=C:\Program Files\IBM\WebSphere Studio\eclipse\startup.jar
-Dinvokedviajava
Sudarshan Raghavan
www.spectrumscm.com
"Chris Laffra" <Chris_Laffra@oti.com> wrote in message
news:bdtkdk$ime$1@rogue.oti.com...
> Chris Laffra
> > Hi,
I
on
the
> > Studio\eclipse).
> > Regards,
> > Sudarshan Raghavan
> > www.spectrumscm.com
Re: MalformedURLException: Eclipse vs WebSphere [message #87394 is a reply to message #87379] Wed, 02 July 2003 10:58 Go to previous messageGo to next message
Sorry ... the first couple of lines in the stacktrace posted in my previous
message should have read:
exception is:
java.rmi.UnmarshalException: error unmarshalling arguments; nested
exception is:
java.net.MalformedURLException: no protocol: Files/IBM/WebSpherejava
Sudarshan Raghavan
www.spectrumscm.com
news:bdunrd$h46$1@rogue.oti.com...
nested
> exception is:
> at
> all.java:257)
> at
> at
Source)
> at
> at
> at
> at
> at
> at
> at
Code))
> at
> at
> at
> rverView.java:142)
> at
> at
> at
> tem.java:352)
> at
> at
Code))
> at
> at
> at
> at
> a:831)
> UserArgs:
> -Djava.class.path=.
> -Xms64M
> -Xquickstart
> -Dinvokedviajava
> Sudarshan Raghavan
> www.spectrumscm.com
Re: MalformedURLException: Eclipse vs WebSphere [message #87781 is a reply to message #87394] Wed, 02 July 2003 22:48 Go to previous message
Strange (to get dissimilar behavior as you are experiencing). Has to do
something with the JRE differences, I would guess. Have you tried
running WSAD with the same JRE you use to run eclipse on? E.g.,
wsappdev.exe -vm [eclipse_jre_path]\jre\bin\javaw.exe -data
[yourworkspace]
Does the error go away? If so, this sounds like an incompatibility between
your JRE and the one shipped with WSAD.
Where did you get your eclipse JRE?
Chris
news:bduoe5$hlu$1@rogue.oti.com...
previous
nested
> exception is:
> exception is:
> Sudarshan Raghavan
> www.spectrumscm.com
> nested
> > exception is:
> > at
> > all.java:257)
> > at
> > at
> Source)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> Code))
> > at
> > at
> > at
> > rverView.java:142)
> > at
> > at
> > at
> > tem.java:352)
> > at
> > at
> Code))
> > at
> > at
> > at
> > at
> > a:831)
600
and
> > UserArgs:
> > -Djava.class.path=.
> > -Xms64M
> > -Xquickstart
> > -Dinvokedviajava
> > Sudarshan Raghavan
> > www.spectrumscm.com
Previous Topic:ILightweightLabelDecorator problem
Next Topic:debugging across multiple projects
Current Time: Fri Jul 18 23:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.10425 seconds
