Home » Eclipse Projects » Eclipse Platform » [JFace] setting a checkbox in a Table
[JFace] setting a checkbox in a Table [message #7757] |
Wed, 23 April 2003 17:12  |
[If this is really an SWT issue, please lemme know, and I'll ask in
e.p.swt.]
How does one programmatically check a box in a Table, based on the
state of the underlying model, when using a CheckboxCellEditor?
Specifically:
I've got a wizard that creates a thing (a foo), which can contain a
list of other things (bars). Bars have properties, most of which are
text (String), but one of which is boolean. I use a Table to represent
the bars (1 row per bar), and use attached Add and Remove buttons to
manage the rows.
The wizard can be invoked in 2 ways:
* "create": As a New Wizard, it creates a new foo, with no bars. If
the user hits my Add button, I create a new, blank bar, the boolean
property of which is false by default (as decreed by an external
DTD).
* "modify": From an editor, the wizard can be invoked on a
pre-existing foo in which one or more bars may already exist, with
each property (including the boolean) already set.
Formerly I only handled the text properties, but now I'd like to
handle the boolean, using a checkbox. I create the Table control
(more-or-less :-) thusly:
0 I create an array of column properties, which are basically just the
String's in the column headers. columnProperties[0] corresponds to
the boolean property (see step 2).
1 I create an array of CellEditor's based on the column properties.
cellEditors[0] is a CheckboxCellEditor, and the rest are
TextCellEditor's.
2 I create a TableViewer using TableViewer(Composite, int), where the
int contains the style bits for creating the Table. Among the bits
set is SWT.CHECK, which creates a checkbox in the first column.
(This is the only way I know to create a checkbox in a table that
will work with a CheckboxCellEditor ... but that's a subject for
another post.)
3 I set the arrays of column properties and CellEditor's on the table
viewer.
4 I add listeners to the table and table viewer.
This works in the "create" context
+ the box is unchecked, but the boolean property is false, so that's
correct
+ the appropriate listener toggles the property when the box is
un/checked
but not in the "modify" context: the box always comes up unchecked,
even if the boolean property in the model is true. So how do I make
the box initially appear checked, if the corresponding bar's
boolean property is set?
Re: [JFace] setting a checkbox in a Table [message #9143 is a reply to message #7757] |
Thu, 24 April 2003 07:21  |
Originally posted by: genadyb.inter.net.il
I'm not sure it will help, but did you try
CheckboxTableViewer class ?
> e.p.swt.]
> Specifically:
> manage the rows.
> DTD).
> TextCellEditor's.
> another post.)
> viewer.
> correct
> un/checked
Current Time: Sat Jul 26 10:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.25439 seconds
